Create a project - PIX4Dmatic
Tip: It is possible to create a new project by simply dragging and dropping images or image folders on the home screen.
New project
New projects in PIX4Dmatic can be created by dragging and dropping images or image folders on the home screen, using the menu bar, or the Ctrl + N (⌘ + N) shortcut.
Drag and drop input files
  1. Drag and drop images or image folders on the home screen.
  2. Specify the Project name and the Path of the project.
  3. Click Start.
Pix4Dmatic create project large
Drag and drop images on the Home screen to create a new project.
A new project is created and ready for processing. To import additional input files use the File menu or drag and drop them on the screen.
From the home screen
  1. Click Select from disk (first thumbnail) on the home screen.
  2. Click:
    • Select images... to select the images, or
    • Select folder... to select the folder with images.
  3. Specify the Project name and the Path of the new PIX4Dsurvey project.
  4. Click Start.
A new project is created and is ready for processing. To import additional input files use the File menu or drag and drop them on the screen.
From the menu bar
  1. Click File on the menu bar.
  2. Click New.
  3. Specify the Project name and the Path of the project.
  4. Click Start.
A new empty project is created and is ready to import images.
Open project
It is possible to open existing PIX4Dmatic (.p4m) projects using the home screen or the menu bar. Projects can also be opened using the Ctrl + O (⌘ + O) shortcut.
Click the project's thumbnail on the home screen. This is only available for projects that were previously opened and saved on the machine.
From the menu bar
  2. Click Open...
  3. On the pop-up Open Project, specify the file and click Open.
The project is opened and a new screen displaying the project opens.
Adding additional images
Additional images can be added to the project by:
  • Drag and drop images or image folders on the screen, or
  • In the Image viewer, click Pix4D_more_icon.png >  Pix4Dmatic_add_images.jpg Import images..., or
  • Use the Menu bar > File > Import images...
Processing queue
PIX4Dmatic has the capability to list projects for processing. From the queue, projects are processed in the order in which they are placed. A project will sit idle while waiting for the previous one to be completed. Once a project has been completed the next queued project will begin processing without delay.
While a project is processing, simply create a new project or open an existing project and click Start. The project will automatically be placed in the queue. The processing status will then be displayed in the Status center below.
Tip: This feature is useful for expediting the processing of multiple projects. For example, PIX4Dmatic can be left to process overnight or over a weekend without any user input.
1 out of 2 found this helpful
4 comments
  • Zachary Lowe
    Everytime I try to start a new project, the 'New Project' screen comes up blank.  Nothing, not a text box, not an icon, not a click button, nothing.  So I have tried three times now installing and uninstalling Mapper.  Each time the same result.  I have looked online for solutions and have come up blank.  Any suggestions?  Thanks
  • Avatar
    Blaž (Pix4D)
    Hi Zachary,
    At the moment we do not have other users reporting this issue. I will send you a message and request for additional information and we will have a look.
    Best,
  • Cabonne Pilots
    I am glad someone else has asked this as I am too experiencing this problem.
  • Avatar
    Blaž (Pix4D)
    Hi,
    The screenshot that you share is from Pix4Dmapper while this article is about creating a project in Pix4Dmatic.
    Please make sure that the drivers of your GPU are updated.
    Would you kindly also check if your computer meets the recommended system requirements?
    Pix4Dmapper is tested, optimized, and supported only on Windows 10. Therefore, it might happen that on other platforms some issues will occur.
    Best,
