App Overview - PIX4Dcatch
This App Overview article explains each button, menu, and feature in PIX4Dcatch, helping you quickly understand the app layout.
Top of the screen
The top section of the capture screen provides real-time status updates on your location accuracy and manages connections to external GNSS/RTK devices.
        App View
  • Signal Quality Indicator: Displays GPS or RTK connection status and accuracy information, and provides the option to connect to RTK via Bluetooth.
Bottom of the Screen
The bottom navigation bar serves as the primary navigation hub, allowing you to seamlessly switch between capturing data, reviewing past projects, and accessing specialized surveying and augmented reality/GIS tools.
        App View_Bottom screen_cropped
Capture View
The Capture screen is the primary interface for starting scans.
        Capture view
  • Capture Button : Tap to start taking photos. Once active, a new bar appears with three buttons and an image counter to track the progress.
                 Group 2143
    • Pause: Stop capturing temporarily.
    • Save: Finish and store the project.
    • Cancel: Stop and discard the current scan.
  • Image Counter count icon : Displays the total number of photos captured.
  • Live Preview : Tap to see a real-time 3D view of the scan. Live data displays raw LiDAR data from the phone. Final results must be processed in PIX4Dmatic or PIX4Dcloud.
  • AnnotationButton (3) :  Allows you to add an annotation during the image capture process. For more information, visit Annotations - PIX4Dcatch.
  • Tools FAB4-1: Tap the menu icon (bottom right) to access Tag Detection for automatic marker identification, AR Points for visualizing known points, Measure for doing the measurement in real time, and AR mode for project visualization in the physical environment.
              PIX4Dcatch Tools
Projects View
The Projects view in PIX4Dcatch serves as your main hub for managing, viewing, and organizing captured data. It is divided into three primary tabs located at the top navigation bar: Local, PIX4Dcloud, and GIS Data.
Folder view_local
Local Projects Tab: The local tab stores and organizes all captured data for easy searching, filtering, and management. This view tracks the status of every scan and serves as the main hub for uploading and exporting files, as well as deleting projects.
    • Filter Dropdown:  By default, it displays All projects. You can tap the dropdown menu to filter your project list by status: Uploads, Collected, Processing, Processed, or All projects.
    • Select:  The Select button located at the top right of the Local tab enables bulk and individual project management. Tapping Select allows you to choose one or more local projects to perform the following actions.
      •  Upload / Multi-Upload: Upload single or multiple selected projects directly to PIX4Dcloud at once. For more information, visit Multi-Project Upload and Project Re-upload - PIX4Dcatch.
      • Delete: Remove single or multiple selected projects permanently from your device memory to free up storage.
      • Export: Export single or multiple project files to local storage, external drives, or third-party sharing services.
    • Map view Map View logo : Displays the project on a map view.
      • View All Projects center map: Tap the Center Map Icon to zoom out and fit all project pins on one screen.
      •  Locate Me Icon location map: Tap the Location Map Icon to center the map directly on the user’s current location.
      • Project Icon project icon:  Tap a Project Icon to view a pop-up with the project’s image, status, name, date, and photo count. It also displays icons for RTK/GPS, Autotags, and Annotations.
      • Live Location undefined-Jan-22-2026-10-06-13-0690-AM: Shows the user's live location on the map.
    • Search Projects search: Find projects using keywords.
    •  Project Card Quick Menu (⋮): Tap the three dots ⋮ on a project card or press and hold it to open the Manage project menu.
      Manage Projects
      •  Rename: Change the project name.
      •  Upload to PIX4Dcloud/Re-upload: Upload the dataset to PIX4Dcloud  or Re-upload the project, if it has already been processed on PIX4Dcloud.
      •  Export data for PIX4Dmatic (OPF): Save project files as a .zip archive for desktop processing in PIX4Dmatic.
      • Export Point Cloud : Export the point cloud collected by LiDAR or ToF sensors. It can be exported in .PLY and .GLTF formats.
      • Export Logs: Export log files documenting internal project processes—recommended immediately after any issue to avoid logs being overwritten.
      • Delete: Permanently deletes the project.
    • Project Detail: Tapping any project card opens its 3D View and detailed project workspace. The following task can be carried out using the Project.
       Project view_ 3Dview
      • Export option: Tap on the export icon _Trailing_button_2on the top right of the screen to view the following options.
        exportoption
        • Export Data for PIX4Dmatic(OPF): Export the complete project in OPF format for PIX4Dmatic. For more information, visit Using OPF from PIX4Dcatch to PIX4Dmatic.
        • Export  Point Cloud (PLY): Export the point cloud collected by LiDAR or ToF sensors.
        • Export Point Cloud (GLTF): Available only if a GLTF point cloud was generated for autotag optimization, volume calculation, or project recovery.
        • Export Logs: Export log files documenting internal project processes—recommended immediately after any issue to avoid logs being overwritten. For more information, visit How to export PIX4Dcatch project and application logs.
      • Manage Project: Tap on the ⋮ to manage the project.
        • Optimize: Optimize processes detected AutoTags on your device to calculate their exact 3D coordinates and refine the preview point cloud before export or cloud upload.
        • Re-upload as a new project: Allows the user to reupload the project as a new project and use a different processing option.
      • Status Badge: Displays current status—Captured, Processing, or Processed.
      •  Accuracy Indicator: Indicates whether GPS or RTK was used during acquisition.
      •  View Tab:
        •  3D View Tab: Visualizes the 3D point cloud collected via LiDAR or photogrammetry.
        •  Data Tab: Displays the details about the dataset, such as the created date, geolocation sources such as EmlidRX, MiniElf, GPS,  and the coordinate reference system.
      •  ToolsButton-1:
      • Start AR session: Launches an augmented reality viewing mode that overlays your captured 3D point cloud and mesh directly onto the physical environment in real time.
PIX4DCloud Projects: The PIX4Dcloud tab provides access to datasets stored within your PIX4Dcloud organization account.
              IMG_5868-portrait
  • Change OrganizationDropdown: Switch between different organizations if your account belongs to multiple teams.
  •  SearchFrame 2608806: Use the search bar to find specific projects, sites, or datasets by typing project names or relevant keywords.
  •  FilterFrame 2608805: Use the filter options to narrow down your view. You can sort and display your content by All, Sites, Folders, or Datasets to quickly navigate large project catalogs.
  •  Project: You can tap on any project to view it or select Start AR Session to project the 3D model into the physical environment using Augmented Reality.
GIS Data:  The GIS Data tab connects and integrates your ArcGIS Online account directly with PIX4Dcatch to access, search, and manage geospatial layers in the field. Logging in with your ArcGIS Online credentials allows you to load organizational feature layers, maps, and feature services. You can display these layers over your 2D project map or live camera view, and visualize the data in Augmented Reality.
        GIS Data
Survey Tab
The Survey tab enables single-point measurements, known as Ground Control Points (GCPs). This tab stores all previous collections and allows you to create new ones. On the right, toggle between a list view and a map view to see the distribution of points.
                             Surveytab
    • Delete  Collection/ Point:  Press and hold the collection to open a pop-up menu that lets you delete the collection.
                                renameti
Account
Tap the User icon to log in, to view available cloud credits, manage capturing settings, and configure app preferences.
                        Account
    • Account  Details:   View the associated account email, organization name, and available credits. Tap the organization name to view its details or switch to a different organization. You can also see who owns the PIX4Dcatch Pro license, request account deletion, and manage your privacy preferences.
    • Integrations: Allows you to integrate the PIX4Dcatch app with third-party software such as ArcGIS Online.
    • Settings: Adjust image triggers and overlap, toggle AR display lines or labels, and create a new RTK profile to connect to your RTK  rover with correct camera offset and NTRIP credentials. For more information visit, Settings - PIX4Dcatch.
    • Others: Access settings restrictions, the latest feature updates, help resources, and app version details.
