Menu View > Volumes > Menu Bar - PIX4Dmapper
Index > Interface > Menu View > Volumes  Previous  |  Next
In PIX4Dmapper the Volume menu provides more information regarding Volumes as well as the option for the user to manually edit them in a project.
Access: On the Menu bar, click View > Volumes, and then click Volumes.
The following options are displayed:
New Volume
A Volume is an object that can be used for volume calculations. It is defined by a 3D Surface called a base surface. The volume is computed between the base surface and the terrain surface, defined by the DSM.
For step-by-step instructions about how to draw a new volume: How to draw a Volume.
Once a New Volume is created, the Sidebar displays the following information: Menu View > Volumes > Sidebar > Objects.
8 out of 18 found this helpful
13 comments
  • Marcio Pivovar
    Hello, some improvement suggestions that I am missing:
    1- Select and delete multiple "volumes" at the same time
    2- Export of "volumes" with all attributes, such as volume values in tables or SHP.
  • Paul Mandeno
    Completely Agree Marcio, Virtual Surveyor easily allows your do to do this .... Come on Pix4D
  • Avatar
    Beata (Pix4D)
    Hi,
    Thank you for your feedback; it's precious. I made a note and passed it on to the right people.
  • Connor Kelly
    I'd like to suggest adding the ability to manually change the altitude or elevation of a specific mark, maybe but right clicking or middle clicking on it?
  • Avatar
    Beata (Pix4D)
    Hi Connor,
    You can edit the height of the vertices in rayCloud. When the volume is drawn vertices are created as MTPs. These MTPs can be modified to 3D GCPs (Ground Control Points) in the rayCloud view. This enables you to give specific coordinates to each point (z), e.g. based on a previous survey of the area or as a height of the surrounding area.
    Regards
  • Leo Hebert
    Hello,
    Is there a way to get volumes underneath a conveyor?  It is adding the height of the conveyor to the stack volume, and I only want the dirt volume.
    Thank you for your help with this.
  • Kapil (Pix4D)
    Hello Leo,
    You have to remove the conveyor belt using the rayCloud editor, before calculating the volume. There is no option to add the height of the conveyor to the stack volume to only calculate the dirt volume. For more information, I would recommend you to go through our support article on How to remove Objects from a Stockpile for the Volume Computation.
    Best,
  • Naotaka Toyoda
    新規ボリュームが出ない。計算がでない。直観的に次に進めない。
  • Avatar
    Michino (Pix4D)
    Toyoda 様、コメントありがとうございます。Pix4Dmapperでの体積計算にはDSMと高密度点群の両方が必要ですので、Step3も処理済みかご確認ください。もしよろしければPix4Dサポートへ直接お問い合わせください。
    よろしくお願いいたします。
  • Lucía Regla
    Hola.
    Se podría recuperar funcionalidades desaparecidas??.
    En la versión 1 de P4D permitía el exportado de pirámides (mesh) de la porción de lidar cubicada. en esta versión solo permite exportar el "contorno" (superficie de corte a partir de la cual cubica).
    Esta funcionalidad desaparecida permitía generar informes, vistas, secciones y longitudinales de la cubicación realizada con otras herramientas de Autocad-MDT-CIVIL... Si no me tendré que des actualizar.
    Edited by Lucía Regla
  • Holden (Pix4D)
    Hi Lucia. You can request features directly with our developers by posting at the link below.
    https://community.pix4d.com/c/pix4dmapper/pix4dmapperFR/78
  • Benjamin Pille
    I have been trying to import a 3D base surface using the "import base surface(s)" button on the top. This way, i can reuse them for following measurements.
    So far, no luck. Is it possible to give some additional info on how to create the right files? I've tried exporting the base contour in XYZ to .shp but keep getting the following error:
    [Error]: Error e0202a: Could not import volume(s) from SHP file. The selected file has to contain the 3D surface of the volume measurement(s).
    Does the file have to contain the contours in XYZ, or is it a actual surface containing the TIN in .shp?
    Thanks
  • Zendesk Admin Service Account
    Hello, have you tried to
    1. Create a Volume in Pix4Dmapper
    2. Export it from Pix4Dmapper: How to export Volumes, "The volume will be exported as a polygon with Z values for each vertex. "
    3. Import it back to the same of a different project
    This should work. Let us know how it goes!
    Edited by Zendesk Admin Service Account
