Import failed - R0032: Project had errors while trying to import its content - PIX4Dfields
Error
"R0032: Project 'Name of the Project' had errors while trying to import its content. Please check that the project was not already imported with a different name.
Description
Error when importing a PIX4Dfields project (.p4f ) into another account that already exists on the same device.
Cause
After processing a project in PIX4Dfields, the data is stored on the device storage in a folder called Data storage folder. The Data storage folder is usually located in C:\Users\...\PIX4Dfields.
If a project was processed on PIX4Dfields, the data is stored on the device storage. Therefore, if you use another PIX4Dfields account, but the same machine, you will get the message, “Please check that the project was not already imported with a different name”.
Solution
1. Export the project.
2. Log out from account A.
3. Log in with account B.
4. Select another location for the Data Storage Folder.
5. After changing the Data Storage Folder, close PIX4Dfields
6. Double click the.p4f
7. The files and data of the project will be imported to the new account, and save into the new Data storage folder.
To open those previous projects, select the corresponding data storage folder.
For more information: This project has missing data - "R0117: The selected item has missing data"
