How to edit the point cloud - PIX4Dmatic
Editing the point cloud helps clean the 3D model by reducing noise, enhancing precision, and improving visual rendering. This article explains in detail how to edit the point cloud in PIX4Dmatic.
Prerequisites
In PIX4Dmatic, the Calibration step must be completed before generating the point cloud. Once Calibration is successful, the Dense point cloud can be generated. The Depth point cloud and Depth & Dense Fusion steps are optional processing steps.
Point cloud tools
All the available point clouds are accessible in the Content panel. To display or hide all point clouds in bulk or individually click on the display icon (visibility). The settings icon settings next to each point cloud provides options to adjust the point size, select all points, or delete them.
Point clouds in the Content panel.
Selection tools
The following selection tools for the point cloud(s) are available (in 3D view):
Tool Keyboard shortcut Description
Simple selection S A single point is selected
Rectangle selection R All points inside the rectangle created will be selected
Polygon selection J All points inside the polygons  created will be selected
Object selection Y An object will be selected, based on machine learning algorithms
Color selection Shift+C All points with similar colors within the defined range and tolerance will be selected.
Edit tools
By using the selection tools, single or multiple points can be selected (highlighted in pink) and edited:
  • Assign to > Apply: Assign and classify the selected point(s) to any ASPRS class.
Tip: For more accurate selection enable the Select only > Point clouds. The selection tools apply only to the point cloud(s) and do not affect other elements such as geometries in layers, cameras, or tie points.
  • Right-click: Enables the context menu. The context menu allows for:
    • Invert selection: Reverses the current selection.
    • Disable point cloud points: Disables the selected points. The disable points are now listed in the Content panel. The setting icon settings allows the display of either All points or the Disabled only.  The toggle toggle_switch_on displays or hides the disabled points.
      disablepoints_1.75-1
Note:
  • To restore disabled points, use the Undo shortcut (Ctrl/Command +Z) immediately after disabling them or
  • Click on more_vertical-16and Restore all disabled points. If the project was captured using PIX4Dcatch is possible to restore points of Depth point cloud, Dense point cloud, and Depth & Dense point cloud.
  • The disabled points can be selected using selection tools.
