English
Double Grid Mission Settings (Android) - PIX4Dcapture
Access: In the Home screen, select Double Grid Mission. In the Map view, tap ic_settings.png.
OPTION
DESCRIPTION
Speed
Defines the drone's speed from a range between Slow and Fast (default). The maximum speed depends on the selected overlap and flight altitude. The scale has six levels corresponding to percentages of the maximum speed between 100% (Fast) and 50% (Slow). The speed should fluctuate between 2 and 8 m/s and is not constant during the flight since the drone slows down to trigger pictures.
Information: Reducing the speed might help to avoid capturing blurry images, but the Fast option is reliable for an optimal reconstruction with the software.
Angle (°)
Defines the tilt (not pan) of the camera between 45° and 80° (default), 90° being vertical. The default value is 80° but if it was changed previously, the angle is the one of the last planned mission.
Information: The drone rotates regardless of the camera angle. It means the drone turns by 180° between two consecutive lines, which implies the heading of the drone is not constant. Therefore, the oblique images are not orientated in the same direction. The drone facing forward throughout the flight, the dataset will contain images with four different orientations.
Overlap (%)
Defines the front overlap between 70%, 80%, and 90%. For more information about how to set the overlap: Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > a. Selecting the Image Acquisition Plan Type. The side overlap is computed such that the side distance between two images is twice the front distance meaning the distance between two images on the same flight line. The side overlap is adjusted with the number of lines so that it is close to the defined overlap value.
Tip: With the advanced mode activated, the scale is extended and more flexible (5% intervals). For more information about the advanced mode: (Android) General settings.
