- Pix4D Documentation
- PIX4Dcapture (legacy product)
- Getting Started / User Manuals / Special Install
Free Flight Mission Settings (iOS) - PIX4Dcapture
Access: In the
Home screen, select
Free Flight. In the
Map view, tap
OPTION
DESCRIPTION
White balance
Defines the white balance to apply between Auto (default), Sunny and Cloudy.
Information: It allows to compensate temperatures so that the color of the image is as close as possible to neutral which corresponds to sunlight at noon outdoor. For each image the temperature is adjusted by an algorithm that optimizes the colors.
The Reset all settings button makes all options revert to their default values.
