Orthoplane - PIX4Dmatic
An orthoplane is an accurate 2D representation created from a section of the point cloud. This article explains how to use the orthoplane tool in PIX4Dmatic.
IN THIS ARTICLE:
Orthoplane
The orthoplane feature generates orthomosaics for vertical and horizontal surfaces, such as building facades or floor plans. It provides accurate, scaled 2D representations. An orthoplane is ideal for architectural surveys, inspections, and preservation projects, offering precise measurements and detailed visual information without distortion. The orthoplane is part of the Section view. For more information: Section view - PIX4Dmatic.
Note: The Orthoplane feature is available for PIX4Dmatic version 1.66 or newer.
To create an Orthoplane in PIX4Dmatic:
- From the toolbar in 3D view create a section.
- Vertical section
- Horizontal section
- Section from polyline
- Section from planar polygon
- Vertical section
- Define the section.
- Adjust the Section box to the desired project area. The adjustment can be done manually or by changing the size and orientation from the Section box tab.
- Navigate to the Orthoplane tab.
- The following settings can be set:
| Point cloud |
This processing option defines which point cloud is used for the DSM generation. The following options are available:
| Algorithm | Allows switching between the orthomosaic creation algorithms.
| 決議 | Defines the spatial resolution used to generate the orthoplane. The orthoplane resolution is the same as the resolution of the DSM. For example, if the DSM resolution is set to 5 cm then the orthoplane resolution is also 5 cm. |
| 表面平滑化 |
This setting is applied to the generated DSM. When using Low values, the final DSM contains sharper features and edges. When using High values, the DSM is smoothed out.
| 補間 |
Affects the completeness of the generated DSM:
| Blending algorithm |
- After selecting the desired settings, click on Generate orthoplane.
Tip: Generating a new orthoplane will not replace the existing orthoplanes.
Note: From version 1.75 or newer, the minimum allowed GSD for orthoplane generation has been reduced to 0.01 mm.
Export
After creating the Orthoplane and adjusting the settings, click Export to save the Orthoplane to the location specified in the Destination setting. The Status bar will display the export progress. Once the export is complete, a .jpg file will be generated in the selected location for further use.
