This article talks about moving through and identifying aspects of a PIX4Dsurvey project.
Navigate in the 3D view
Project Settings
Navigate in the original images
To change the display of an individual image
To change the display of all images
To pan, rotate, and zoom in the 3D view:
- Left-click to pan the 3D view.
- Right-click to rotate the 3D view.
- Use the scroll wheel to zoom in and out on the 3D view.
To access the predefined views:
- Click View in the Menu bar.
- Click:
- Orthographic view (5) to switch to orthographic view.
- Perspective view (6) to switch to perspective view.
- Zoom to fit all content (Ctrl+1) to zoom out and view the entire scene.
- Zoom to selection (Ctrl+2) to zoom to the selected object.
- Top view (7) to view the scene from the top. The scene is zoomed out to display the entire scene.
Project Settings
Click at the to-right corner of PIX4Dsurvey to open the Project Settings adjust the following settings in the 3D view:
- Point size (10 - default, 0.5 - 50), to change the point size of all project point clouds. The point size of each point cloud can be individually set in the Content - Point clouds panel by accessing the Point cloud properties
of the individual point cloud.
- Color by elevation, by enabling this feature, it is possible to assign a color to each point of a point cloud according to the elevation of the points.
- By default, the color palette is scaled according to the minimum and maximum altitude values of the point cloud. It is possible, however, to manually change the starting and ending point by moving the two sliders. Points outside this range are shown as grey.
Histogram showing the number of points by altitude. Move the two sliders horizontally to define how to stretch the color palette.
- A selection of different color palettes are available.
- Obscured object visibility (0.5 - default, 0 - 1), to change the visibility of obscured objects.
- Camera (off - default), to toggle on/off the position and orientation of the cameras in the project (only available for photogrammetry projects).
- Camera Size (1 - default, 0.01 - 5), to change the size of cameras (cameras must be activated in the button above or in Menu View > Cameras.
- Bookmarks (on - default), to toggle on/off the position and orientation of the bookmark cameras in the project view. More information about bookmarks can be found here: Bookmarks in PIX4Dsurvey.
- Bookmarks size (0.50 - default, 0.01 - 5), to change the size of the bookmark cameras.
- Sky background (on - default), to toggle on/off the sky shared.
- Background color (black - default, grey, white), to change the background color.
- Viewport Layouts (one viewport - default), to split the view in different viewports. Eight different layouts are available
Navigate in the images
To change the display of an individual image:
- Hold Ctrl and left-click to pan on the image.
- Hold Ctrl and rotate the scroll wheel to zoom in and out of the image.
To change the display of all images:
- Click
to add a marker (must be marked on a minimum of two images).
- Click + or - to increase or reduce the number of columns of displayed images.
- Use the slider to zoom in and out all the images at once.
