Edit, Add, and Delete Indices and Formulas in the Index Calculator - PIX4Dmapper
This article provides step-by-step instructions on editing, creating, and deleting an index and formula.
With the Index Calculator, it is possible to perform the following actions:
- Edit an Index - Formula from PIX4Dmapper Index Database
- Edit a user-defined Index - Formula
- Add a new Index - Formula
- Delete a user-defined Index
1. On the Menu bar, click View > Index Calculator.
2. On the Index Calculator sidebar, in section 3. Index Map, click Indices...
3. Select the Index to edit and click Duplicate. A new index with the name "IndexName_copy" is created.
-   : Index from PIX4Dmapper index database. For more information about PIX4Dmapper Index Database List: PIX4Dmapper Index Database List. : Index from PIX4Dmapper index database. For more information about PIX4Dmapper Index Database List: PIX4Dmapper Index Database List.
-   : User-defined index. : User-defined index.
 : Index with some user-edited values. : Index with some user-edited values.
 : Index from the .p4d file. : Index from the .p4d file.
4. (optional) Change the index name:
4.1. Select the Index by clicking the Index name.
4.2. Double-click the Index name.
4.3. Edit the name.
5. (optional) Change the formula expression. There are two ways of changing the formula expression:
1. By double-clicking on the formula:
1.1. Select the Index by clicking the Index name.
1.2. Double-click the formula.
1.3. Edit the expression.
2. By clicking on Edit:
2.1. Select the Index by clicking the Index name.
2.2. Click Edit.
2.3. Use the Formula Editor to change the formula. For information about the Formula Editor and how to use it: Menu View > Index Calculator > Sidebar > 3. Index Map > Index Map (Formula Editor).
2.4. Once the formula is completed, click OK.
6. On the Index List pop-up click:
- OK: To close the Index List and display the last selected index from the Index List in section 3. Index Map.
- Cancel: To close the Index List and display the index selected before opening the Index List in section 3. Index Map.
2. On the Index Calculator Sidebar, in section 3. Index Map, click Indices...
3. (optional) Change the index name:
3.1. Select the Index by clicking the Index name.
3.2. Double-click the index name.
3.3. Edit the name.
4. (optional) Change the formula. There are two ways of changing the formula expression:
1.1. Select the Index by clicking the index name.
1.3. Edit the formula.
2.1. Select the Index by clicking the index name.
2.2. Click Edit.
2.4. Once the formula is complete, click OK.
5. On the Index List window click:
- OK: To close the Index List and display the last selected Index from the Index List in section 3.Index Map.
3. Click Add. The Formula Editor pop-up appears.
- If the Reflectance Map is generated:
- If the Reflectance Map is not generated:
4. Use the Formula Editor to edit the formula. If the Reflectance Map is generated, use the bands of the Reflectance Map Band Selection. If the Reflectance Map is not generated, compose the index by typing the formula. For information about the Formula Editor and how to use it: Menu View > Index Calculator > Sidebar > 3. Index Map > Index Map (Formula Editor).
5. Once the formula expression is completed, click OK.
6. By default, the new Index is created with the name "unnamed".
7. (optional) Change the new index name:
7.1. Select the Index by clicking the index name.
7.2. Double-click the index name.
7.3. Edit the name.
8. On the Index List window click:
3. Select the Index to be deleted.
4. Click Remove.
- OK: To close the Index List and display the last selected Index from the Index List in section 3. Index Map.
