[2022] Technical release notes - PIX4Dcloud
Note: This article includes the release updates for PIX4Dcloud Starter and PIX4Dcloud Pro (formerly PIX4Dcloud Advanced).
December 22nd, 2022 - Improvements
What's new
  • Visualization of the projects computed in a custom coordinate system (Site localization).
Improvements
November 15th, 2022 - Improvements
What's new
  • Toggle annotation visibility by dragging and sliding through the checkboxes for an easier and faster experience.
Improvements
  • DXF layer visibility persists, meaning that it is now possible to hide or show that a part of a DXF layer will remain in that view even after a browser refresh.
Bug fixes
  • DXF duplication in a site is now fixed when moving from one project to another.
October 13th, 2022 - Import DXF
What's new
  • DXF file import as Design Overlay.
Improvements
  • PIX4Dcloud and PIX4Dcloud Advanced process using PIX4Dmapper version 4.8.2 (most recent PIX4Dmapper version available).
Changes
  • New coordinate system transformation database.
  • X is now named Easting, and Y is named Northing.
September 28th, 2022 - Improvements
What's new
  • A Detail tab is available in all projects to show the project metadata.
Improvements
  • A new Building reconstruction option is available on the 3D model template to improve the results for building projects with homogeneous facades.
  • .LAZ point cloud format is now supported.
Changes
September 14th, 2022 - Improvements
Improvements
  • New language available: German.
Improvements
  • AutoGCP algorithm no longer requires a diameter size as input in the project creation wizard.
  • The status of the IFC layers is kept when the project is re-opened.
Bug fixes
  • Fixed the issue where the snapping from/to the IFC was not working properly in some cases.
  • Fixed zooming in and out not working properly when navigating in 3D in projects with IFC files.
August 4th, 2022 - 2D/3D compare and transfer data to Trimble Connect
What's new
  • 3D compare view (Only for PIX4Dcloud Advanced users).
  • Transfer data from PIX4Dcloud or PIX4Dcloud Advanced to Trimble Connect.
  • A new cluster of servers is available in Canada.
  • Download several outputs at the same time.
  • Standard templates are modified when images are taken by ANAFI AI drones. The best internal parameters are applied to calibrate all the cameras and generate quality outputs.
  • North indicator icon in 2D/3D view.
Improvements
  • Online measurements always display precise values.
  • The index layer is displayed on top of the orthomsaic and DSM outputs on the Layer menu by default. This visualization is shown when a project is uploaded from PIX4Dfields to PIX4Dcloud.
  • Subscription plan and License Management are merged into Plans and products under the User account menu.
June 20th, 2022 - Import/Visualize IFC file
What's new
  • Import and visualize an IFC file (Only for PIX4Dcloud Advanced and PIX4engine Cloud users).
Improvements
May 31st, 2022 - Import/Export CSV file in project coordinate system
What's new
Improvements
  • Better image selection for the visual inspector functionality.
  • For projects uploaded from PIX4Dcatch:
    • New geoids supported (South Africa and Mexico).
April 19th, 2022 - Improvements
Improvements
  • PIX4Dcloud and PIX4Dcloud Advanced process using PIX4Dmapper version 4.8.0 (most recent PIX4Dmapper version available).
  • Display status of the project in the timeline.
Bug fixes
  • Fixed bug where the output coordinate system selected by the user was sometimes ignored.
March 17th, 2022 - Improvements
Improvements
  • Texture mesh resolution of 16k x 16k is now supported.
  • The name of the site and the dataset is displayed in the tab of the browser.
  • The project creation wizard now displays the total number of images selected for processing.
Bug fixes
  • Fixed bug related to the Orthomosaic/DSM not being displayed when the projects were processed with some particular coordinate systems.
February 16th, 2022 - Improvements
Improvements
  • PIx4Dcloud and PIX4Dcloud Advanced process using PIX4Dmapper version 4.7.5 (which is the most recent PIX4Dmapper stable release) by default.
February 2nd, 2022 - Limit size increase for orthomosaic, DSM and Index
Improvements
January 17th, 2022 - Multiselect tool for moving and deleting items
What's new
  • Multiselect tool to move several elements to a folder or delete them.
Improvements
  • The histogram of an index is displayed by default.
Changes
  • The units in which a project is displayed by default are the same as those in which it was processed.
