[2020] Technical release notes - PIX4Dcloud
Note: This article includes the release updates for PIX4Dcloud Starter and PIX4Dcloud Pro (formerly PIX4Dcloud Advanced).
December 8th, 2020 - Bug fixes and improvements
Improvements
  • Mobile device improvements (more information here)
    • Changes in the 2D/3D user interface
    • Improved mobile support for editing points, lines and polygons so that they can be selected more easily on touch screens
  • Projects uploaded from PIX4Dmapper 4.6 version can be processed
  • Sub-cm precision for measurements and annotations: especially for PIX4Dcatch projects where images are taken very close to the object and the GSD (Ground Sample Distance) can be very small
Bug fixes
  • Fixed the issue where an Overlay was not displayed properly when the site had projects with different coordinate systems. (Note: For existing Overlays which have already been imported and are not displayed for this reason, they should be imported again)
  • Fixed the issue where the Show my current position icon was hidden by the orthomosaic layer. Now it is always displayed on top of the orthomosaic and DSM
November 5th, 2020 - Bug fixes and improvements
Improvements
  • The volume annotation is disabled when the project has no DSM and therefore the volume cannot be calculated
  • [PIX4Dcloud Advanced] New messages warn the user when using the AutoGCPs detection functionality if:
    • The wrong GCP file has been imported
    • The wrong coordinate system file has been imported
  • [PIX4Dcloud Advanced] Improvements to handle larger overlays
Bug fixes
  • Fixed the issue for when zooming in very quickly meant PIX4Dcloud did not display the highest ortho resolution
  • Fixed the issue for when sometimes the red and blue marks of the import overlay feature were not displayed
  • Fixed the issue when creating a field in the NDVI layer. Sometimes the '+' button was gone
October 22nd, 2020 - Bug fixes and improvements
Improvements
  • [PIX4Dcloud Advanced] New project group card in a stacked style
  • Search functionality includes folders. A project can be searched for even if it is inside a folder
  • New NDVI and DSM icons visible in editor during tiling
  • [PIX4Dcloud Advanced] Messages in the comparison mode inform users about the alignment of the project
  • The GCP tab is not available if the project does not contain GCPs automatically detected by the AutoGCPs detection functionality
  • Improved performance while uploading images
Bug fixes
  • Fixed the issue which made the NDVI layer disappear when drawing a boundary. Now it is displayed and the user can better adjust the boundary
  • Corrected text and inconsistencies in the user interface
September 28th, 2020 - Processing templates step and Crane Camera projects AutoGCPs alignment
What's new
  • Different type of computations via a template selection step
  • [PIX4Dcloud Advanced + CraneCamera] AutoGCP alignment for Pix4D CraneCamera projects
  • [PIX4Dcloud Advanced + CraneCamera] Message informing about the type of alignment used
Improvements
  • [PIX4Dcloud Advanced] Pop up message when the GCP target size has weird values. When the GCP target size is lower than 20 cm or larger than 2 meters, a message is displayed to verify that the value is correct.
  • New icon for projects which have been shared but have no outputs
Bug fixes
  • Fixed the issue when the altitude was not properly computed in some projects until the user refreshed the browser. The right value is now displayed from the beginning
  • Fixed the issue with the 3D embeds not working for anonymous users
August 19th, 2020 - Bug fixes and improvements
Improvements
  • [PIX4Dcloud Advanced] Timeline performance improvements for large sites (+200 datasets)
  • [PIX4Dcloud only] Add icon for new dataset button
  • Improved text visibility for projects that are processing in light theme mode
  • Improved spacing for elevation profile measurements
  • Improved user menu access for small mobiles
  • [PIX4Dcloud Advanced + CraneCamera] Added link to support article when a project is not well-aligned
  • [PIX4Dcloud Advanced] 3D view is preserved when changing from one day to another. When a user is looking at the 3D view on Day1 and goes to Day2 through the timeline, Day2 will also show the 3D view
Bug fixes
  • Persists the chosen language by the user
  • Fixed the issue when creating a project in a folder (it was created in the root level)
  • Empty folders could not be deleted despite they did not contain any project or site. Now it is possible to delete them.
  • [PIX4Dcloud Advanced] Fixed the issue where invalid characters in the file imported as overlay broke the processing and the overlay was never displayed.
August 3rd, 2020 - Bug fixes and improvements
Improvements
  • [PIX4Dcloud Advanced] Added help button in the volume comparison
  • Added link to support article when selecting the processing template
  • Pop up message when a user is reaching the end of the allowance
  • [PIX4Dcloud only] Direct access to PIX4Dcloud Advanced trial license through the account menu for users with access to PIX4Dcloud
Bug fixes
  • [PIX4Dcloud Advanced] Fixed the issue with having decimals in the GCP target size (it did not process)
  • Fixed the issue where units were not properly taken when sharing a project
  • Fixed the issue with the start process button which could be clicked more than once and that was causing projects to fail.
  • Fixed the issue with importing a zipped point cloud. The uploader got stuck.
  • [PIX4Dcloud Advanced] Fixed the issue when going back to the editor after using the compare mode, two orthos and two DSMs were displayed in the same project
Changes
  • [PIX4Dcloud Advanced] Disable annotations in compare mode
July 3rd, 2020 - Processing templates, bug fixes and improvements
What's new
  • Processing template selection
Improvements
  • [PIX4Dcloud Advanced] Overlay import allows zooming as much as needed
  • Welcome dialog has been removed and a new login icon has been added
  • Better support for Microsoft Edge browser
  • User interface improvements: better contrast in the uploader, better contrast in the drop area in the wizard, improved files view for mobile users
  • PIX4Dcloud favicon added
Bug fixes
  • [PIX4Dcloud Advanced] Compare mode: fix to show the compare button in shared projects, fix to solve an issue with the second project not refreshing correctly
  • [PIX4Dcloud Advanced] GCP report can be opened in Acrobat Reader
  • Fixed the issue where units were not taken properly from the account settings
  • Fixed the export button in the Virtual Inspector
  • Fix to inform the user when a .zip file is being prepared for download
June 9th, 2020 - Launch release
What's new
  • PIX4Dcloud and PIX4Dcloud Advanced are standalone products and can be purchased separately from PIX4Dmapper.
  • New UI with respect to the old Cloud platform
  • PIX4Dcloud Drive to better organize, view and filter the projects
  • Guided procedure for project and site creation
  • 2D and 3D synchronized views displaying DSM, orthomosaic, NDVI map, Point Cloud and 3D Textured Mesh
  • Markers, measurements, volume calculations exchangeable between projects and third-party software
  • Adjustable layer hierarchy
  • Sharing functionality with view and measure or edit and save rights
  • Dedicate view for downloadable input and output files
  • [PIX4Dcloud Advanced] Visualization of the evolution of the site through a Timeline.
  • [PIX4Dcloud Advanced] AutoGCPs detection functionality. Our AI algorithm finds and marks the GCPs for you during the processing phase
  • [PIX4Dcloud Advanced] CAD overlays to easily import and overlay design plans and maps. The as-built can be quickly compared with the as-designed to easily check progress and identify as-built errors
  • [PIX4Dcloud Advanced] 2D comparison (shareable) view
  • [PIX4Dcloud Advanced] Volume comparison and monitoring report
