技術リリースノート(Android) -PIX4Dcatch
Download the latest version for android.
バージョン1.30.0
| バージョン | Release Date | リリースタイプ |
| 1.30.0 | October 20th, 2025 | 改善点 |
What’s new:
- Handled organization Access-Control Lists (ACL) for member roles when logging in, opening the account dialog, or uploading to PIX4Dcloud.
バージョン1.29.0
| 1.29.0 | September 18th, 2025 | Updates, Improvements, Bug fixes |
- Improved login security with OAuth2 redirect and app link verification.
- Optimized for the latest Android versions (support for Android 16).
- Updated demo project URLs.
- General bug fixes and performance improvements.
Versions 1.28
| 1.28.0 | April 16th, 2025 | General improvements |
| 1.28.1 | May 6th, 2025 | Bug Fixes |
1.28.1
What's new
- Bug Fixes
1.28.0
What's new
- General improvements
1.27.3
| 1.27.3 | May 23th, 2024 | Bug Fixes |
What's new
- Bug Fixes
バージョン1.27.2
| 1.27.2 | February 19th, 2024 | Bug Fixes |
What's new:
- Fix minor application bugs.
バージョン1.27
What's new:
- Fix issue of having corrupted projects when opening the detailed view.
What's new:
- Automatic Tag Detection of GCPs during capture using unique ID encoded Targets.
- Add geoids: GEOIDE-Ar16 and PL-geoid-2021.
- Show mesh in the camera feed during capture (Beta).
- Show warning message when the device is heating.
- Improve viDoc connection stability.
- General bug fixes & UI improvements.
バージョン1.26
What's new:
- Ability to edit GCPs description.
- Ability to access the secured shared links when opening the project in PIX4Dcloud.
- Add geoids: TWGEOID2018h, FIN2000, FIN2005N00 and LV14.
Bug fixes & Improvements
- Improve the upload speed.
- Refresh the projects faster.
- GCPの精度が負の値になるのを防ぐ。
- Fix issue of not able to logout.
- Fix viDoc NTRIP & laser measurements.
- Enhance depth points presentation in the live preview.
バージョン1.25
What's new:
- Display the depth points in live preview with less noise.
- Save detailed info for the point collection with GCP marking, in one file, available when exporting projects.
- Show previously selected CRS when creating new point collections.
- Improve handling projects states when switching accounts.
- Improve dialog details when failed to connect to NTRIP.
- Show better information dialog when there are no enough credits.
- Better permission failure dialogs handling when trying to upload projects.
- Fix issue of showing GCPs with specific CRSs wrongly on the map.
- Fix crashes while capturing, uploading projects and when opening the demo project.
バージョン1.24
What's new:
- Fix issue of not able to upload to PIX4Dcloud or export with some valid Pix4D licenses.
バージョン1.24.0
What's new
- Available in French, German, Simplified & Traditional Chinese languages.
- Display the file format before importing GCPs & show the file name in the app.
- Add report PDF file containing capture screenshot
- Fix crashes when connecting to viDoc RTK & when receiving NMEA messages.
- Enhance viDoc connection workflow.
- Fix crashes in detailed view and upload dialog.
バージョン1.23
What's new
- Achieve increased accuracy by including GCPs when processing projects:
- Import points as GCPs.
- Easily mark GCPs in images.
- Upload & process with marks to PIX4Dcloud or export to PIX4Dmatic.
- Ability to login to & check the organizations the user belongs to.
- Support for German (GCG2016) & Slovenian (SLO-VRP2016/Koper) geoids.
- Allow users with PIX4Dmatic license to export a site localization.
- The onboarding slides are available in Japanese and Spanish.
- Fix lagging before and while capturing.
- Fix issue of having the project cameras clustered.
- Fix issue of not having the buttons properly working on Pixel and Samsung.
- Fix issue of not showing the point cloud in the saving report on devices that doesn’t support depth.
- Fix issue of disconnecting the RTK when canceling the settings dialog.
- Fix issue of updating only the last 10 remote projects status.
- Fix issue of having multi projects upload failure when uploading before having the projects remote state updated.
- Persist Antenna Offset & Laser On / Off status for each GCP collection separately
- Better login failure dialogs handling.
- Enhance ArCore tracking by placing the anchors in front of the cameras.
- Various bug fixes & UI improvements.
Version 1.22
What's new
- Allow user to unselect satellites constellation.
- Improve RTK connection workflow.
- Improve RTK projects geolocation.
- Fix NTRIP connection issues.
- Fix issues of turning on the viDoc laser without measuring points.
- Fix issues when uploading projects to PIX4Dcloud<.>
- Fix crash when exporting project from the detailed view.
- Fix crash when opening demo project.
- UI improvements for the RTK info panel.
- Various UI fixes.
Version 1.21
What's new
- Available in Spanish language.
- Show VDOP & satellite count in the RTK panel.
- Show GPS accuracies in the GPS panel.
- Ability to manually refresh the projects list.
- New detailed info file for point collections available on export.
- Add RTK tag in the detailed view.
- Improve handling PIX4Dcloud projects states.
- Improve overlap triggering.
- Fix for device pose triggering.
- Fix various issues when uploading multiple projects.
- Bug fixes & UI improvements.
Version 1.20
What's new
- Reduce time for saving/opening projects.
- Display optimal accuracy in the details tab for viDoc RTK projects.
- Add an option to specify the minimum elevation for viDoc RTK.
- Improve point cloud, by default, in GLTF format.
- Improve project details view performance.
- Fix an issue of having projects saved with no images.
- Fix an issue of having corrupted images.
- Fix crashes when connecting to viDoc RTK.
- Fix crashes after uploading projects.
バージョン1.19
バージョン1.19.1
不具合の修正
- Fix crash when connecting to viDoc RTK rover with french language keyboard.
バージョン1.19.0
What's new
- Show a report with estimated accuracies at the end of capture and in the project detailed view.
- Show Site Localization point names in PIX4Dcloud.
- Reconnect to viDoc after internet loss.
- Ability to request account deletion.
- Improve live view depth points presentation.
- Fix issue with importing projected CRS.
- Fix offset values after viDoc disconnection.
- Fixes for multiple projects upload.
- Many bug and UI fixes.
Version 1.18
What's new
- Improved viDoc stability and accuracy for large projects.
- Better warnings handling during capture.
- Add a progress bar when saving projects.
- Fix viDoc laser measurements.
- Fix issues when resuming a project uploaded to a site.
- Fix issues when uploading multiple projects.
- 複数のプロジェクトをアップロードする際、通知の許可を求める。
Version 1.17
What's new
- Assign a site localization to Point CRS collection:
- Measure points & get their coordinates in the assigned site CRS.
- Remove the assigned site localization.
- Residuals & RMS can be viewed for localized sites.
- Option to filter points.
- Show a progress bar when saving projects.
- Prevent viDoc RTK from being stuck in Autonomous or DGNSS Only.
- Improved stability when measuring & exporting GCPs.
- Fix login issues.
- Fix GCP info units & labels.
- Fixed crashes & UI improvements.
Version 1.16
What's new
- Added Site Localization functionality.
- Create a site localization point collection to compute and define a custom coordinate system.
- Import local points with an undefined coordinate system or global points with a geographic coordinate system.
- Link local and global points.
- Upload and process a site-localized project on PIX4Dcloud.
- Export site localization WKT2 file.
- Export local and global points from the site localization point collection in two separate CSV files.
- Various small bug fixes & UI improvements.
Version 1.15
What's new
- Ability to enter geoid height.
- Added geoids: 'CGG2013a' and 'arcgp-2006-sk'.
- Added 'SVD2006', 'CGVD2013a(2002)' and 'CGVD2013a(1997)' vertical coordinate reference systems.
- Fix crashes when capturing.
- Fixed the issue of having wrong vertical accuracy for GCP measurements.
- Allow the user to access the height measurement over an ellipsoid.
- Various UI improvements.
Version 1.14
What's new
- Available in the Japanese language.
- Compatible with Android 13 devices.
- Added geoids: 'RAF20', 'RAF18b', 'hBG18', 'OSGM15'
- Ability to extend notifications
Version 1.13
What's new
- GCP (Ground Control Point) measurement:
- Laser functionality with viDoc RTK
- Add reference images to a single-point measurement
- Clearer warning messages
- Added Poland geoid 'PL-geoid-2011'.
- Save NTRIP credentials before connecting to viDoc.
- Show 3 digits for viDoc accuracies.
- Improved viDoc accuracy & Bluetooth lost detection.
- Fix having a corrupted login state.
- Fix issues related to opening big projects.
- Fix the issue of not being able to select different vertical CRS & geoids.
- UI improvements.
Version 1.12
What's new
- Support for GCP (Ground Control Point) measurement.
- Measure single points using viDoc RTK. *Laser functionality coming*
- Export GCP collections as CSV to include a PIX4Dmatic compatible file.
- viDoc RTK rover connection improvements.
Version 1.11
What's new
- Support for viDoc RTK rover.
- Able to capture in Portrait mode.
- Search bar and project number added to the projects view.
不具合の修正
- Improve captured point cloud.
- Improve image triggering and performance during capture.
- Many UI improvements and bug fixes.
Version 1.10
What's new
- Improved warnings during capture.
- Improved authentication workflow.
不具合の修正
- Fix issues when uploading to PIX4Dcloud.
- Fix crash and issues when canceling an upload.
- Fix issue of not being able to load sites in multi-projects upload.
- Fix issues when opening large projects in the detailed view.
- Fix issues related to the demo project.
バージョン1.9
バージョン1.9.1
不具合の修正
- Stability improvements.
バージョン1.9.0
What's new
- Improve demo project download.
- 大規模なデータ取得の場合、取得した点群データをより詳細に表示します。
- Add Auto-rotate functionality in the live preview top-view mode.
不具合の修正
- Ability to manipulate smoothly the 3D View when the cameras are shown.
- Improvements in the upload to PIX4Dcloud workflow.
Version 1.8
What's new
- Demo project available in the projects folder.
- Ability to rotate phone upside down (180 degrees).
- Availability to use geoid GSIGEO2011.
不具合の修正
- Fixed issue showing the disclaimer page after logout.
- Fixed issue of not being able to pass the disclaimer page on tablets.
- Update geoids.
- Many bug fixes and improvements.
バージョン1.7
バージョン1.7.1
What's new
- Allow unlimited processing for valid PIX4Dcloud Advanced trial licenses.
バージョン1.7.0
What's new
- Show feature points in live preview view for non-supported depth devices.
- Improve 3D viewer visualization.
- App usage disclaimer.
不具合の修正
Version 1.6
What's new
- 複数のプロジェクトをPIX4Dcloudにアップロードします。
- Continues to upload when the app is in the background.
- Project upload progress bar.
- Show resume percentage tag for partially uploaded projects.
- Improve display of image locations on the map.
- Enhance upload failure messages.
不具合の修正
- App can be used without Location Services
- Fixed issues when using multiple accounts in the app.
- Fix crashes.
バージョン1.5
What's new
- New default processing pipeline used when uploading to PIX4Dcloud
- Option to process with the classic PIX4Dmapper pipeline
- Ability to view third-party license info from the account dialog
不具合の修正
- Alert when illegal characters are used to rename projects when uploading to PIX4Dcloud
- Show loading dialog when opening the project details
- Fixed crashes and improvements
Version 1.4
What's new
- Show Imperial or Metric units based on the system locale
- When upload fails, a dialog explaining the reason appears
不具合の修正
- Fix crashes when sending app to background
- Fix issue of not showing the Delete button when multiple projects are selected
- Fix crashes when exporting data while the device is low on resources
Version 1.3
What's new
- Display the PIX4Dcloud processed 3D-model in the project 3D-view
- Ability to save logs, rename & delete a project from the detailed view
- Display the percentage towards completion when uploading to PIX4Dcloud
不具合の修正
- Fix issue of having corrupted images on some devices
- Fix issue of showing the wrong image after selection
- Show live preview data after it was hidden
- Fix occasional crashes while saving and opening projects
Version 1.2
What's new
- Live -preview:
- Show 3D preview of the scene captured in real-time
- Show the location of images in the live preview
- Toggle between a top view and synchronized camera views Visualize & export the 3D model
- 3D view in the project details that render the depth points & the images
- Export the point cloud in PLY format
- Other updates:
- Display information, storage used & maps of the project
不具合の修正
- Solved corrupted zipped files for large capture
- Solved lagging in overlap trigger mode
Versions 1.1
バージョン1.1.4
What's new
- The ability for any PIX4D account user to export a project to a photogrammetry software such as PIX4Dmatic
バージョン1.1.3
What's new
- Ability to view, pan, and zoom images in the detailed project view
- Ability to delete images
- Ability to show image information
- Default trigger setting is set to 90% overlap
- Reframing of the text in the upload dialog to make it more understandable
- Ability to receive notifications
不具合の修正
- Fixed crash when accepting permissions at the first start of the app
- Fixed autofocus option not being applied
バージョン1.1.2
What's new
- Ability to change a project name on save
- Ability to cancel a current capture session
不具合の修正
- Fixed issue of not able to download the app from play store, on many devices, due to depth API support
バージョン1.1.1
不具合の修正
- Fixed issue of not being able to create a trial license for some users
- Fixed issue of having incorrect altitude in some image metadata
バージョン1.1.0
What's new
- Ability to choose image overlap trigger from the settings during data capture
- Enhanced visualization technique to improve the experience of data capture
- More feature points are shown during data capture
- Ability to filter projects by the mean of tabs in the projects view
- Ability to save log files from the projects view
Bugs fixes
- Fixed crash when getting network state on Galaxy tab
- Fixed issue when exporting projects on Xiaomi
- Fixed issue of login to PIX4D from Chrome browser
バージョン1.0
バージョン1.0.3
不具合の修正
- Add a check if "Google Play Services for AR" is not installed and redirect to Google Play Store for installation
バージョン1.0.2
What's new
- Ability to select multiple projects to discard them
- Ability to rename projects
- Ability to export a project while offline
- Automatic selection of a newly created site
- Other minor improvements to the user interface
不具合の修正
- Fixed issues when performing volume calculations for high-resolution GSDs
- Fixed an issue where project files were uploaded multiple times
- Fixed the ability to re-upload a project when it is deleted on PIX4Dcloud
- Fixed crash at startup when GPS is updating
バージョン1.0.1
What's new
- 不具合の修正
バージョン1.0.0
PIX4Dcatch is the tool for acquiring optimal ground images for photogrammetry. These ground images can be used to get highly accurate 3D models on or offline within PIX4Dmapper (free 15-day trial available, then a valid subscription is required).
No need to be an expert. Walk around your area of interest and the app will record pictures along the way, together with GPS positions. Images can be uploaded to PIX4Dcloud for the fast generation of scaled and georeferenced 3D models and point clouds that you can visualize, measure, share, and export. Or they can be exported locally for processing in PIX4Dmapper.
Workflow
- Scan: Walk around the area of interest. PIX4Dcatch automatically records geotagged frames and displays on your screen real-time 3D meshing for scene completion feedback.
- Upload: Stop recording and automatically upload images to PIX4Dcloud to generate accurate and easy to share 3D models (requires a PIX4Dcloud subscription - free 15 day trial available).
- Export: Or export: transfer the images from your device to your desktop computer and start the photogrammetry process, add GCPs and validate the accuracy of your 3D scene with PIX4Dmapper (requires a PIX4Dmapper subscription-free 15-day trial available)
- Examine: Measure distances, areas, and volumes, and perform virtual inspections.
- Share: Selectively and securely share project data and insights with your team, clients, and suppliers. Devices compatibility:
Device compatibility:
- All ARCore enabled devices.
Usage information
- Ensure the app is up to date. Upload the images to PIX4Dcloud to generate, visualize, measure, and share your 3D model.
- PIX4D accepts no liability for damage, injuries, or legalities from the misuse of this app. Use only in safe environments.
