Mount and configure an Emlid Reach RX - PIX4Dcatch
This article describes how to correctly configure and set up the Emlid Rech RX for seamless integration with PIX4Dcatch
To effectively use a PIX4D-supported RTK device with a mobile device, the initial step is configuring the setup correctly. This involves setting the camera offset between the antenna and the mobile device's camera. This offset, whether measured automatically by Pix4Dcatch (SPC+) or manually by the user, is crucial for accurately computing locations captured by Pix4D-adapted RTK devices, ensuring precise measurements for scans or ground control points (GCPs).
Note: To ensure optimal performance and prevent potential issues, update the RTK antenna firmware before use. Follow the instructions provided in the Emlid Reach RX Firmware Update Guide to complete the update process.
Emlid Reach RX has been fully integrated in PIX4Dcatch since version 2.0.0 released on April 30th, 2024.
Mount the PIX4D-supported Emlid RTK rover to the device
The PIX4D-supported Emlid is a GNSS RTK receiver that allows PIX4Dcatch to geolocate the images acquired by your mobile device with centimeter accuracy. The PIX4D-supported Emlid RTK rover can be coupled with mobile phones (iOS) using the SP connectors (cases or clamps) provided by SP Connect.
Note: The SP connectors can be obtained when purchasing the PIX4D-supported Emlid RTK rover. They can also be purchased directly from SP Connect and most electronic, bicycle, and motorcycle shops. Refer to the manufacturer's instructions for further details when mounting for the first time. If the mobile device does not have a custom case available (e.g. Android phones), the universal clamp can be used.
Important: After mounting the PIX4D-supported Emlid RTK rover to the mobile device, verify whether the camera offset has been automatically calculated. If the mount is not listed, the camera offset must be measured manually.
Smartphone model
First, insert the phone into its compatible SP-connect case. Then, mount the case to the device by following the instructions provided with the SP-connect case.
Important: Ensure proper orientation of the mobile device after mounting it to the PIX4D-supported Emlid RTK rover with the antenna pointing up.
Device type
Orientation
iPhone
Portrait
Devices with a Known Camera Offset
This list contains the combinations of mobile devices (phones and tablets) with the Pix4D-supported RTK devices where the camera offsets are already measured. PIX4Dcatch will automatically fill in the X, Y, Z fields with the correct camera offset values.
Smartphone model Compatibility
iPhone  SPC+
iPhone 17 Pro
iPhone 17 Pro Max
iPhone 16 Pro
iPhone 16 Pro Max
iPhone 15 Pro
iPhone 15 Pro Max
iPhone 14 Pro
iPhone 14 Pro Max
iPhone 13 Pro
iPhone 13 Pro Max
iPhone 12 Pro
iPhone 12 Pro Max
iPhone 11 Pro
iPhone 11 Pro Max
iPhone XR ✅
Tablet model Compatibility
iPad  SPC+
iPad 11 inch M4-2024 iPad case - Pix4D Japan*
*Only available in Japan.
Note: The solution for iPad Pro 11'' is only available in Japan.
Important: If the PIX4D-supported RTK devices is not mounted with an SP-connect case, then offset values need to be measured manually, as described below. In PIX4Dcatch, there is an option to overwrite the autodetected values with the manually measured ones.
Camera Offset Measurements
When initiating the connection to the PIX4D-supported RTK devices, the dialog RTK Device Settings opens. The section Camera Offset allows the user to set the X, Y, and Z offset values properly. The available options depend on the combination of the PIX4D-supported Emlid RTK device version, the mobile device and the device case. The following options are available: SPC+ and Custom.
The option SPC+ is only available if the combination of the PIX4D-supported Emlid RTK device version, the mobile device and the device case are known. The option Custom is always available and intended to be used by universal or specific cases. This option requires measuring the camera offsets manually and setting them in PIX4Dcatch. The camera offset value selection is saved for the next measurements and modifications are only needed if the setup changes.
       RTK catalog
How to Manually Measure the Camera Offset
emlid_rtk_diagram_iphone_light
Mount the device to the PIX4D-supported RTK devices using the appropriate SP-connect case. Phone cases can be purchased separately from the SP-connect website. The SP-connect universal phone mount can be used if the specific model is unavailable. SP-connect cases are also available in most bicycle and motorcycle shops.
Place the device in landscape mode and the display to the front. Notate the orientation of the X, Y, and Z axes and how they relate to the point of origin on the antenna to measure from. The point of origin resides in the middle of the screw mount at the base of the antenna. It will also be necessary to determine which lens to measure from for devices with multiple camera lenses.
Tip: If unsure which camera lens to measure from, open PIX4Dcatch and place an object in front of each lens. The lens that becomes blocked is the correct one to measure from.
Measure the X and Y axis
To measure the X-axis offset, measure the X-axis on the vertical axis from the middle of the antenna to the point where it intersects the Y-axis. Then, measure the distance from the camera lens to the bottom of the mount.
iPhone 13 & 14 - 258iPhone 13 & 14 - 260
Measure the Z axis
Measure the depth from the center of the handle to the center of the lens for the Z axis offset.
Enter the camera offset values
With the camera offsets properly measured and recorded, they can be included in the appropriate Camera Offset Values field. Depending on the device's geographical region, centimetres or inches will be the displayed measurement unit.
      portrait offset               landscape offset
The camera offset is now properly set in the Camera Offset Values X, Y, Z fields. Continue with the RTK Device Settings dialog to complete the Pix4D-supported Emlid RTK connection to the device.
Third-party information disclaimer:
PIX4D provides instructions for third-party platforms and products solely as a helpful guide to unblock your integration. Those companies are independent of PIX4D. We do not maintain, control, or guarantee the performance, accuracy or reliability of these products.
PIX4D may provide third-party links or contact information to help you find additional information about this topic. This contact information may change without notice. PIX4D does not guarantee the accuracy of third-party documentation or contact details.
