2D/3D output is missing / functionality is not available - PIX4Dcloud
This article serves as a troubleshooter for cases when an output is missing from the 2D/3D view or when a functionality is not enabled on PIX4Dcloud / PIX4Dcloud Pro.
The missing output is:
Orthomosaic and/or DSM
Point cloud
3D Textured Mesh
The unavailable functionality is:
3D view
Virtual inspector
Elevation profile
Volume calculation
Share button is not visible in the dataset
Timeline / Cannot add a dataset to a site
DXF design overlay
Licenses: Note that in this article some features are only available with PIX4Dcloud Pro licenses.
Roles:
- Only Owners, Managers, and Editors can process a dataset in PIX4Dcloud.
- Viewing the functionalities in a dataset is available to Owners, Managers, Editors, and Readers.
Error description: The Orthomosaic and/or DSM processing appears to have failed, or the output is completely missing from the project.Cause / How to solve: The output may not have been selected in the list of outputs to be generated before starting the processing step. Users frequently assume this is a bug, but it is often simply unselected prior to processing.
- Verify your processing template and options to ensure the required outputs are enabled.
- For PIX4Dcloud processing: Check the processing template settings when creating the project to ensure Orthomosaic and DSM generation are selected.
- For PIX4Dmapper uploads: Go to Process > Processing Options... > 3. DSM, Orthomosaic and Index and verify the specific format boxes (e.g., GeoTIFF) are checked. See more in, After uploading from PIX4Dmapper to PIX4Dcloud for processing.
- If the output was missing from the selection, enable the required output checkboxes and re-process the project. (Note: Reprocessing will consume additional credits).
Point cloud
Error description: The Point Cloud processing appears to have failed, or the output is completely missing from the 3D view.Cause / How to solve: The Point Cloud may not have been selected in the list of outputs to be generated before starting the processing step. Users frequently assume this is a bug, but it is often simply unselected prior to processing.
- For PIX4Dcloud processing: Check the processing template settings when creating the project to ensure Point Cloud generation is selected.
- For PIX4Dmapper uploads: Go to Process > Processing Options... > 2. Point Cloud and Mesh and verify the Point Cloud format boxes (e.g., LAS) are checked.
3D Textured Mesh
Error description: The 3D Textured Mesh processing appears to have failed, or the output is completely missing from the 3D view.Cause / How to solve: The 3D Textured Mesh may not have been selected in the list of outputs to be generated before starting the processing step. Users frequently assume this is a bug, but it is often simply unselected prior to processing.
- For PIX4Dcloud processing: Check the processing template settings when creating the project to ensure 3D Textured Mesh generation is selected.
- For PIX4Dmapper uploads: Go to Process > Processing Options... > 2. Point Cloud and Mesh > 3D Textured Mesh and verify the "Generate 3D Textured Mesh" box is checked.
3D view
- Error description 1: The Point Cloud and 3D Textured Mesh are uploaded as results, and they are not aligned.
- Cause / How to solve:
The mesh (.obj, .jpg and .mtl) uploaded as a result to the Cloud is indeed not georeferenced. In all of the PIX4D processes, a file called offset.xyz is always generated together with the mesh files and is used to place it in the right location
If the 3D mesh is not coming from a PIX4D process, that file has to be created manually, otherwise, PIX4Dcloud will not be able to locate the 3D mesh in the right position.
- Error description 2: The 3D view doesn't render.
- Cause / How to solve: It is necessary that the web browser application supports optimized WebGL for rendering 3D graphics. This is a known issue for some iOS devices. For more information: ArcGIS help, Sketchfab help.
Virtual inspector
- Error description : When selecting the Inspect tool, the following message appears on the right panel: "The Virtual Inspector is not available. Make sure the project was processed in the cloud".
The Virtual Inspector is only available under these conditions:
- The project has been processed on PIX4Dcloud (that excludes projects created by uploading results).
- The project has been computed with PIX4Dmatic and the results have been uploaded to the cloud, and the original images have also been uploaded.
- The project has been created with PIX4Dmatic and it has been uploaded to cloud for processing.
- The project images were not captured using a fisheye lens camera (e.g. Bebop 2, GoPro).
Elevation profile
- Error description: The elevation profile is missing / doesn't work.
The project does not have a DSM.
- Error description: After clicking Calculate volume still spinning for a log time
- You clicked Calculate volume before the dataset status displayed "All changes saved".
- The base volume is not aligned with the DSM.
Volume calculation
- Error description: The volume computation is not available.
Timeline / Cannot add a dataset to a site (Only PIX4Dcloud Pro)
- Error description: The timeline is not displayed at the top of the project / I cannot add a CAD overlay / I cannot add a dataset from inside my project.
The dataset is not assigned to a site yet.
Assign the dataset to a site first. Then, the timeline, the overlay layer and the Add dataset option will appear in the project view.
Design overlay (Only PIX4Dcloud Pro)
- Error description: DXF is not visible in 2D viewer.
One of these might be the reason:- DXF shifted with respect to the orthomosaic in the 2D viewer because the project and the DXF are in different coordinate systems.
- DXF with incorrect scale.
- DXF with incorrect rotation.
Warning:
- The DXF is expected to be in the same coordinate system as the project, otherwise it will not be aligned with the orthomosaic, DSM, point cloud and 3D mesh.
- The DXF is a very complex format that contains many different type of elements. Some of them may not be supported and will not be displayed.
Note that Editors and Readers roles cannot share a dataset with other users.
