PIX4Dcloud processing options in PIX4Dcatch
Projects captured with PIX4Dcatch can be uploaded to PIX4Dcloud Pro or PIX4Dcloud Starter with selectable processing outputs and coordinate reference systems.
Processing options
Project credits
3D Models
Elevation Models (GeoTIFF)
Settings
Processing options
Once a project has been captured and saved, it can be uploaded to PIX4Dcloud by tapping the Upload button.![]()
The initial Upload Project screen defines:
- Dataset name.
- Account and Organization.
- Upload location.
- Metadata (Date created, size, and number of images).
- Dataset Record (optional note).
- Included Points (Annotations).
Tap Next step to display the processing options. These options include:
- Project credits.
- 3D Models (Point Cloud).
- Mesh.
- Gaussian Splatting.
- Elevation models (DSM, Orthomosaic).
- Settings (Coordinate System and Region of Interest).
Project credits
This section displays:
- Credits required to process the project.
- Basic processing options
When enabling Gaussian Splatting output, the credits required to process a project are the sum of those for both basic processing options and Gaussian splatting.
- Credits currently available in the account.
3D Models
The 3D Models processing options let you configure which 3D outputs and file formats are generated from your capture data.
Point Cloud:
Generates a dense 3D point cloud from your capture data. Two formats are available:
LAZ (Always included): A compressed version of the LAS format that reduces file size without data loss. Ideal for efficiently storing and transferring large LiDAR datasets.
SLPK (Optional): SLPK files are optimized for efficient visualization of 3D datasets, including point clouds and meshes, in ArcGIS Online and ArcGIS Pro.
Mesh:
Generates a textured 3D surface mesh. Two formats are available:
OBJ (Always included): Included by default. A standard format for 3D geometry and textures compatible with most 3D modeling and CAD software
SLPK (Optional): Scene Layer Package files optimized for smooth rendering and efficient visualization of 3D textured meshes in ArcGIS Online and ArcGIS Pro.
Gaussian Splatting
Generates a Gaussian Splatting model using the acquired images. For more information: Using PIX4Dcatch to generate a Gaussian Splat model.
The Elevation Model processing options generate 2D geospatial outputs that represent terrain height and aerial imagery from your capture data.
DSM:
A digital surface model (DSM) includes all the above-ground features such as vegetation and buildings.
Orthomosaic:
Produces an orthorectified imagery layer using advanced photogrammetric corrections.
Settings
Output Coordinate Reference System:
The processed datasets may be georeferenced using one of the following options:
- Auto Detected: Automatically assigns the CRS based on the UTM zone associated with the mobile device’s position.
- Known CRS: Selects a specific CRS from the internal database by searching for its EPSG code (recommended) or name.
- Import Coordinate System: Imports a custom projected coordinate system in the .wkt, .txt, .csv, .cal, or .dc format. For more information: Well-Known Text (WKT) in PIX4Dcatch.
For more information: Output Coordinate Reference System - PIX4Dcatch
Region of interest (ROI):
A region of interest (ROI) determines the output extent, therefore speeding up processing time, reducing disk storage requirements, and enhancing reconstruction quality. It is not possible to add a region of interest after the project has been uploaded to PIX4Dcloud.
