OPTION | DESCRIPTION |
Angle of the camera (°) - Except Bebop 2 |
Defines the tilt (not pan) of the camera between 0°, horizontal, and 90° (default), vertical. The default value is vertical but if it was changed previously, the angle is the one of the last planned mission. |
Front overlap (%) |
Defines the image front overlap between 20% and 90% (1% intervals). Default value is 80%. For more information about how to set the overlap: Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > a. Selecting the Image Acquisition Plan Type. |
Side overlap (%) |
Defines the image side overlap between 20% and 90% (1% intervals). Default value is 70%. For more information about how to set the overlap: Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > a. Selecting the Image Acquisition Plan Type. |
Look at grid's center |
Defines whether the drone should be oriented towards the center of the mission when taking pictures, Yes, or not, No (default). The point of interest should be the middle of the area to map. |
Picture trigger mode |
Defines how pictures are triggered between stopping to shoot, Safe mode, or while the drone is flying, Fast mode (default). |
Drone speed |
Defines the drone's speed from a range between Slow and Fast (default). The maximum speed depends on the selected overlap and flight altitude. The scale has five levels corresponding to percentages of the maximum speed between 100% (Fast) and 60% (Slow). The speed should fluctuate between 2 and 8 m/s for copters and is not constant during the flight since the drone slows down to trigger pictures. |
White balance - Except Bebop 2 |
Defines the white balance to apply between Auto (default), Sunny and Cloudy. |
Ignore homepoint |
Defines whether the maximum authorized distance (2 km) between the home point and the flight plan is applied, No (default), or ignored, Yes, to start the mission. |
The Reset all settings button makes all options revert to their default values.
hello i installed pix4dmapper on my pc, i used polygon
but the DSN ORTHOMOSAIC AND INDEX is not working
