  • 検索フィールドが空のため、提案はありません。
Outputs - PIX4Dmatic
The following table presents PIX4Dmatic's main output files:
Output
File format
Description
Point cloud .laz A compressed version of the LAS format that reduces file size without data loss. Ideal for efficiently storing and transferring large LiDAR datasets.
.las 1.4 An advanced version of the LAS file format with additional point record types and fields for detailed LiDAR data. Suitable for sophisticated surveying and GIS applications.
.las 1.2 (For ArcGIS Pro) An earlier version of the LAS format for standardized LiDAR point cloud data storage.
.xyz A plain text format for storing point cloud data with X, Y, and Z coordinates. Widely supported and easy to use for basic analysis and data sharing.
Mesh
.obj
Files: .obj, .mtl, .jpg, offset.xyz
Mesh can be visualized in PIX4Dcloud, Windows 3D Viewer, Meshlab, Global Mapper, Rhino, 3ds Max, 3DBuilder, or Autodesk Maya
.slpk Esri file format for use in ArcGIS Pro, or ArcGIS Online
.ply
Files: .ply, .jpg
A  3D file format used to store geometric data of 3D models, including vertex positions and other properties like color and normals. Useful for 3D modeling and computational geometry applications.
Cesium 3D
Files: .glb, .json
Cesium 3D tiles
.fbx
3D file format used to store and exchange complex 3D data, making it suitable for transferring entire 3D scenes with third-party software.
DSM .tiff (GeoTIFF) Export the generated DSM. The image compression, file type (single, tiles), and image scale can be defined. Optimized for PIX4Dcloud
.tfw
World File for TIFF. Contains the location, scale, and rotation of the image
.prj Coordinate Reference System file
Orthomosaic .tiff (GeoTIFF) The image compression, file type (single, tiles), and image scale can be defined. Optimized for PIX4Dcloud
.jpg (Georeferenced with .jgw) The quality (%) and image size (S, M, L) can be defined
.tfw World File for TIFF. Contains the location, scale, and rotation of the image
.kml Generate Google Maps tiles using the standard KML
GCP marks .txt File with GCPs marks that can be imported into other PIX4Dmatic projects
.csv
Region of interest .kml File with the Region of Interest (ROI) used in the project
Undistorted images .jpg Export all the images undistorted
MTP marks .txt File with MTPs marks that can be imported into other PIX4Dmatic projects
.csv
mITP marks .txt File with mITPs marks that can be imported into other PIX4Dmatic projects
.csv
Image geolocations & orientations .csv The Camera type, the export CRS, and the orientation values can be defined
Quality Report .pdf Quality report to assess the accuracy and quality of projects
Layers
.dxf File with connected geometries generated in PIX4Dmatic for CAD use
ZIP SHP
SHP
GeoJSON
.csv
Videos & Views
.webm
Video audiovisual media file format generated using the Video & Views feature of PIX4Dmatic
Section view
.dxf
The .dxf file will contain the polyline(s) created within each Section view for CAD use.
Orthoplane
.jpg (Georeferenced with .jgw) Orthoplane file created and exported in PIX4Dmatic.
PIX4Dmatic project file
.p4m PIX4Dmatic project file that can be used to open existing projects in PIX4Dmatic or PIX4Dsurvey.
.opf Open Photogrammetry Format. OPF is the specification for a standardized file format designed for photogrammetry data.
Log files
.txt The Log Files contain useful information about the processing of the project. It describes the steps and substeps of processing, the actions taken, the warnings, and the errors during the processing
Processing templates
.json Custom processing templates can be configured and exported from a PIX4Dmatic project. For more information: Custom processing templates - PIX4Dmatic
