OPTION | DESCRIPTION |
Speed |
Defines the drone's speed from a range between Slow and Fast (default). The maximum speed depends on the selected overlap and flight altitude. The scale has six levels corresponding to percentages of the maximum speed between 100% (Fast) and 50% (Slow). The speed should fluctuate between 2 and 8 m/s and is not constant during the flight since the drone slows down to trigger pictures. |
Capture angle (°) |
Defines the angle that separates consecutive images. The smaller the angle, the higher the image overlap. The value varies between 4° (Low) and 20° (High). The default value is 10° but if it was changed previously, the angle is the one of the last planned mission. |
