How to cancel or resume a subscription plan or a trial
A subscription plan can be canceled or edited at any time. Canceling the plan means deactivating the auto-renewal option and the associated billing. For PIX4Dcloud, the cloud credits are defined by the purchased plan and are valid until the subscription's end date.
Note: Once a subscription is canceled, the license will remain valid until the last day of validity. It is, therefore, possible to cancel a subscription before the renewal and continue using the license after the cancellation until the last day of validity.
Warning:  It may happen that an external email has been sent stating  "Your subscription has been cancelled", please disregard it. No actions are needed. Please visit https://www.pix4d.com/support/ and create a support ticket if additional assistance is needed.
Cancel a subscription plan or a trial
  1. Go to https://account.pix4d.com/plan/manage.
  2. Select the organization holding the subscription you would like to cancel
  3. Under Plans & licenses, click the license to be canceled.
  4. Click Manage subscription plan.
  5. Click CANCEL SUBSCRIPTION
    1. In case of a trial or a single-product subscription: click the Cancel subscription button.
    2. In case of a multi-product subscription (bundle): select the product(s) you want to cancel and then click the Cancel subscription button.
      1. If you did not select all products of a bundle: The selected products will be removed from the bundle, and it is not possible to reactivate the subscription
      2. If you selected all products of a bundle: The bundle remains and it can be reactivated, if needed, before the license expiration.
  6. Add the reasons for your cancellation by selecting them from the list. You can select more than one reason.
    1. In case of canceling a trial: Click Confirm.
    2. In case of canceling a subscription: Click Confirm cancellation.
  7. The message Subscription canceled appears. The box will also let you know until when the license remains active.
  8. The Auto-Renewal status will change to Disabled. The license will still work until the last validity day (expiration date).
Note: Trial licenses, if not canceled, are converted into trial subscriptions. More information can be found here: How to obtain a trial license for PIX4D products.
Tip: If you changed your mind after canceling a subscription or a trial, you can reactivate it as long as the subscription or trial period has not ended. More info here: Resume a subscription plan
Note: PIX4Dcatch licenses purchased on the Apple's App Store are not listed here. If you want to cancel such a subscription, please follow the instructions listed in the Cancel a subscription from Apple's App Store section.
Troubleshooting
Something went wrong with your payment
When the Cancel now button is gray and cannot be clicked, it indicates an issue with a previous payment.
The main reason for this to happen is when both of these points happen:
  • The subscription plan has not been canceled before the auto-renewal date
  • The subscription plan has renewed, and the payment failed (because of insufficient funds or any other reason)
In this case, if you want to cancel the subscription, you first need to pay the open invoice (you should have received instructions via email from our payment processor, Stripe, on how to pay the open invoice).
Alternatively, if you are not interested in renewing the license, please ignore the charge attempts for two weeks.
Resume a subscription plan or a trial
If you canceled a subscription plan or a trial, the license will still be valid for the entire validity period. If you changed your mind and you still want to continue using the product after the expiration, as long as you are still within the validity period, you can resume the subscription plan or a trial. This will turn on auto-renewal, and your license will renew at the end of the validity period.
  3. Under Plans & licenses, click on the license that should be canceled.
  5. Click Reactivate subscription.
  6. The subscription will reactivate. A message will tell you the renewal date.
Note: This is valid only for PIX4Dcatch licenses or trials requested via Apple's App Store.
Licenses purchased or requested on Apple's App Store are managed by Apple, and the procedure described in the previous sections cannot be used.
To cancel a subscription for a license purchased on Apple's App Store, please follow this procedure on your iOS device:
  • Open the Settings app
  • Tap your Apple ID (your name at the top)
  • Tap Subscriptions
  • Tap the PIX4Dcatch Subscription
  • Tap Cancel Subscription (you need to scroll down if needed)
Tip: More information can be found here: How to cancel a subscription on your iPhone (external link apple.com).
