  • 検索フィールドが空のため、提案はありません。
FAQ - PIX4Dfields
本記事では
一般
What is PIX4Dfields?
How does PIX4Dfields work?
Does PIX4Dfields have access to satellite images?
Is PIX4Dfields available for macOS and Windows?
What hardware specifications do you need to run PIX4Dfields?
Can I use PIX4Dfields with no internet connection?
What is the difference between a map generated in PIX4Dmapper and PIX4Dfields?
What is the geometric accuracy of PIX4Dfields?
What is the difference between the digital surface model (DSM) generated in PIX4Dfields and PIX4Dmapper?
Does PIX4Dfields include the same radiometric correction module as PIX4Dmapper?
License/payment
How do I try PIX4Dfields?
How do I change from a trial to a paid license?
How do I activate/redeem my license key?
How do I transfer my license to a different laptop/device/computer?
How to cancel my subscription?
Cannot purchase or renew a license/ Why has my payment failed?
How many computers can be used with the same account?
What is the price and type of licenses for PIX4Dfields?
Are there any bundle offers available for PIX4Dfields?
Inputs
Can I import as-applied maps to PIX4Dfields?
Are the inputs and outputs of PIX4Dfields compatible with other Pix4D software?
Which cameras are supported in PIX4Dfields?
Are there any demo data sets I can use to test PIX4Dfields?
Does PIX4Dfields support Ground Control Points (GCPs)?
Can PIX4Dfields process oblique imagery?
What is the recommended flight pattern?
What is the recommended flight altitude in PIX4DFields?
My map doesn’t look great. Why?
The DSM values seem wrong. What elevation is PIX4Dfields using?
Does PIX4Dfields process thermal imagery?
In zonation, how do you decide if the zones are significantly different from each other?
What is the default coordinate system in PIX4Dfields?
Outputs
Can I create a report of my outputs in PIX4Dfields?
Can I upload PIX4Dfields layers to a farm management system?
Is the export functionality limited for trial licenses?
What are the requirements to Share to PIX4Dcloud?
Does PIX4Dfields translate/convert acres to hectares? How do I change the units?
Can I use an external drive to store projects in PIX4Dfields?
Features
Does PIX4Dfields have any key shortcuts?
Can I search for an address or a GPS location?
Support and Technical Details
Activation file, Activation request file - Offline license activation
How can I get technical support for PIX4Dfields?
How to follow up on the Support tickets created?
Future Development
Automatic plant counting
General Information
PIX4Dfields is a product of PIX4D. An advanced agriculture mapping software for aerial crop analysis and digital farming.
The official PIX4Dfields main page is: https://www.pix4d.com/product/pix4dfields/
To download the latest version of PIX4Dfields visit https://www.pix4d.com/download-software/
PIX4Dfields applies a fast, direct-to-orthomosaic photogrammetry workflow optimized for smooth terrain, enabling rapid map generation and immediate field analysis using a laptop. Since version 1.11, an “accurate” processing mode is also available, producing more detailed height models and orthomosaics. While this option increases processing time, it is ideal for applications requiring higher precision, such as trial plots and terrain analysis.
Access to the Sentinel 2 satellite has been introduced since PIX4Dfields 2.0. For more information, see Satellite data in PIX4Dfields.
Yes, PIX4Dfields is available for both macOS and Windows.
There are recommended hardware and software requirements to use PIX4Dfields, see: Computer requirements.
Yes, PIX4Dfields is specifically designed to convert images into high-resolution maps, with no cloud or internet connection required. However, note that before using it on a new computer you will need to activate your license. While connected to the internet, log in to your Pix4D account (or create a new one) and select a license so that you can use PIX4Dfields. The software will store this license on your computer until it expires, so you can work offline.
PIX4Dmapper takes fine-grained local variations in altitude into account when building maps, whereas PIX4Dfields is optimized for representing terrain, using a coarser ground model. If you have a lot of 3D structure in your maps, PIX4Dmapper will give more accurate results for the areas with the 3D structure. However, PIX4Dfields will still give good results on any surrounding terrain.
Beginning with PIX4Dfields 1.11, an accurate processing option was introduced. This option generates a highly detailed height model along with a more accurate orthomosaic. This is ideal for trial plots, spot applications, and terrain analysis.
It depends on the dataset, see What is the difference between a map generated in PIX4Dmapper and PIX4Dfields?. PIX4Dfields' fast processing performs relatively well on the ground. However, on buildings and other structures above the ground, the accurate processing option is recommended. This option will generate a highly detailed height model along with a more accurate orthomosaic.
Absolute accuracy: On terrain features, the accuracy is 1-3 x the average GSD, or the GPS accuracy of the camera, whichever is larger.
Relative accuracy: On terrain features, the accuracy is 1-3 x the average GSD of the output orthomosaic.
While both digital surface models (DSMs) are outputs generated with Pix4D software, each is more specific to the industry the software is created for. With the DSM generated in PIX4Dmapper, you can get the accurate elevation value of each pixel, with or without above-ground objects, ready for your preferred GIS workflow. DSMs generated in PIX4Dfields capture terrain well but are less accurate in representing buildings and other vertical structures. They are a useful tool when addressing irrigation variability and pinpointing erosion-prone areas, but are not intended for high-resolution usage. The absolute altitude of the DSM generated in PIX4Dfields will depend on the quality of the GPS information from the image acquisition. Please see Processing options to fully understand the difference between fast and accurate processing
Both products use the same radiometric correction module to correct individual input images. PIX4Dfields uses a different (faster) method to stitch the images into an orthomosaic. For more information: Radiometric correction in PIX4Dfields.
License and payments
You can explore PIX4Dfields for 15 days for free with limited export functionality.
  • Existing PIX4D users: Download PIX4Dfields from the download page. By logging in with your existing credentials you will be able to test PIX4Dfields for free.
  • New PIX4D users: To create a PIX4D user account go to the sign-up page. Upon completion, you will be redirected to the PIX4Dfields download page where you can download the software and demo datasets.
If a paid license was purchased and assigned to the same Pix4D account, log out and log in again to PIX4Dfields and select the new paid license.
First, ensure there is a Pix4D account. If not, create an account following the Sign up instructions. Then, to redeem a License key or a Voucher code:
  1. Go to the redemption page. If prompted, log in with the credentials of the Pix4D account to which the license or Pix4D credits should be attached or the credentials of the organization's owner.
  2. Enter the license key received in the PDF License certificate or the Voucher code present on the flyer. Make sure you are logged in with the correct Pix4D account.
  3. Click Redeem.
For more information: License key.
There is no need to "transfer" your Pix4Dfields license to another computer. If the processing device has changed or the license should be used on a different computer:
  1. Log Out: First, log out of the Pix4Dfields application on the current computer. This will free up the license seat.
  2. Install and Log In: Install Pix4Dfields on the new computer and log in using your Pix4D account credentials.
    Note that projects stay in the device that was used for processing.
How to cancel the subscription plan?
 The subscription plan can be canceled or edited at any time. Canceling the plan means deactivating the auto-renewal option and the associated billing.  For more information: How to cancel the subscription plan
If you are encountering issues purchasing or renewing a license through our e-commerce portal, there are a few items to check before proceeding. The following articles highlight a few of the most common solutions to aid the payment process:
Managing the payment method information
Each PIX4Dfields license is linked to a PIX4D account. PIX4Dfields can run on one computer at a time, but the license is floating and can be used to log in on any number of computers.
What is the price and type of licenses of PIX4Dfields?
PIX4Dfields is offered with monthly, yearly, three-year, and One-Time Charge (OTC) licenses. For more information: PIX4Dfields pricing.
We frequently offer exclusive bundles with some of our camera and drone partners. For more information, Contact sales.
Inputs
Are the inputs and outputs of PIX4Dfields compatible with other PIX4D software?
Yes, it is possible to import the exports from PIX4Dmapper (and other software) into PIX4Dfields and vice versa.
Yes, applications and as-applied maps can be imported into PIX4Dfields. The required format depends on the file type. For shapefiles, it is essential that a .prj file is included to identify the coordinate reference system (CRS). This file is sometimes missing from John Deere exports; however, it can be added within QQGIS. It is also advised to simplify the geometry by following: Too many polygons error - R0177- PIX4Dfields
PIX4Dfields processes RGB images, multispectral images, and the thermal bands of the Altum and the Sentera 6x cameras. A list with a sample of the supported cameras and the complete database can be found here: PIX4Dfields supported cameras.
Note: If an RGB or multispectral camera is not supported in PIX4Dfields, it is still possible to process the dataset if a file with the internal camera parameters is provided. For more information: Your camera is not supported at this time - PIX4Dfields.
Yes, the example datasets can be downloaded from the dashboard once you have activated a license. The datasets can also be downloaded from Example projects for PIX4Dfields.
Does PIX4Dfields support ground control points (GCPs)?
PIX4Dfields does not support the use of ground control points (GCPs) because it relies on RTK (Real-Time Kinematic) positioning, which is typically sufficient for most agricultural applications. However, if you require enhanced accuracy and reconstruction using GCPs, we recommend utilizing PIX4Dmatic for processing RGB images or PIX4Dmapper for processing multispectral images...
PIX4Dfields supports processing nadir images captured with a drone camera pointing straight down. We recommend using PIX4Dmatic to process oblique images.
For agricultural purposes, a single grid is recommended. We suggest avoiding double grid flights. For more information: How to capture drone images for PIX4Dfields.
Assuming a relatively flat scene, a flight altitude between 60 and 100m normally gives good results. We do not recommend low-altitude flights (5-20m) as they may introduce artifacts into the orthomosaic. Please also keep in mind the legal flight altitude at your location.
Factors such as low overlap, reflective surfaces in the area (water or glass), or large areas of the same color or texture (snow or sky) can affect the quality of your map. Please contact Support if you encounter such issues. We can identify the cause and provide some recommendations for your future flights.
For more information: Stitching artifacts - PIX4Dfields
Note: PIX4Dfields recommends at least 85% frontal and 70% side overlap. For dense forest vegetation areas, it is recommended to increase the overlap to at least 85% frontal and side overlap and fly higher so that it is easier to detect similarities between overlapping images
PIX4Dfields uses the elevation tagged in the images and does not apply any conversion. Elevation will depend on the GPS of the drone and can refer to the ellipsoidal height or a geoid model.
PIX4Dfields can only process the thermal bands of the Micanse Altum and Sentera 6x cameras. PIX4Dfields can process .jpg thermal imagery, but they will be treated as RGB images, and the resulting orthomosaic is a colored-mapped of temperatures and contains only a visual representation of the temperature instead of the raw values
PIX4Dfields Targeted Operations Zonation provides several options to choose the optimal number of zones. The zones are based on clustering regions with similar values together.
What is the default coordinate reference system in PIX4Dfields?
The default coordinate system is the corresponding Universal Transverse Mercator (UTM) zone (datum WGS84, EPSG 4326). Changing the input or output CoordinateReferenceSystem (CRS) of the files within PIX4Dfields is impossible.
Outputs
You can create a PDF report of your outputs. To do so go to the export button in your top bar and once in the Export panel simply select the export type to be PDF report. Then include all the outputs you would like to display in the PDF report and hit export.
It is possible to export zonation & prescription maps to a tractor terminal for variable rate fertilizer application as a shapefile. For more information: How to export a variable application rate map to a tractor terminal.
It is possible to upload files directly to John Deere Op. Center.
Note: PIX4Dfields outputs such as Orthomosaics, Digital Surface Model, and Index maps are exported as a GeoTIFF file. See PIX4Dfields inputs and outputs. Different Farm Management Systems support GeoTIFF files. Please refer to your Farm Management System about their supported formats.
Yes, the export functionality is available only for commercial licenses. Therefore, during the trial period, it is not possible to export the results of PIX4Dfields. For more information about commercial licenses, contact sales.
A paid (commercial) license is needed (i.e. not Trial) with valid S&U. An additional PIX4Dcloud license is not needed to use the Share to PIX4Dcloud option.vFor more information: Share to PIX4Dcloud - PIX4Dfields
Should I upload PIX4Dfields files to DJI Smart Farm?
PIX4Dfields generates prescription maps and boundary files that are directly compatible with DJI Agras T-series drones, allowing you to bypass the need for DJI Smart Farm entirely.
The only file DJI Smart Farm accepts is an external .tiff prescription. Go to Custom prescription and click Upload Prescription Map.
It is not recommended to use an external USB storage drive or network drive, as it may cause instability or crashing.
To use an external drive to store projects in PIX4Dfields:
1. Open PIX4Dfields.
2. Click on the Settings menu.
3. Navigate to the Data storage folder section.
4. Here, you can change the data storage location by selecting your external drive as the new destination for your project data.
Please remember to make sure that your external drive is properly connected to your computer and that it has enough space to store your projects.
Features
PIX4Dfields currently does not offer any keyboard shortcuts that utilize key combinations.
 To change the measurement units in PIX4Dfields, follow these steps:
1. Access Settings: Open PIX4Dfields and navigate to the settings menu at the top-right.
2. Locate Units: This section allows you to configure how measurements are displayed.
Yes, you can search for an address or GPS coordinates by using the location icon. icon to locate adress or gps location
When visiting the licensing page, there is Offline license activation tab, that asks for an Activation request file. This feature is not available in PIX4Dfields, please ignore it.
Future Development - Add your feature request!
PIX4Dfields will develop, grow, and implement new features specifically based on user feedback. With this constant development, you can expect updates in our software that will translate into better decision-making for agriculture. You can provide feedback on the product and share your feature requests in our PIX4Dfields Feature Request page.
After you open/create a support request using our contact support form, you will receive a confirmation email to your license email to confirm the receipt. No confirmation is sent to the email you designated as "Cc".
To inquire about the status of a request or to follow up if you have not received a response from a support agent, reply to the confirmation email or any other email of a specific conversation.
Pix4D customers with valid support & upgrades and trial holders: For technical questions, contact our support team. After engaging with the Pixie chatbot, simply select the option to create a support ticket. https://www.pix4d.com/support/.
Not a customer yet? For technical questions, post on the Pix4D Community or contact sales
A plant counting algorithm is in development. While the release date has not been set, you are welcome to contact us if you wish to participate in testing by sharing your imagery. After engaging with the Pixie chatbot, simply select the option to create a support ticket. https://www.pix4d.com/support/. Manual counting with multi-point annotations enables users to count and classify plants, trees, or objects by color.  For more details, see the article at https://support.pix4d.com/hc/en-us/articles/3600428292028
