How to define a project coordinate reference system in PIX4Dcloud
This article explains the different ways to define a project coordinate reference system in PIX4Dcloud, depending on whether the project is created by processing images, uploading existing outputs, or manually configuring an empty or non-georeferenced project. Correctly defining the coordinate reference system ensures proper alignment, accurate measurements, and consistent visualization across datasets.
Project coordinate reference system when processing images
Project coordinate reference system when uploading outputs
Manual project coordinate reference system definition
Choosing the correct workflow to define the project coordinate reference system
Licenses: This article is valid for PIX4Dcloud Starter and PIX4Dcloud Pro licenses (formerly PIX4Dcloud Advanced).
Roles: Only Owners, Managers, and Editors can create and process datasets in PIX4Dcloud.
When images are processed in PIX4Dcloud, the project coordinate reference system is defined during Step 3 of the dataset creation wizard.
The coordinate reference system is selected in the Output coordinate reference system section. It is recommended to use the EPSG code to select the correct coordinate reference system.
PIX4Dcloud automatically proposes a default coordinate reference system based on the image geolocation, which is suitable for most use cases.
For more information, see: New dataset Processing options Output coordinate reference system - PIX4Dcloud.
For more information, AutoGCPs detection functionality - PIX4Dcloud Pro.
When a project is created in PIX4Dcloud only to visualize existing outputs (such as an orthomosaic, DSM, NDVI, point cloud, or 3D mesh), the project coordinate reference system is automatically defined by the first georeferenced output uploaded.
All subsequent outputs must use the same coordinate reference system.
Mixing outputs with different coordinate reference systems may result in misalignment.
For more information, see: New dataset Dataset creation Upload outputs - PIX4Dcloud.
A project coordinate reference system can be defined manually in the following cases:
The project is empty and no outputs have been uploaded.
The project contains outputs without an embedded coordinate reference system, such as:
IFC files
3D mesh files
Outputs missing CRS information (e.g. orthomosaic, DSM, NDVI, or point cloud without a defined coordinate reference system)
To manually define the project coordinate reference system:
In Drive, click New dataset.
Select Upload processed results.
Click Create to generate an empty project in PIX4Dcloud.
Click Set CRS to manually define the project coordinate reference system.
Information: Once the project coordinate reference system is manually defined, PIX4Dcloud expects all subsequently imported outputs and annotation files to be georeferenced in the same coordinate reference system.
The table below summarizes how the project coordinate reference system is defined in PIX4Dcloud based on how the project is created and which data is available.
| Project scenario | How the project is created | coordinate reference system definition | Notes |
| Images are processed directly in PIX4Dcloud | Upload images and start processing | Defined in Step 3 – Output coordinate reference system of the dataset creation wizard | A default coordinate reference system is automatically suggested based on image geolocation |
| Images are processed with GCPs (PIX4Dcloud Pro) | Upload images and GCPs and start processing | Defined by the GCP coordinate reference system | The output coordinate reference system must match the GCP coordinate reference system |
| Outputs are uploaded for visualization only | Upload processed outputs (no image processing) | Defined by the first georeferenced output uploaded | All uploaded outputs must use the same coordinate reference system |
| Outputs include files without CRS (e.g. OBJ, IFC) | Upload processed results | Must be manually defined before or during upload | Required when outputs do not contain embedded CRS information |
| Empty project (no images or outputs) | Create dataset → Upload processed results | Manually defined using Set CRS | Useful for preparing a project before uploading outputs |
| Mixed outputs with different CRS | Upload processed results | Not supported | All outputs must share the same coordinate reference system |
