English
  • 検索欄が空のため、提案はありません。
クレジット残高システム -PIX4Dcloud- よくある質問
This article explains how the credit balance system works in PIX4Dcloud, including how credits are calculated, consumed, purchased, and managed. It also clarifies specific behaviors related to PIX4Dcloud Pro (formerly PIX4Dcloud Advanced) and PIX4Dcatch.
ライセンス:この記事は、PIX4Dcloud およびPIX4Dcloud (旧PIX4Dcloud )のライセンスに適用されます。
クレジット残高システムとは何ですか?
Credits represent the amount of data processed on Pix4D cloud infrastructure. The number of credits required depends on the camera resolution (in megapixels) and the number of images processed.
Credit formula
Credits = (Image resolution in MP × Number of images) / 100
The image resolution is calculated from the image width and height.
An online credit calculator is available at:
 https://www.pix4d.com/pix4dcloud-calculator/
Information: For datasets with Gaussian Splats, the following formulas apply:
  • For terrestrial datasets uploaded from PIX4Dcatch and PIX4Dmatic: Credits = (Image resolution in MP * number of images / 100 ) + 5 credits.
  • For drone datasets: Credits = Image resolution in MP * number of images / 80.
Warning: The maximum number of images that can be processed in PIX4Dcloud is 4000. See also PIX4Dcloud best practices.
どのようなアクションでクレジットが消費されますか?
Credits are consumed whenever processing is performed on Pix4D cloud servers, regardless of the final processing outcome.
The following actions consume credits:
  • Uploading and processing images directly in the PIX4Dcloud user interface
  • Uploading and processing images from PIX4Dcatch to PIX4Dcloud
  • Creating a project in PIX4Dmapper and uploading it to PIX4Dcloud for processing
  • Creating a project in PIX4Dmatic and uploading it to PIX4Dcloud for processing
  • Reprocessing a dataset (by uploading the same dataset again with the same name and number of images)
Information: Credits are consumed even if processing fails, as they cover infrastructure and processing costs (e.g. AWS). Credit refunds are only considered when failures are caused by verified internal bugs. Users are strongly encouraged to review Pix4D best practices before processing.
What actions do not consume credits?
No credits are consumed when no processing is performed in PIX4Dcloud.
Examples include:
  • Uploading already processed outputs directly through the PIX4Dcloud user interface
  • Uploading processed results using the Share to Cloud feature from other Pix4D products:
クレジットの購入方法は?
It is possible to buy credits from the Organization portal: https://account.pix4d.com/home.
Can I purchase credits automatically?
PIX4Dcloud supports automatic credit top-up, which purchases additional credits when the balance falls below a defined threshold.
To enable auto top-up:
  1. Go to the Organization Dashboard at https://account.pix4d.com/home.
  2. Click Credit transaction.
  3. Click Enable auto top-up.
  4. 画面右上の 今すぐ購入.
Important: Auto top-up is available only after the first manual credit purchase. The selected credit package is reused for future automatic purchases.
警告: If the credit card expires and the account has no active subscriptions:
  1. Disable auto top-up
  2. Re-enable auto top-up
  3. Enter the updated credit card information
If the account has active subscriptions, follow: Managing the payment method information.
Information: For Organizations, availability depends on the user role. See: How to buy credits on behalf of an organization.
Pix4D バウチャーはどのように利用すればよいですか?
Pix4D credit vouchers can be redeemed to add credits to an individual or Organization account. Vouchers are typically issued by Pix4D sales representatives or authorized partners.
Redemption instructions are available here:
How to redeem license keys or credit voucher codes.
Information: Credit vouchers are valid for 3 years from the purchase date.
How can I check how many credits do I have?
Credits can be checked in two ways:
自分の信用履歴を確認するにはどうすればよいですか?
  1. Login with your Pix4D credentials at cloud.pix4d.com/login
  2. Open Account Settings from the user menu.
  3. Select the desired Organization dashboard.
  4. をクリックしてください Credit transactions in the left panel.credit_trasnsactions
The credit history lists the transaction date, user, resource, and number of credits. The history can be exported as a CSV file for a custom date range.
credit historyjpg
range
クレジットを購入できるのは誰ですか?
The credit system is available (since June 1st, 2023) to:
  • Individual users using the credit-based system
  • Organization Owners using the credit-based system
クレジットの有効期限はいつですか?
Credits do not expire as long as a valid license is active. If the license expires, unused credits are deleted after 60 days. See: Our retention policy.
How many credits do I need to process my project?
The required number of credits can be estimated using the online calculator:
During project creation, PIX4Dcloud and PIX4Dcatch display the exact number of credits required before processing starts. For more information, see:
Warning: Projects that include Gaussian Splatting outputs require 5 additional credits (available only when processing from the PIX4Dcatch interface).
Does deleting a project give me the credits back?
No. Deleting a project does not restore consumed credits. Credits are used to cover processing and infrastructure costs, but deleting a project does free up storage space.
How many credits do I get with a PIX4Dcloud Pro trial license?
A PIX4Dcloud Pro trial includes 40 processing credits and an unlimited number of projects.
Example usage:
  • One drone project with ~200 images captured using a 20 MP camera.
  • PIX4Dcatch projects use a default resolution of 2.7 MP; for example, 100 images require approximately 3 credits.
For more deatils, see: PIX4Dcloud / PIX4Dcloud Pro credit balance system - PIX4Dcatch RTK.
Do PIX4Dcatch users need to buy credits?
This depends on the PIX4Dcatch license type:
  • PIX4Dcatch Yearly license: License only, no included credits
  • PIX4Dcatch Individual Year: Includes the license and 500 credits
To purchase additional credits from the Organization portal.
As a user, how do I know the number of credits required to process my dataset on PIX4Dcloud?
Once a project is uploaded directly to PIX4Dcloud (web browser) or from PIX4Dcatch, the system will automatically report the exact number of credits that will be consumed for processing. This information can be verified:
To calculate in advance the number of credits required to process a project, you can use the online credit calculator.
Warning: Projects including Gaussian Splatting as output will cost 5 more credits (only available when processing from the PIX4Dcatch user interface)
What happens if I do not have enough credits?
If insufficient credits are available and auto top-up is disabled, the project can still be created but processing does not start. The dataset status remains Pending User Capacity until enough credits are purchased.
Information: For further questions or concerns, please contact Sales.
