Image attached to an annotation in PIX4Dcloud Pro
This article explains how to attach, view, replace, and delete images associated with annotations in PIX4Dcloud. It also clarifies the difference between manually attached images and automatically generated screenshots, including how these elements are used in annotation PDF reports. Some reporting features are available only with a PIX4Dcloud Pro license.
Licenses: This article is valid for PIX4Dcloud Pro and Enterprise licenses.
Roles: Only Owners, Managers, and Editors can attach an image to an annotation in a datasets in PIX4Dcloud.
Image attachment and screenshot for the annotation PDF report
Image attachments and annotation screenshots
PIX4Dcloud supports two types of images associated with annotations:
Image attachment
An image that is manually uploaded and attached to an annotation. Image attachments can be added from:
  • PIX4Dcatch
  • PIX4Dcloud
These images are visible in the viewer and can be included in annotation reports.
Screenshot for annotation reports (PIX4Dcloud Pro)
A screenshot is automatically generated when an annotation is created in PIX4Dcloud. This screenshot:
  • Is used in the annotation PDF report
  • Is available only with a PIX4Dcloud Pro license
  • Cannot be manually edited or replaced
When an annotation is selected, the right-hand panel displays:
  1. The manually attached image (if available)
  2. The automatically generated screenshot below it
Information:
  • The screenshot included in the annotation PDF report is generated automatically at annotation creation time.
  • If an image is attached manually (for example, from PIX4Dcatch), it is also included in the annotation report.
  • For projects created before the release of annotation reports, or for annotations not created in PIX4Dcloud (for example, imported from external files or from PIX4Dsurvey), no screenshot is generated.
How to enlarge and download an attached image
(This functionality applies to manually attached images)
To enlarge or download an attached image:
  1. Select an annotation in the viewer.
  2. In the right panel, click on the image that was attached in PIX4Dcatch:enlarge
  3. The image will be enlarged:download-2
  4. Click Download to save the image locally, or Close to return to the project.
How to attach, replace, or delete an image
Attach or replace an image
  1. Create an annotation in PIX4Dcloud.
  2. Once created, an automatic screenshot is generated and displayed in the right-hand panel (PIX4Dcloud Pro only).
  3. To add or replace a manually attached image, click Add/Replace image at the top of the annotation properties panel.
    1. Add_replace screenshot annotation v2-1
  4. Select the image file to upload.
Delete an attached image
  1. Click the attached image in the right-hand panel.
  2. Select the Close/Delete option.
  3. Confirm the deletion.
Note: Only manually attached images can be deleted or replaced. Automatically generated screenshots cannot be removed.
