Previous | Next |
The exported outputs contain the information about layers that will be automatically recognized when importing them in third-party software.
Export all outputs
To export all otputs in Pix4Dsurvey:
- On the Menu bar, click File.
- Click Export To and select the output format. The dialog Select File appears.
- Navigate to the path where you want to save the file.
- In File name, type the desired file name.
- Click Export.
The exported outputs are now ready for import in your preferred third-party software.
Export an output
To export an individual output:
- Right-click on the desired object in the Content panel.
- Click Export.
tengo una licencia de prueba y no me permite exportar archivos
Hi Victor,
I had a look and there is no trial license associated with your account. If you don’t have a Pix4D license yet, feel free to get in touch with Technical Sales about purchasing a license or getting a trial.
Best,
Hola,
Puedo exportar e importar archivos dxf a Pix4Dsurvey?
Saludos.
Hi Manuel,
It is possible to export .dxf files from Pix4Dsurvey. All information about layers will be automatically recognized when importing them in third-party software, for example CAD.
You can import .dxf files into Pix4Dsurvey and use them as a reference and a base for vectorization. Snapping on existing vertices is supported so you can really take advantage of the preexisting data.
Best,
