Troubleshooting PIX4Dcloud Processing Errors
This article outlines common processing errors encountered in PIX4Dcloud and related applications (e.g., PIX4Dcatch, PIX4Dmatic, PIX4Dcloud Enterprise with API access). It includes the root causes of each error and recommended solutions.
IN THIS ARTICLE:
Error 10002 – An unexpected error occurred
Error 10003 – Processing exceeded available resources
Error 10101 – Failed to create cameras
Error 10410 – Processing failed
Error 10411 – Failed to densify sparse point cloud
Error 10501 – 3D textured mesh generation failed
Error 10601 – The input data is not valid
Error 10611 – The selected output coordinate system is not isometric
Error 10612 – The selected output coordinate system is not projected or arbitrary
Error 10613 – An output CRS cannot be defined without a horizontal CRS component
Error 10614 – A geoid model or geoid height cannot be specified without a CRS vertical component
Error 10615 – A geoid height cannot be specified with a geoid model
Licenses: This information is valid for PIX4Dcloud Starter and PIX4Dcloud Pro licenses.
Roles: If the dataset fails prematurely, only the user who processed it receives an email with a copy of the log file. If processing fails after the calibration step has started, the log file is also accessible in the Results tab of the dataset. Only Editors and above roles can process and access the Results tab of the dataset.
Warning: If the problem is related to the display of the outputs and not the processing (the outputs are generated, but something in the display doesn't work, or no email is sent as error notification). For more information, Output is not displayed / feature is missing in the cloud.
Description: This generic error often indicates issues related to dataset configuration or processing limitations.
Possible causes:
The processing took more than 72 hours to complete.
Oblique images were used with a nadir processing template that lacks a defined region of interest.
The selected processing options could not be handled efficiently with the available resources.
The output coordinate reference system (CRS) is incompatible with the input data.
Projects from the Japanese version of PIX4Dcatch are more likely to experience this issue. In these cases, the point cloud is often split into multiple disconnected blocks, while other outputs attempt to combine into a single file.
- Dataset name contains unsupported characters such as 親, ת, ę, ž, ^, ' , ; etc.
Recommended actions:
Use a processing template that matches the type of images (nadir or oblique).
Include a region of interest if oblique images are used.
Check and reduce processing complexity where possible.
Review and adjust the output coordinate system to ensure compatibility with input data.
- If the project was uploaded from PIX4Dmapper or PIX4Dmatic to be processed in PIX4Dcloud, then try choosing at least one of the following options:
- Reducing the number of images. Sometimes, there are flying modes in some drones that capture more images than necessary to cover the area, or sometimes, the images cover a larger area, and some of them can be skipped.
- Ensuring the strictly necessary outputs are marked for their generation.
- Defining a processing area.
Description: The project could not be processed due to insufficient system resources.
Optimize processing settings by reducing image resolution, number of images, or complexity of outputs.
Root cause: Corrupted or incompatible image metadata.
Possible causes:
Image files have been edited.
Image format is unsupported.
Ensure images are unaltered and in a supported format before upload.
Root cause: Calibration quality issues.
Verify that the image quality is sufficient. For more information, How to verify that the Image Quality is sufficient.
- Verify that there is enough overlap between the images. For more information: How to verify that there is enough overlap between the images.
- Verify that the image geolocation, output coordinate system, and Ground Control Points / Check Points coordinate system are correct. Learn How to verify all of the coordinate systems in PIX4Dcloud.
Information: It is also recommended to review the Quality Report that is usually available in the email that is sent after the process has finished.
To analyze the Quality report, see this article.
Root cause: A fragmented dense point cloud.
Ensure the dense point cloud consists of a single, cohesive block before mesh generation.
Description: One or more input elements are invalid or improperly configured.
Verify the dataset and input parameters. Reupload if necessary.
Select a valid isometric coordinate system that maintains uniform scale in all directions.
Choose a valid projected or arbitrary coordinate system.
Instructions by product:
PIX4Dcloud: New dataset > Processing options > Output coordinate system
PIX4Dcatch: Output Coordinate Reference System
PIX4Dmatic: Project coordinate system
PIX4Dcloud Enterprise with API access: Project coordinate system
Use a CRS that includes a horizontal component.
Reference documentation:
PIX4Dcloud: How to define a project coordinate system in PIX4Dcloud or
New dataset > Processing options > Output coordinate system - PIX4Dcloud
PIX4Dcatch: Output Coordinate Reference System - PIX4Dcatch
PIX4Dmatic: Project coordinate system - PIX4Dmatic
PIX4Dcloud Enterprise with API access: Project Coordinate system.
Either remove the geoid model or specify a vertical CRS component.
PIX4Dcloud: New dataset > Processing options > Output coordinate system or
How to define a project coordinate system in PIX4Dcloud -
PIX4Dmatic: How to use vertical coordinate systems and geoids - PIX4Dmatic
Remove the geoid height or use a matching geoid model within the CRS definition.
PIX4Dcloud: New dataset > Processing options > Output coordinate system - PIX4Dcloud
Note: When working across platforms (PIX4Dcloud, PIX4Dcatch, PIX4Dmatic, PIX4Dcloud Enterprise with API access), ensure consistent and valid CRS configurations to avoid processing failures.
