English
  • 検索欄が空のため、提案はありません。
PIX4Dcatch PIX4DRTKデバイスPIX4Dcatch 接続する
A PIX4D-supported RTK device is a GNSS receiver that enables PIX4Dcatch to geolocate images with centimeter-level accuracy. Correct connection and configuration are essential to ensure accurate results. This article explains how to connect a mobile device to a PIX4D-supported RTK device and configure the RTK parameters.
Initialize Connection
Before initializing the connection:
  • Ensure that Bluetooth is enabled on the mobile device.
  • Power on the PIX4D-supported RTK device with a long press and wait until it is ready.
  • PIX4Dcatchを開きます。
At the top-left corner of the screen, tap the GPS signal indicator and select RTK via Bluetooth.
         RTKカード
The RTK Device Settings dialog opens. Select Import or Create RTK Profile as required. For information about the RTK profile template, click here.
     Connect rtk (2)
Set Camera Offset Values
When connecting a PIX4D-supported RTK device to a mobile device, define the offset between the antenna and the camera (also known as the camera offset).
PIX4Dcatch automatically recognizes offset values for known combinations of mobile devices and supported RTK devices. If the offset is unknown, it must be manually entered in the Camera Offset Values (X, Y, Z) fields. If these values are zero, the offset has not been recognized and must be manually configured.
       rtk catalog
NTRIP Credentials
NTRIP Settings
NTRIP (Networked Transport of RTCM via Internet Protocol) streams real-time correction data from a base station to the rover to achieve centimeter-level accuracy.
NTRIP configuration includes:
    • NTRIP Credentials
    • Mountpoint Selection
    • Input Coordinate Reference System (CRS)
NTRIP Credentials
Enter the following details under NTRIP Settings:
  • Hostname / IP (IP is preferred when available)
  • Port Number
  • Username
  • Password
Select Validate NTRIP to confirm the connection.
         ntrip
Important: The device clock must be synchronized for NTRIP communication to function correctly.
  • iPhone or iPad: Go to Settings > General > Date &Time > toggle on Set Automatically.
  • Android: go to Settings > General management > Date &Time > toggle on Automatic date and time.
Select Mountpoint
After validation, the Mountpoint screen becomes active. Select the preferred GNSS correction source. Depending on the CORS network, this can be a single base station or a triangulated network of nearby stations.
    Tip: Contact the NTRIP provider for details on available mountpoints.
    Mountpoint Options
    Mountpoint Options
    説明
    Nearest | Net | VRS
    • Nearest: Single Base RTK corrections for the nearest station.
    • Net: Average of the three nearest base stations.
    • VRS: Virtual base created from nearby stations.
    MSM
    Multiple Signal Messages (RTCM 3.2 correction format).
    RTCM
    Standard correction format by RTCM.
    • RTCM 2.3: GPS Only
    • RTCM 3.1: GPS + GLONASS
    • RTCM 3.2: GPS (including L5) + GLONASS + Galileo + BDS
    CMR
    Trimble correction format.
    • CMR: GPS Only
    • CMR+: GPS + GLONASS
    • CMRx: compressed format (GPS L5 + GLONASS + Galileo + BDS)
    iMAX
    Leica network correction format using a real reference station for consistency and traceability.
    Select NTRIP CRS
    1. Go to Input Coordinate Reference system.
    2. Tap select NTRIP Coordinate system.
    3. Search for the desired CRS (only geographic coordinate systems are available).
    4. Select the CRS.
    5. A green checkmarkVector confirms a successful selection.
    CRS PLAN
    crs
    Commonly Used NTRIP CRS Options
    We compiled a list of coordinate reference systems commonly used for broadcasting NTRIP corrections from various regions.
    国または地域
    Coordinate reference system
    Europe
    ETRS 89 (EPSG: 4258)
    United States
    NAD83(2011) (EPSG: 6318)
    日本
    JGD2011 (EPSG:6668)
    シンガポール
    SVY21 (EPSG:4757)
    Note: Refer to  Which geoids are compatible with PIX4Dcatch for supported geoid models.
    Next Steps
    Once the RTK device connection and configuration are complete, proceed to Capture a project with PIX4Dcatch to begin collectin data and measuring points.
