General
Account and license
- Not Receiving Notification Emails from PIX4D
- FAQ - Pricing increase 2026
- Single Sign-On (SSO) for Pix4D
- PIX4D License Types
- End-of-support PIX4Dcapture Pro
- Mission planner decommission
- How to download the last stable version available of a PIX4D software in case of an expired Maintenance Plan
- End-of-support - PIX4Dcapture
- License key activation, PIX4D credit voucher codes, and coupon codes
- Standard Support
- How to obtain a trial license for PIX4D products
- Issues with license key or voucher code redemption
- Restricted Export of Pix4D Software Products
- Cannot confirm/activate the account because the confirmation/activation email has not been delivered
- How to delete my PIX4D account
- I cannot find the license in my organization account
- Cannot purchase or renew a license
- How to renew a Rental license
- How to get started
- PIX4D licenses
- Managing the payment method information
- How to opt out of sharing personal data with PIX4Dmapper 4.3.9 or older
- How to subscribe to the Maintenance Plan
- How to buy a subscription plan
- Sign up - How to create a PIX4D account
- Password of the PIX4D account
- Billing and licensing FAQ
- How to cancel or resume a subscription plan or a trial
- Premium support
- Why has my payment failed?
- Basemap display issue
- What to do in case of a service incident - FAQ
- Is my credit card information secure?
Organization management
- Organization management
- Organization settings
- How to create and delete an Organization
- Resource transfer in PIX4Dcloud
- How to consolidate multiple Organizations into one Organization
- Desktop products within an Organization
- Cloud products within an organization
- PIX4Dcatch within an organization
- FAQ - Organization management
Pix4D outputs
- Pix4D outputs with other software > by use
- Pix4D outputs with other software > by software
- Applications with ArcGIS products
- Reflectance map vs orthomosaic
- How to import Pix4D data into IMS Map360
- Applications with Google
- Pix4D outputs into ERDAS IMAGINE photogrammetry (LPS)
- How to share KML files
- How to visualize the 3D textured mesh with georeference
- What is the XML structure file?
- How to convert a GeoTIFF File into .png File
- How to upload files to Sketchfab
- How to convert a GeoTIFF File into a georeferenced .jpg File
- TFW World File Values
- How to convert the Orthomosaic .tiff Format from compressed to uncompressed - PIX4Dmapper
- How to convert .xyz Point Clouds into .tin with Saga GIS
- Applications with Global Mapper
- Pix4D outputs for 3D printing
- Pix4D outputs with other software > by output
- How to import Pix4D outputs to Autodesk
- How to visualize the GeoTIFF DSM File - PIX4Dmapper
- Error in Meshlab: "Some materials definitions were not found..."
- Using Pix4D Shapefiles in SMS AgLeader Software
- Applications with Quantum GIS (QGIS)
- How to import the GeoTIFF Orthomosaic into the 12D Model Software
- How to use the 3D Textured Mesh in Sketchfab
- How to import PIX4Dmapper Outputs into Inpho
- Applications with 3D PDF
- How to import a 3D Textured Mesh into Meshmixer
- Why are the EXIF tags empty in the orthomosaic?
- Transparency of the orthomosaic
Photogrammetry knowledge
- Tie points in photogrammetry project (GCPs, CPs, MTPs, and ATPs) - PIX4Dmapper
- What is the maximal orthogonal ray distance?
- Best practices for image acquisition and photogrammetry
- Camera distortion
- How to verify that there is enough overlap between the images
- Coordinate reference systems and 2D projections
- Automatic target detection - AutoGCP algorithm
- Ground sampling distance (GSD) in photogrammetry
- How the onboard GPS affects the project accuracy?
- Photo stitching vs orthomosaic generation - PIX4Dmapper
- How are tie points errors defined - Mean, Sigma, RMS?
- TOOLS - GSD calculator
- TOOLS - Vertical pixel displacement calculator
- Orthometric vs ellipsoidal height
- Reprojection error - PIX4Dmapper
- Number and distribution of ground control points (GCPs) in corridor mapping
- Which factors affect the accuracy of the automatic aerial triangulation (AAT)?
- Is it possible to generate the orthomosaic of water surfaces?
- Scientific papers
- What is... (a densified point cloud? an orthomosaic? etc.)
- What is the relative and absolute accuracy of drone mapping?
- Yaw, Pitch, Roll and Omega, Phi, Kappa angles
- Vertical vs oblique imagery
- How to select Camera Focal Length and Flight Altitude considering the desired Ground Sampling Distance and Terrain to map?
Practical knowledge
- Best practices for multispectral drone surveys
- Volume Measurement in Pix4D Products: Overview and Algorithm Guide
- Are DJI drones suitable for mapping?
- How to zip and unzip files
- How to create screenshots or screen recordings
- Which image acquisition app can I use with Pix4D's software?
- Processing thermal images - PIX4Dmapper
- Can PIX4Dmapper process large frame images?
- Image acquisition plan for terrain with height variations
- What is the equirectangular image format?
- How to update the driver for an NVIDIA graphics card
- Can RAW images be processed?
- Can hyperspectral images be processed?
- Processing images from GoPro cameras - PIX4Dmapper
- Does Pix4D offer stereo-viewing options?
- Can satellite imagery be processed?
- Which cameras can be used for precision agriculture
Other resources
- Processing RGB Imagery from Skydio Drones with Pix4D Software
- PIX4Dmapper Getting Started PDF version - EN, ES, FR, PT, LV, UA, RU
- FAQ - Pix4D Training
- Webinars and ebooks
- How to access your PIX4D training
- Site localization calculator
- Supported drones and cameras
- Glossary
- Example projects - real photogrammetry data
- EXIF and XMP tag information for project creation
- Specifications of XMP Camera Tags – Pix4D Software
- Getting the most out of the Pixie chatbot
- Pix4D desktop applications affected by Windows Explorer bug
