  • 検索フィールドが空のため、提案はありません。
Project registration - PIX4Dsurvey
PIX4Dsurvey allows for the project registration (optional) of imported data (point cloud or photogrammetry project in the form of point clouds and calibrated images) to an existing PIX4Dsurvey project.
Registration is the process of aligning and integrating imported data, such as point clouds or photogrammetry projects, with an existing PIX4Dsurvey project. This step is essential for ensuring that all data is accurately positioned to one another, resulting in a unified dataset that can be used for further processing. The alignment relies on the same markers from both projects to facilitate this integration. This processing needs to be performed as the first step before proceeding with other processing (filters, grid of points, ...).
Important: From PIX4Dsurvey 1.62.0 and above, the Automatic registration tool has been removed.
Access:
  • When using PIX4Dsurvey 1.47 and previous versions, click Automatic Registration Icon 登録 in the Content panel on the left of the PIX4Dsurvey window.
  • When using PIX4Dsurvey 1.48 and more recent versions, open the Content sidebar PIX4Dsurvey content icon and then, in the input data section PIX4Dsurvey input data icon, click on the Register... .
Manual registration
(PIX4Dsurvey 1.48 and later versions) The Manual registration uses markers to register a point cloud to a reference point cloud.
Tool description
  • [1] Reference project: Choose a reference project from the drop-down list of available point clouds. This project will be used as a reference, it won't be moved.
  • [2] Project to register: Choose a project to register from the drop-down list of available point clouds. This project will be moved. The project chosen as a reference will not be available from this list.
  • [3] Select reference marker: These markers serve as a reference for manual registration and should have been created on well-identifiable features.
  • [4] Select matching marker: These markers will be used pairwise to define the rotation and translation of the registration. Markers in the left column should have been created on the reference project. Markers from the right column should have been created on the project to register. Each pair of markers (left + right column) should indicate the same real-world point.
  • [5] PIX4Dsurvey Add button Add reference point: To be used if the user wants to use more than 3 markers to manually register a project. At least 3 markers are necessary to define an unambiguous transformation.
    survey_project_1.74
How to manually register a project
  1. Create at least three markers on well-identifiable features in the point cloud of the reference project (Vectorization tools in PIX4Dsurvey). These points should also be visible on the project to register.
    1. Navigate to the 3D view.
    2. Press M to enable the marking vectorization.
    3. Click on the well-identifiable feature on your reference projects' point cloud to create the marker.
    4. (optional) Rename the marker to make it recognizable.
    5. Repeat for at least two other points.
  2. Create markers for the same features as in step 1 (Vectorization tools in PIX4Dsurvey).
    1. Navigate to the 3D view to find the same features identified in the previous step.
    3. Click on the well-identifiable feature on the point cloud of the project to register to create the marker.
    4. (optional) Rename the name to make it recognizable.
    5. Repeat for all other markers identified in the reference project.
    Tip: Use the visibility buttons visibility icon そして visibility off icon in the input data section PIX4Dsurvey input data icon in the content panel PIX4Dsurvey content panel icon to view/hide a specific project. This will help when creating markings on the reference project or on the project to register. Learn more about visibility in this article: Project management > Content Management.
  3. Open the content sidebar PIX4Dsurvey content panel icon and then, in the input data section PIX4Dsurvey input data icon, click on the Register...
  4. Select the project that will serve as a reference from the Reference project drop-down menu. This project must be the one used to create the markers in step 1.
  5. Select the project that will need to be registered from the Project to register drop-down menu. This project must be the one used to create the markers in step 2.
  6. Select reference markers; these should be the markers created in step 1.
  7. Select matching markers; these should be the markers created in step 2.
    Important: The Reference markers and Matching markers referring to the same feature must be entered on the same row.
  8. (optional) Click PIX4Dsurvey Add icon Add reference point to add more reference point markers in case you created more than three markers in steps 1 and 2.
  9. Click Register.
Information: If a point cloud that comes from a project is selected as a project to register, all the point clouds and images from the same project will be affected.
Warning: Vectorized data (such as polylines, polygons, volumes, ...) based on the point cloud to register will not be registered. Proceed with the vectorization only after registering all the point clouds that need this process.
Important: The reference project and project to register must have common features. All associated point clouds and images will be affected.
Tip: PIX4Dcatch projects processed using the PIX4Dcatch template in PIX4Dmatic are more likely to be successfully aligned.
Tip: Registering projects in EPSG coordinate systems to point clouds in arbitrary coordinate systems will work better if the X and Y values are closer.
