How to consolidate multiple Organizations into one Organization
Many companies end up with several Pix4D Organizations over time. One might be created for each employee, project, office or department. This article explains how to merge them into one central Organization, which this article calls the master Organization. In a single Organization, you manage all licenses, credits, resources and users in one place. For example, all employees of the same company or department can work in the same Organization.
 License: Applies to all users with an active PIX4D license.
Before you start
Moving to a single Organization takes some planning. Before you transfer anything, we recommend that you gather the following information for each Organization you want to merge:
  • Owner and Managers: who has the Owner and Manager roles in each Organization.
  • Licenses and credits: which licenses are active, when they expire, and how many credits are left.
  • Billing model: Transferred can only be performed under the Credits model.
  • Resources: which datasets, sites and folders must be kept, and which can be deleted.
  • Users: who needs access to the master Organization, and with which role.
Tip: Consolidating is a good opportunity to clean up. Delete datasets that are no longer needed before the transfer, and plan a folder structure for the master Organization (for example, one folder per department, team or customer).
Step 1: Define the master Organization
Decide which Organization will become the master Organization. This is the Organization that will hold all resources, licenses and credits in the end, and that all users will work in.
You have two options:
  • Use an existing Organization. This is usually the best option if one Organization already holds most of the licenses, resources or users, or if it already has the correct legal and billing details.
  • Create a new Organization. This is the best option if none of the existing Organizations is right for the whole company or department. For example, an existing Organization might be registered to an individual, or have the wrong legal name. For instructions, see How to create and delete an Organization.
Warning: For a Business-type Organization, the legal name cannot be changed after the Organization is created. Make sure that the legal name is correct before you click Create.
Note: The user who creates an Organization automatically gets the Owner role.
Step 2: Transfer resources to the master Organization
Next, transfer the datasets, sites and folders from each source Organization to the master Organization. For full instructions, see Resource transfer in PIX4Dcloud.
Requirements
Important: Check the following requirements before you start a transfer.
  • Roles: The user who does the transfer must be at least a Manager in the source Organization and at least an Editor in the master Organization. Users with the Member role cannot transfer resources between Organizations.
  • Organization membership: The user must belong to both Organizations and must have accepted the invitation to the master Organization.
  • Licenses: Both Organizations must have an active PIX4Dcloud license.
  • Access type: Only resources with Inherited access can be transferred. Resources with Direct access cannot be transferred.
  • Dataset status: Only processed datasets can be transferred. If any of the selected datasets is not processed, the whole transfer fails.
  • Billing model: Resources cannot be moved from an Organization that uses the Credits model to an Organization that uses the Allowance model.
 What happens after the transfer
Warning: Moving resources between Organizations removes all current access for all users. In the master Organization, access is then set by that Organization’s own user management and access permissions.
  • Existing share links stop working. Create and send new share links from the master Organization if needed.
  • The AWS cluster location where the project is stored does not change.
  • Depending on the license model, license allowances or credit balances may change.
The steps to transfer resources between organizations are explained in the following link: Resource transfer in PIX4Dcloud.
Step 3: Transfer licenses and credits
Licenses and credits cannot be transferred from the Organization portal. To move licenses and credits from the source Organizations to the master Organization, contact PIX4D Support.
Important:
  • Do not delete any source Organization until Support confirms that its licenses and credits have been transferred. Licenses and credits held by a deleted Organization cannot be recovered.
  • We recommend that you transfer the resources (Step 2) before you transfer the licenses. The resource transfer requires an active PIX4Dcloud license in both the source Organization and the master Organization.
Step 4: Review users, invitations and roles
When all licenses, credits and resources are in the master Organization, review who needs access to them. Users in the source Organizations do not get access to the master Organization automatically.
  1. In the master Organization, go to User Management.
  2. Click Invite people to invite each user who needs access to the licenses or resources.
  3. Give each user the role that fits their tasks, for example Manager, Editor, Reader or Member.
  4. Assign licenses to the users who need them.
  5. Check the access settings of the transferred folders, sites and datasets, and give access to the right users.
Note: Invitations expire after 15 days. Pending invitations are listed under User Management with the status Pending. Remind users to accept their invitation in time.
Note: A user can belong to several Organizations at the same time, with different roles in each. Accepting an invitation to the master Organization does not change the user’s roles in other Organizations.
For more information about roles, inviting users and assigning licenses, see Organization management.
Step 5: Delete the Organizations that are no longer needed
When everything is set up in the master Organization, we recommend that the Owners delete the Organizations that are no longer needed. This avoids confusion about which Organization to use. For instructions, see How to create and delete an Organization.
Warning: Deleting an Organization is permanent. After deletion, you can no longer access its PIX4Dcloud projects or the licenses it held.
Note: Only users with the Owner role can delete an Organization. Deleting an Organization does not delete the user accounts of its members.
