OPTION | DESCRIPTION |
Drone | |
Drone |
Selects the drone to fly. For more information: (Android, iOS) Which drones are supported by Pix4Dcapture. |
Camera |
Selects the camera mounted on the drone. For more information: (Android, iOS) Which drones are supported by Pix4Dcapture. |
General settings | |
Map |
Opens a pop-up to select and manage alternative street and satellite basemap providers. |
Units |
Selects between Meter or Feet. The default selection depends on the geolocation of the device. |
Auto download images when mission ends |
Defines whether the mission is synchronized right after the flight, Switched on (default), or manually by the user later, Switched off. For more information: (iOS) How to synchronize and upload a mission to the cloud. |
Upload resolution |
Select between Half or Full (default). Defines the resolution of the images to upload and process on the cloud. |
Flying in China |
Improves the geolocation of images if flying in China only, Switched on, otherwise it should not be activated, Switched off (default). To use with caution. |
About |
Opens a sub-menu with information about the Privacy policy (Pix4D main site) and App version. |
hi,
where i can see or adjust the rtk settings in pix4dcapture ios version?
Hi Kai,
There are no RTK settings available on the iOS version of Pix4Dcapture. Then you won't be able to make any adjustments for it from our application. The RTK settings can probably be adjusted form the native drone application.
Best,
hi gael,
if i understand correctly, there is no possibility in pix4d (ios version) to see if rtk is active or not active ?
so i have to switch between the drone application and pix4d (ios) like in ctrl+dji and pix4d (android) for rtk settings ?
best,
Hi Kai,
My previous answer may have been confusing. Actually, the P4P RTK is not officially supported by Pix4Dcapture so we can not guarantee that it will work using it. It means that we did not test it with our application and in this way, we don't recommend using it.
Best,
Hi ,
When I use Pix4d Capture for aerial mapping, there is an error. I can't see the map clearly. It's cloudy. So I can't create a flight plan well. How can I solve it.
Thank
Hello, Kyaw,
The default basemap provider for Pix4Dcapture is Mapbox and it can be limited in some areas where indeed you will see clouds or it won't be up to date. Note that only the basemap provider is responsible for this and you have the ability on Pix4Dcapture to set another basemap provider or even add a custom one. I suggest you read the procedure here.
Best,
Hi, I'm having trouble connecting the dji air to pix4capture using iPhone 7. I have installed the dji 4 go, program the mission and after starting does not connect, in the checklist drone information not connected. In the dji go it takes off. someone can help me. thanks
Hi Filipe,
The behavior you are describing has not been reported to us so far. As a first step, I would suggest you go through all the basic checks and troubleshooting steps as it will solve most of the issues that can be encountered if properly followed.
You should not run the DJI 4 Go app in the background while running the Pix4Dcapture app. You have to close it so that there won't be conflict during the connection process.
Regards,
Buenas noches gracias por su atención, me podria indicar como cargar un KML O UN KMZ en la aplicación para los iphone ya que para programar varios vuelos es necesario en un mismo proyecto.
Como hago varios planes de vuelo en un mismo proyecto en los iphones
gracias por su atencion.
Hello,
You can't upload the KML/KMZ file on the iOS version of the Pix4Dcapture app. This feature is only available on the android version of Pix4Dcapture.
Regards,
Gracias por su atención, y cual opción se debe aplicar para programar misiones en un área que no se puede definir en terreno, como programo mas de una misión para cubrir mas área con varias misiones
