Technical release notes (2.XX) - PIX4Dmatic
This article summarizes PIX4Dmatic version 2.0 and above. This includes new capabilities, additional updates, and bug fixes.
Download the latest or authorized older PIX4Dmatic versions from the Download page after signing in with your license account. For more information click here.
To access PIX4Dmatic 1.0-1.86 technical release notes, please visit: Technical release notes (1.XX) - PIX4Dmatic
Disclaimer: The preview version contains new features and bug fixes. Documentation and support are not available. We recommend testing the preview version before using it for production work.
| Version | Release date | Release Type | Installers |
| 2.3.0 | March 24, 2026 | Preview | Windows | Mac |
2.3.0
All licenses
New Capabilities
Volume computation improvements:
Added cut/fill colorization for computed volumes in the 3D view, using height differences to easily distinguish between cut and fill areas
Volumes can now be recomputed directly from the Properties panel
Information
- Supported macOS versions are now Sequoia (15.x) and Tahoe (26.x). Sonoma (14.x) is no longer supported
- Updated the Windows installer to support desktop Gaussian Splatting processing. The new installer does not automatically replace previous versions; older versions should be manually uninstalled from the “Add or Remove programs” list
Bug fixes
- Fixed an issue where the CSV geometry export custom headers Easting and Northing were incorrectly swapped for certain coordinate reference systems
Known issues
- This version is not compatible with the PIX4Dmapper “Open in PIX4Dmatic” feature
- On macOS, the application may crash when closing in certain cases
PIX4Dmatic Standard
Additional Updates and Improvements
- Improved the calibration for terrestrial acquisitions, delivering better scene reconstruction for datasets with weak, missing, or no GPS data
Information
- To prevent crashes during calibration, please ensure your NVIDIA drivers are up to date. This version of PIX4Dmatic uses requires driver version 570 or newer for optimal stability and performance
Bug fixes
- Fixed an issue where processing in the cloud would fail if Gaussian splats were selected as an output
- Fixed an issue where exporting to LAS/LAZ was incorrectly blocked for projects containing terrain classification when using a Standard license
PIX4Dmatic Analyst
New Capabilities
- Added support for using a single TIN as the "To surface" for volume computations
- Improved the accuracy of progress reporting and the responsiveness of cancellation when generating TIN surfaces
PIX4Dmatic Pro
New Capabilities
- Added support for generating Gaussian splats. Visualize splats in 3D and share results directly to PIX4Dcloud. Leveraging Gaussian splatting technology now allows for higher-quality point clouds, DSMs, meshes, and orthomosaics compared to standard processing. Note: Generation is currently supported on powerful NVIDIA GPUs
Information
Bug fixes
| 2.2.0 | March 2, 2026 | Preview | Windows | Mac |
2.2.0
All licenses
New Capabilities
- Added support for viewing the elevation difference between the base surface and the point cloud in the status bar by hovering over a volume in the 3D viewer
- Added a new settings dialog for volume computation, allowing for the customization of input point clouds, classification filters, and grid resolution
- Added support for viewing the coordinates of points on a TIN surface by hovering the cursor over it in the 3D viewer
- The software now retains the specific settings and point clouds used for each volume computation, automatically flagging volumes as "outdated" if the underlying source data changes
- All steps in the processing panel are now selectable. Checking a desired output automatically selects all required prerequisite steps
- Added the Window > Save current layout as default option, allowing the current arrangement and visibility of panels and tabs to be applied automatically to all new projects
- Improved the layout and stability of PDF reports on macOS, ensuring parity with the Windows version. This update preserves image links and resolves resource management issues during the export process.
Information
- Discontinued support for NVIDIA GPU architectures Kepler and older to focus on modern hardware optimization
Bug fixes
- Fixed an issue where the default CRS was not consistently suggested when creating a new project from imported images
- Fixed an issue where the scene origin was not recentered when changing the CRS for imported images, which previously led to precision errors and sparse point clouds during densification
Known issues
- When a project is uploaded to PIX4Dcloud for processing, and the "Gaussian splat" option is selected, processing will fail. The workaround is to use a previous software version until it is fixed in the next release.
PIX4Dmatic Standard
- No updates specific to this license
PIX4Dmatic Analyst
New Capabilities
- LandXML import: import multiple TIN surfaces via File > Import > TINs or drag-and-drop
- Added the capability to export several TIN surfaces into a single LandXML file
PIX4Dmatic Pro
New Capabilities
| 2.1.0 | February 11, 2026 | Preview | Windows | Mac |
2.1.0
All licenses
New Capabilities
- Added the ability to customize keyboard shortcuts directly in the Preferences dialog
Added support for the SHARE SLAM S20 camera
Added support for new cameras: Wingtra INSPE, MAP61, RX1RX2, SUR61, SONY DSC-RX1RM3, SONY ILX-LR1 with 85mm lens
- Updated the 2D basemap to the latest version, ensuring access to the most recent map data
- Added the option to select the language for quality reports and custom reports when exporting via the report panel
- Added a "Load more" button to the PIX4Dcloud resource list, allowing users to access all datasets, sites, and folders beyond the previous 25-item limit
- Consolidated settings and menu options into a single 3-dot menu for all content panel items to improve consistency
- Added a Cancel button to the login dialog during SSO authentication, allowing users to abort the request and retry without restarting the application
Bug fixes
- Fixed an issue where the status bar would flicker or display the DSM/DTM elevation instead of the correct coordinates when hovering over objects in the 2D view
- Fixed crash when opening native file explorer on Windows
- Fixed an issue where the point cloud section in the content panel could become unresponsive if the Remove outliers tool failed while processing a subset of point clouds
PIX4Dmatic Standard
- Added an Export option directly to the content panel menus for DSM, ROI, mesh, and orthomosaic
- Updated the calibration process to automatically discard corrupted images instead of failing the entire process, allowing calibration to continue
Bug fixes
- Fixed an issue where position and orientation cells in the Cameras table became uneditable after their values were removed
PIX4Dmatic Analyst
New Capabilities
- Added support for multiple TINs in a single project. Users can now choose which TIN to use for contour line generation and decide whether to create a new model or overwrite an existing one
PIX4Dmatic Pro
New Capabilities
Bug fixes
| 2.0.0 | January 5, 2026 | Stable | Windows | Mac |
| 2.0.1 | January 30, 2026 | Stable | Windows | Mac |
| 2.0.2 | February 16, 2026 | Stable | Windows | Mac |
2.0.2
All licenses
New Capabilities
Added support for opening PIX4Dmapper and PIX4Dsurvey project files by:
Right-click on a .p4d or .p4s file → Open with “PIX4Dmatic.exe”
Drag & Drop a .p4d or .p4s file onto the “PIX4Dmatic.exe” desktop icon
From the command line (e.g. Command Prompt)
e.g. "c:\Program Files\PIX4Dmatic\PIX4Dmatic.exe" project.p4d
Bug fixes
- Fix crash when opening native file explorer on Windows
2.0.1
All licenses
Bug fixes
- Fixed a crash that could occur during communication with Pix4D server
- Fixed a crash that could occur when closing the application
- Fixed an issue where manual tie points would disappear from the 2D and 3D views during calibration or reoptimization
- Fixed an issue where exported volume CSV files always used metric units, ignoring the project setting for display units
- Fixed an issue where the 2D view incorrectly displayed the 3D length for measurements instead of the expected 2D length
- Removed the duplicate Compute all outdated volumes command from the Edit menu; it is now exclusively located in the Process menu
PIX4Dmatic Standard
Bug fixes
PIX4Dmatic Analyst
PIX4Dmatic Pro
Bug fixes
2.0.0
All licenses
New Capabilities
- Added support for the new PIX4Dmatic license plans: Analyst, Standard, and Pro
- Added a project axes indicator in the 3D view
- Moved the outlier removal filter from the processing options to a standalone tool accessible via the 3D view and point clouds panel
- Updated the Device manager to display active devices from all organizations
Bug fixes
- Fixed an issue that could cause the application to freeze when exporting GeoTIFF files
- Fixed an issue where the custom report displayed incorrect names for volumes in the overview page
- Added support for imported point clouds in the custom report inventory snapshots
- Fixed an issue that prevented opening LAS files containing incorrect variable length record (VLR) information
PIX4Dmatic Standard
PIX4Dmatic Analyst
New Capabilities
- All PIX4Dsurvey features are now available in PIX4Dmatic: Key capabilities now integrated into a single application include automatic vectorization and comprehensive terrain workflows (terrain classification, TIN, grid, and contour lines)
- Added the ability to generate a digital terrain model (DTM) using terrain-classified points to create bare-earth surface models
- Added the option to generate contour lines directly from the digital terrain model (DTM)
Bug fixes
PIX4Dmatic Pro
New Capabilities
