English
  • 検索欄が空のため、提案はありません。
PIX4D RTKデバイスの取り付けと設定 - viDoc
Important: Vidoc is no longer distributed by Pix4D.
To effectively use a Pix4D supported RTK device with a mobile device, the initial step is configuring the setup correctly. This involves setting the camera offset between the antenna and the mobile device's camera. This offset, whether measured automatically by PIX4Dcatch (SPC and SPC+) or manually by the user, is crucial for accurately computing locations captured by Pix4D supported RTK devices, ensuring precise measurements for scans or ground control points (GCPs).
Which Version of viDoc distributed by Pix4D do I have?
Currently, the Pix4D supported RTK devices has different versions that require different offset values: viDoc distributed by Pix4D compatible with SPC+ connector (Pix4D supported RTK devices P01) and viDoc distributed by Pix4D compatible with SPC connector. This section describes how to identify the Pix4D supported RTK devices version, in order to set the correct camera offset values and achieve the best available accuracy of the reconstruction.
Important: The list of compatible iOS mobile devices with SPC/SPC+ connectors and viDoc distributed by Pix4D models is available here.
重要: バージョン1.28.0以降のAndroidではRTK デバイスはサポートされていません。RTKの販売代理店にお問い合わせください。
If you bought the RTK device through Pix4D, please Contact Support
Smartphone type with SPC+ connector
Since SP Connect released a new version of their adapter called SPC+, Pix4D released Pix4D supported RTK devices P01, a new version of the viDoc distributed by Pix4D RTK device that is now compatible with the new SPC+ cases. This device version is indicated by the additional Pix4D logo and the rounded shape of the new SPC+ mount type. Manual offset measurement is only needed in the following situations:
  • PIX4Dcatch does not recognise the device
  • A custom case is used
P01 label extension
Connector on Pix4D supported RTK devices
Connector on the SPC+ case
Smartphone type with SPC connector
This Pix4D supported RTK devices version is compatible with the old SPC cases and can be recognized easily by the rectangular mount type and the black label without the Pix4D logo. Manual offset measurement is only needed in the following situations:
  • SPC universal case is used
Connector on the SPC case
Mount the viDoc distributed by Pix4D to the Device
Pix4D 販売するviDocはPix4D PIX4Dcatch モバイル端末で撮影した画像PIX4Dcatch センチメートル単位の精度PIX4Dcatch するGNSS RTK受信機Pix4D 。Pix4D が販売するviDocPix4D デバイスは、SP Connectが提供するSPコネクタ(ケースまたはクランプ)を使用して、スマートフォンや タブレットと接続することができます。
Note: The SP connectors can be obtained when purchasing the viDoc distributed by Pix4D RTK device. They can also be purchased directly from SP Connect and most electronic, bicycle, and motorcycle shops. Refer to the manufacturer's instructions for further details when mounting for the first time.
Important: After mounting the viDoc distributed by Pix4D to the mobile device, please check if the camera offset has been automatically calculated for you. If your mount is not available in this list, you need to measure the camera offset manually. For more information: Manually Measure Camera Offset
スマートフォンの機種
First, insert the phone into its compatible SP-connect case. Then, mount the case to the RTK device by following the instructions provided with the SP-connect case.
Important: Ensure proper orientation of the mobile device after mounting it to the viDoc distributed by Pix4D with the antenna pointing up.
Device type
Orientation
iPhone
Portrait
iPad
Landscape
Tablet model
Compatible SP-Connect Case:
Insert the tablet into the suitable SP-connect case. After that, secure the case to the RTK device by following the guidelines provided with the SP-connect case, ensure the table is in landscape mode
Holder with clamp:
Loosen the screw on the bottom of the viDoc distributed by Pix4D, and carefully insert the tablet into the clamp. Use the iPad's magnets to center the viDoc distributed by Pix4D. Tighten the screw to secure the tablet, and ensure that the tablet is in landscape mode.
Devices with a Known Camera Offset
This list contains the combinations of mobile devices (phones and tablets) with the Pix4D supported RTK devices where the camera offsets are already measured. PIX4Dcatch will automatically fill in the X, Y, Z fields with the correct camera offset values.
スマートフォンの機種
Compatibility with the case type
[iPhone]
SPC
SPC+
iPhone 15 Pro Max
iPhone 15 Pro
iPhone 14 Pro Max
iPhone 14 Pro
iPhone 13 Pro Max
iPhone 13 Pro
iPhone 12 Pro Max
iPhone 12 Pro
iPhone 11 Pro Max
iPhone 11 Pro
iPhone XR
* Warning: This configuration is not recommended due to partial camera sensor occlusion.
Tablet model
[iPad]
SPC
SPC+
iPad Pro 12.9-inch (4th, 5th and 6th generation)
iPad Pro 11-inch (2nd, 3rd and 4th generation)
Important: If the Pix4D supported RTK devices is not mounted with an SP-connect case, then offset values need to be measured manually, as described below. In PIX4Dcatch, there is an option to overwrite the autodetected values with the manually measured ones.
カメラのオフセット測定
When initiating the connection to the Pix4D supported RTK devices, the dialog RTK Device Settings opens. The section Camera Offset allows the user to set the X, Y, Z offset values properly. The available options depend on the combination of the viDoc distributed by Pix4D RTK device version, the mobile device and the device case. The following options are available: SPC, SPC+ (in tablet and older mobile app versions: Automatic) and Custom.
The options SPC and SPC+ are only available if the combinations of the viDoc distributed by Pix4D RTK device version, the mobile device and the device case are known. The option Custom is always available and intended to be used by universal or specific cases. This option requires measuring the camera offsets manually and setting them in PIX4Dcatch. The camera offset value selection is saved for the next measurements and modifications are only needed if the setup changes.
カメラのオフセットを手動で測定する方法
PIX4Dcatch_RTK__measure_z_offset_IPHONE_.jpgPIX4Dcatch_RTK__measure_z_offset_IPAD_.jpg
適切なSP-connectケースを使用して、本デバイスをPix4D デバイスに取り付けてください。スマートフォンケースは、SP-connectのウェブサイトから別途購入できます。対応するモデルがない場合は、SP-connectのユニバーサルスマートフォンマウントをご利用いただけます。SP-connectのケースは、ほとんどの自転車店やバイクショップでも取り扱っています。
Place the device in landscape mode and the display to the front. Notate the orientation of the X, Y, and Z axes and how they relate to the point of origin on the antenna to measure from. The point of origin resides in the middle of the screw mount at the base of the antenna. It will also be necessary to determine which lens to measure from for devices with multiple camera lenses.
Important: If you use iPad, make sure the device is in landscape mode and the antenna is pointing upwards, like in the image above. The X and Y offset values will need to be entered as negative values.
Tip: If you don't know which camera lens to measure from, start PIX4Dcatch and then place something in front of each camera lens. The lens blocked is the appropriate lens to measure from.
重要: When using the universal mount, the lens and device must be below the antenna when mounting the device to the viDoc distributed by Pix4D.
PIX4Dcatch_Android_RTK_x_Not_Above_origin.jpg PIX4Dcatch_Android_RTK_check_Not_Above_origin.jpg
Measure the X axis (Y axis for iPad)
Measure the value from the antenna base to the center of the lens along the axis for the X axis offset.
PIX4Dcatch Android RTK measure x offset diagram
Measure the Y axis (X axis for iPad)
Measure the value from the center of the antenna to the center of the lens along the axis for the Y axis offset.
PIX4Dcatch Android RTK measure y offset diagram
Z軸を測定する
Z軸のオフセットを測定するには、アンテナの中心からレンズの中心までの深さを測定してください。
PIX4Dcatch Android RTK measure z offset diagram
Important: Most cases and adaptors are adding extra offset on top of the screen. Make sure that Z axis offset is measured to the lens and not the case/adaptor.
カメラのオフセット値を入力してください
カメラのオフセット値を正確に測定して記録したら、RTKデバイス設定ダイアログの適切な「カメラオフセット値」フィールドに入力 できます。デバイスの地域設定に応じて、表示される単位はセンチメートルまたはインチになります。
Important: Ensure that camera offset values are defined in the correct measurement units. Setting the unit is available under the General settings -> Language & Region -> Measurement system.
The camera offset is now properly set in the Camera Offset Values X, Y, Z fields. Continue with the RTK Device Settings dialog to complete the viDoc distributed by Pix4D RTK connection to the device.
