  • 検索フィールドが空のため、提案はありません。
PIX4Dcloud Enterprise features
A PIX4Dcloud Enterprise license gives access to following features:
  • The PIX4Dcloud Pro user interface,
  • Team Access Control
  • API access.
  • SSO
PIX4Dcloud Pro user interface access
Any PIX4Dcloud Enterprise customer can take advantage of the PIX4Dcloud Pro user interface and of all its functionalities.
Team Access Control
This feature allows maximum control over user audience access within the organization, including licenses and resources (datasets, sites, and folders). For more information,
API access
Via the API, different features are available. The main actions that can be performed are the following ones:
  • Create datasets or sites.
  • Process datasets with templates:
    • 3D maps or Nadir
    • Oblique: process with settings optimised for oblique images.
    • Buidling:  input images are from oblique flights around objects with little texture
    • Flat: ojects located in flat areas and with low texture images (vegetation, airports, etc.).
    • RTK: GPS image data is captured using an RTK device.
    • Gaussian splats model
The complete and detailed documentation on how these functionalities can be used via the API can be found at this link.
SSO
Contact us for setting up the SSO configuration: https://www.pix4d.com/contact/
