  • 検索フィールドが空のため、提案はありません。
Technical release notes - PIX4Dreact
Current Version 1.6
Version Release date Release type Installers
1.6.1
March 4th, 2026 Fix/Improvements Download page
1.6.0
June 13th, 2025 New Features,  Improvements, Bug fixes Windows   Mac
Version 1.6.1
Bug fixes
  • Zurich processing and storage cluster location: Share to Cloud works correctly for that PIX4Dcloud location.
  • Fixed a crash that occurred when opening the file explorer from within the application, which was caused by recent Microsoft 365 updates.
Version 1.6.0
New Features
  • Location search: Search by name, ZIP code, or GPS coordinates.
  • Batch map export & import: Export and import multiple maps simultaneously.
  • Native Apple silicon support: Optimized processing speeds on Apple M-series CPUs. MACs with an Intel CPU are no longer supported.
  • New language support:
    • Czech
    • Hungarian
    • Romanian
  • Changed the base map provider to MapTiler.
Improvements
  • Better camera compatibility: Unsupported cameras can now be processed if correct EXIF tags are present.
  • New camera support:
    • DJI Mini 3
    • DJI Matrice 4E
    • DJI Matrice 4T (wide RGB)
    • DJI Zenmuse L1 (RGB)
    • ソニー ILX-LR1
    • Sentera 6X Thermal Pro (RGB and Thermal)
  • Improved support for Skydio X10.
  • Capture time for each map visible on the dashboard.
  • Maps are sorted by the capture time by default.
  • Added "Label size" setting to snapshot export.
  • Added “Count” markers (MultiPoint)
Bug fixes
  • Fixed exporting log files when processing fails.
Versions 1.51
1.5.1 June 27th, 2024 Improvements Windows   Mac
1.5.0 August 31st, 2023 New Features, Improvements Windows   Mac
Version 1.51.1
Improvements
  • Support for Skydio X10/X10D.
  • Support for DJI Mavic 2 Enterprise Dual.
  • Support for Mavic 2 Enterprise.
  • Support for DJI M30.
  • Support for DJI Mini 4 Pro.
  • Support for DJI Mini 2.
  • Support for DJI Air 3.
  • Support for DJI M30 (RGB).
  • Support for Wingtra A6100.
  • Support for Wingtra RGB61.
  • Support for Sentera 65R.
Version 1.5.0
New Features
  • High-resolution snapshots: Export the current view of the map or the full map, including any markers, as a high-resolution JPEG, e.g., for large-format printing.
  • Share to PIX4Dcloud: Support for uploading markers.
  • Option to display coordinates in degrees, minutes, and seconds (DMS).
  • Clickable zoom buttons.
  • Holes and sub-polygons for area markers.
Improvements
  • Support for DJI Mavic 3T (RGB, Thermal)
  • Support for DJI H20T (Thermal)
  • Support for DJI Mavic 2 Ent. Advanced (Thermal)
  • Support for DJI Mini 3 Pro.
  • Support for MAPIR Survey3W RGB.
  • Support for XAG M500 RGB.
Versions 1.4
1.4.3 November 9th, 2022 Improvements Windows  Mac
1.4.2 June 29th, 2022 Improvements Windows  Mac
1.4.1 December 15, 2021 Fix/Improvements
1.4.0 November 4th, 2021 New, bug fix
 Version 1.4.3
Improvements
  • Support for DJI M30T (RGB, Wide).
  • Support for DJI Mavic 3 Enterprise.
  • Support for DJI H20T (RGB, Wide).
  • Support for DJI Air 2.
  • Support for ACSL Soten.
  • Support for Autel EVO II V3.
Version 1.4.2
Improvements
  • Support for DJI AIR 2S.
  • Support for DJI Mavic 3.
  • Support for Sony Alpha 7R IV (FE 24mm F2.8 G lens).
  • Support for Skydio X2 (RGB Only).
Version 1.4.1
Fix/Improvements
  • Fixed an issue where the processed map looked blue for some GPU models under some conditions.
  • Support for DJI Mavic 2 Enterprise Advanced (RGB only)
Version 1.4.0
New
  • Upload outputs (ortho, surface model) directly to PIX4Dcloud for sharing.
  • GPU acceleration to reduce processing time.
  • Now available in Ukrainian.
  • Layer export menu with option to scale output size and option to include overviews for faster opening of the output in a third-party GIS solution.
  • Export menu redesign.
Fix/Improvement
  • Importing a project now displays a progress bar.
  • Custom basemaps now display when exporting a snapshot or PDF report.
  • Markers now correctly export the “name” value.
  • Improved marker line measurement accuracy.
Versions 1.3
1.3.0 April 21, 2021 New, bug fix. Windows  Mac
Version 1.3.0
New
  • Customize the PDF report with your own logo and contact details.
  • US National Grid map overlay with the ability to jump to a specific cell by either USNG code or GPS coordinates.
  • Number of markers for each map visible on the dashboard.
  • Now available in French, Italian, Korean and Russian.
  • Redesigned menu for managing markers and the ability to import markers from a shapefile.
  • Ability to switch the base map from within a project. Select either satellite, street, none or custom (when set).
Versions 1.2
1.2.0 September 17, 2020 New, bug fix
Versions 1.2.0
New
  • Selectable color for markers (point, line, area).
  • Improved look and feel of markers.
  • Set a custom basemap via URL (tiled web map format).
  • Export markers as shapefiles.
  • Available on macOS (10.15 and above).
  • Support for new cameras: Skydio 2.
  • Additional languages: Chinese and Portuguese.
Fix/Improvement
  • Increased maximum zoom level to support very high-resolution maps.
  • JPEG (screenshot) export now correctly exports elevation model if selected.
  • Improved PDF report export speed and stability.
Versions 1.1
1.1.3 July 1st, 2020 New, Known issues
1.1.2 May 28, 2020 Bug fix
1.1.1 March 17, 2020 Bug fix
1.1.0 February 18, 2020 New, bug fix
Version 1.1.3
New
  • Support for Autel EVO II Pro camera
  • Support for Autel EVO II Dual camera (RGB only)
  • Support for DJI Zenmuse XT2 camera (RGB only)
Known issues
Exporting an elevation model as a screenshot gives as output the orthomosaic.
Version 1.1.2
New
  • Support for Autel EVO I camera.
  • Support for Autel EVO II 8K camera.
  • Suppor for Zenmuse X7 (35mm lens) camera.
  • Support for Parrot Anafi Thermal camera (RGB only).
Fix
  • Essential update to allow continued functionality of the default basemap.
  • Processing fixes and extended camera support.
Version 1.1.1
Improvements
  • Login/logout not possible in some instances.
  • Satellite basemap did not display in some instances.
Version 1.1.0
New
  • Ability to switch language between English, German, Japanese and Spanish.
  • Import images by selecting a folder.
Improvements
  • RGB orthomosaics sometimes generated large files.
  • Tool buttons did not display with some screen resolutions.
  • Text did not show correctly on some computers.
  • App did not start for certain old graphic card drivers.
Versions 1.0
1.0.1 December 3, 2019 New, bug fix
1.0.0 October 23, 2019 Initial release
Version 1.0.1
New
  • Support for the DJI Mavic 2 Enterprise Dual drone (RGB only).
Note: This drone generates both a low and a high resolution version of each image. When importing the images in Pix4Dreact, a warning message will be displayed. This message appears, because Pix4Dreact does not support the processing of the low resolution images. Click PROCESS to continue and allow the software to process the high resolution images.
 Improvements
  • Regular updates include stability and minor bug fixes.
 Version 1.0.0
Pix4Dreact is a new fast-mapping software built for emergency response and public safety. Pix4Dreact creates 2D maps from aerial imagery which provide up-to-date and reliable information in the field.
  • Fast and accurate maps while in the field.
  • Orthomosaic generation from drone images with no internet connection or cloud processing required (internet connection is only required during the first software activation).
  • Measurement and Marker tools.
  • Import and Export functionality.
  • PDF report for fast evaluation of the results and sharing with other stakeholders.
