Mission Planner (Retiring end of July 2025)
  1. Pix4D Documentation
  2. PIX4Dcloud
  3. Mission Planner (Retiring end of July 2025)
Mission types - Mission Planner - PIX4Dcloud
Warning: The application will be retired at the end of July 2025. More communications will come in the upcoming weeks.
Mission types
Several mission types can be selected from the mission creation window, described in the following sections.
Corridor mission
Corridor missions are designed to map linear structures such as power lines, roads, or any other that follow a linear path. They are defined by a set of points that will establish the direction of the flight lines.
How to position and design the mission
Once entering the Corridor mission a default mission defined by two points will be displayed on the map.
The following actions can be performed.
  1. Move the survey area: the survey area can be displaced by click on the mission shape and dragging it to a new location.
  2. Move a vertex: tap on a vertex and drag it to a new position to extend or reduce the survey area.
  3. Remove a vertex: two adjacent vertex can be merged by dragging one on top of the other one.
  4. Add a vertex: a vertex can be added by tapping on the “+” icon displayed over a segment.
Note: The Reset mission button reset.png allows the mission shape and location to be reset to the default one.
Define the Corridor mission properties
The following mission information and settings are available on the right panel.
  • Mission summary:
    • Length [km]: length of the mission geometry. The reral length of the flight will be determined by the numer of flight lines.
    • Width [m]: the projected width of the survey area on the ground.
    • Flight time [hh:mm:ss]: estimated flight time of the current mission.
    • GSD [cm/pixel]: distance between two consecutive pixel centers measured on the ground. The GSD depends on different parameters such as the camera specifications, the flight height, and the camera angle.
  • Mission settings:
    • Drone model: select the desired drone model.
    • Camera model: select the specific camera for the selected drone model.
    • Start position: determines the start and end position of the flight. It can be switched betwen 4 different options: A,B,C,D.
  • Flight height [m]: height of the mission in reference to the take-off location. The range is 10 - 150m.
  • Front overlap [%]: percentage of an image covered by the next one at the ground level with respect to the flight direction. The range is 20 - 90%.
  • Side overlap [%]: percentage of an image covered by an adjacent one (in adjacent flight line) at the ground level. The range is 20 - 90%.
  • Number of lines: determines the number of passes of the drone in the current mission. The higher the number of passes, the higher the width.
  • a minimum of 2 lines is recommended.
  • Drone speed [100%]: speed of the drone during the mission execution. The maximum speed depends on the selected front overlap and flight height. The slider allows selecting percentages (10% steps) of the maximum speed.
Note: The reset.pngRestore button can be used to reset the settings to their default values.
Grid mission
The Grid mission is meant to plan and fly polygonal mission shapes with a single grid flight pattern for 2D maps or a double grid flight pattern for 3D models. It is suitable for most environments that require flexible boundaries or complex mapping shapes and ensures that images are taken with the gimbal pitch and the overlap required for optimal processing.
Once entering the Grid mission the default mission shape is displayed over the basemap at the current location.
  5. Rotate the flight lines: tap and rotate within the survey area to modify the direction of the flight lines.
Define the Grid mission properties
  • Mission summary:
    • Area [ha]: area covered by the mission.
  • Mission settings:
    • Flight pattern:
      • Use Single grid pattern to take images perpendicular to the ground (nadir), with the overlap required for optimal processing. Recommended in the following cases: main interest in 2D map outputs, relatively flat surface (e.g. earthworks, fields), large area.
      • Use Double grid pattern to take images from multiple sides (oblique), with the overlap required for optimal processing. Compared to the single grid, this pattern is recommended for flying closer to objects in order to capture more vertical details.
      • Note: Double Grid is recommended in the following cases: main interest in 3D model outputs, surface with height fluctuations or objects (e.g. buildings, forest), small and medium area (the flight time is doubled compared to single grid pattern).
  • Camera angle [°]: angle of the camera during the mission execution. The range is 0° - -90° (nadir).
  • Drone speed [%]: speed of the drone during the mission execution. The maximum speed depends on the selected front overlap and flight height. The slider allows selecting percentages (10% steps) of the maximum speed.
Note: The reset.png Restore button can be used to reset the settings to their default values.
To generate the best 2D and 3D outputs, we highly recommend using the default mission settings values according to the selected flight pattern:
Parameters
Single grid
Double grid
Front overlap
80%
80%
Side overlap
70%
70%
Gimbal pitch
-90°
-70°
Orbit mission
Plan and fly an Orbit Mission around a target point. It ensures that the images are taken from all angles, with the overlap required for optimal processing. Recommended in the following cases: main interest in 3D model outputs (point cloud, mesh, etc.); isolated object (e.g. house); small area.
Define the mission properties
  • Mission information:
      • Area in m2
      • GSD cm/px
  • Mission settings:
      • Flight height: defines the height of the mission (10m - 250m).
      • Images per orbit: defines the number of images per orbit (20 - 180).
      • POI height: defines the height of the point of interest (0m - 250m).
Cylinder mission
Plan and fly a Cylinder Mission around a tall object. It ensures that the images are taken at different levels and from all angles, with the overlap required for optimal processing. Recommended in the following cases: main interest in 3D model outputs (point cloud, mesh, etc.); isolated object (e.g. tall building); small area Define the mission properties
      • Area in m2
      • GSD cm/px
  • Mission settings:
      • POI min height: point of interest minimum height (base). The value should be at least 10 m lower than the POI max height. Tap Set to current to set the value to the current height of the drone (0m - 240m).
      • POI max height: point of interest maximum height (top). The value should be at least 10 m higher than the POI min height. Tap Set to current to set the value to the current height of the drone (10m - 250m).
      • Mission min height: minimum height at which the drone will fly the mission (cylinder base). The value should be at least 10 m lower than the mission max height. Tap Set to current to set the value to the current height of the drone (10m - 240m).
      • Mission max height: maximum height at which the drone will fly the mission (cylinder top). The value should be at least 10 m higher than the mission min height. Tap Set to current to set the value to the current height of the drone (20m - 250m).
      • Verticals: number of vertical lines in the cylinder mission (4 - 20).
      • Front overlap: frontal overlap between successive images in the vertical lines (60% - 90%).
Note: When performing a Cylinder mission, the camera angle is automatically interpolated in the vertical lines in order to look at the POI max height from the mission max height and at the POI min height from the mission min height.
