Outputs - PIX4Dcloud
The outputs of PIX4Dcloud consist of photogrammetric results and of post-processing outputs, such as annotation files.
Project processed via project wizard in PIX4Dcloud
Project processed via PIX4Dcatch
Outputs uploaded to an empty project in PIX4Dcloud
Outputs uploaded via Share to PIX4Dcloud
Project uploaded from PIX4Dmapper to PIX4Dcloud
Post-processing results and workflows
Access: The generated outputs (point cloud, 3D mesh, DSM, orthomosaic, quality report, log file, and other outputs and formats) are accessible once processing is complete in Files & Reports > Results.
When creating a new dataset to process on PIX4Dcloud/ or PIX4Dcloud Advanced, the following standard outputs (with default formats) can be generated and made available for their web visualization, according to the Processing options selected in step 4.
| Output | Extension | Description |
| Orthomosaic | .tif | Orthomosaic file. |
| DSM | .tif | DSM file. |
| Point cloud | .laz, .las, or .slpk | Point Cloud file(s). |
| Gaussian Splat | .ply | 3D object |
| 3D mesh | .obj or .slpk | OBJ 3D Mesh with texture files. |
| Quality report | Quality report of the project. | |
| Log file | .log | Application logs, generally used for troubleshooting. |
When processing a project via PIX4Dcatch to be processed with PIX4Dcloud/or PIX4Dcloud Advanced, the following standard outputs (with default formats) can be generated and made available for their web visualization.
| Point cloud | .laz |
| 3D mesh | .obj | OBJ 3D Mesh with texture files. |
| Gaussian Splat (*) | .ply | Photorealistic 3D model |
(*) It has to be required by the user when uploading images for processing from PIX4Dcatch. See Using PIX4Dcatch to generate a Gaussian Splat model for more information.
When uploading results to a project in PIX4Dcloud/or PIX4Dcloud Advanced, the following output formats can be downloaded afterward.
| NDVI | .tif | NDVI index. |
| Point cloud | .laz / .las | Point Cloud file(s). |
When uploading results to a PIX4Dcloud project via Share to PIX4Dcloud, the following output formats can be downloaded afterward.
| Pix4D product | Output | Extension | Description |
| PIX4Dmatic/PIX4Dsurvey | Orthomosaic / DSM | .tif | Orthomosaic file / DSM file |
| Point cloud | .laz | Point Cloud file(s). | |
| 3D mesh | .obj | OBJ 3D Mesh with texture files. | |
| PIX4Dfields/PIX4Dreact | Orthomosaic / DSM / Index | .tif | Orthomosaic file / DSM file / Indexes (BNDVI, GNDVI, CLI, NDVI) |
A wider variety of formats and outputs can be generated and processing options selected if the project files are uploaded from PIX4Dmapper to PIX4Dcloud/or PIX4Dcloud Advanced. More information on customized processing options in How to customize the options for processing on PIX4Dcloud. A full list of downloadable files is available in How to download the results from PIX4Dcloud.
| Point cloud | .las | Point Cloud file(s). |
| DTM (*) | .tif | Contour lines file |
| NDVI (**) | .tif | NDVI map |
| Quality report | .pdf, .xml | Quality report of the project. |
(*) DTM can only be generated when uploaded datasets from PIX4Dmapper to PIX4Dcloud, but the output cannot be visualized in the PIX4Dcloud 2D viewer.
(**)NDVI map can only be generated when uploaded datasets from PIX4Dmapper to PIX4Dcloud.
Annotation files
After the dataset is processed on PIX4Dcloud and/or available for its web visualization, annotations can be added and later on exported to third-party software or to other PIX4Dcloud datasets.
More information on how to export annotations and which formats are supported for their export in How to export/import annotations.
Download/Export results
Outputs from PIX4Dcloud can be downloaded individually or as a results folder. More information on how to export outputs in Download/Export. When accessing the project via share link, this feature is not available.
Share
Outputs from PIX4Dcloud can be shared for collaboration purposes. For more information: Share.
