How to export, back up, and manage projects - PIX4Dfields
This article explains how to export and import PIX4Dfields projects. This process is particularly important, as the data can consume a significant amount of physical storage space.
本記事では
Where are projects stored?
Who can access the projects?
Batch export PIX4Dfields projects
Batch import PIX4Dfields projects
Export a single PIX4Dfields project
Import a single PIX4Dfields project
Delete a PIX4Dfields project
Share outputs using PIX4Dcloud
Export PIX4Dfields outputs to use them on third-party software
Projects are stored in the Data Storage folder on the computer used for processing.
To access it:
1- Go to Settings on the top-right:
2- Click on the Data storage folder:
- All projects and files generated will be stored in this folder. Several file types will be present
- To modify the storage location of your projects, select a different folder in the Data storage folder settings. Changing your data storage folder will not move existing projects to the new location.
- To move projects, please read: Batch export PIX4Dfields projects (.p4z)
The default location for the Data Storage folder is:
For Windows: C:\Users\USERNAME\Pix4Dfields
For Mac: Users/USERNAME/Pix4Dfields/Data
Projects are only visible to the Pix4D account used for processing. When logging in with a different Pix4D account, those projects will not appear. To transfer projects between Pix4D accounts, please read Batch export PIX4Dfields projects (.p4z).
Batch export of PIX4Dfields projects 🆕
Using the Export projects feature is recommended when moving multiple projects at a time or backing up.
To access the feature:
- Click the Settings icon at the top-right of the home screen.
- Click Export projects
- The Export projects menu appears.
- All projects will be selected by default.
- Order projects by clicking on the column name. You can order by Name, Size, or Created/Modified dates.
Ordering by Size is recommended to know which projects occupy the most space.
- The option "Do not export files that are stored in the data storage folder (advanced)" should be enabled only when exporting the project structure without including the files from the Data storage folder. This setting is intended for scenarios where the Data folder will be manually transferred to the desired location.
- Click Export project(s).
- Ensure sufficient disk space before exporting, otherwise Error 0175 will occur.
“Unable to detect sufficient disk space.
R0175: Caution, the selected folder may not have sufficient disk space, projects may fail to export correctly”
- Each selected project will be exported as a single .p4z file.
Batch import of PIX4Dfields projects 🆕
To import projects:
- Click Import projects
- Select one or multiple .p4z files to import.
- Click Open.
- Open a PIX4Dfields project.
- Click on Export.
- Click on Project.
- Select the folder where to save the project> click Select folder.
- Inside the selected folder (root folder), a .p4z file will be created.
- Download the .p4z file.
- Log in to PIX4Dfields
- Close PIX4Dfields (stay logged in)
- Double-click on the .p4z file
- A message Confirm to import project appears, click Continue
- The project is ready to use in the new device.
To delete PIX4Dfields projects:
- Go to the Dashboard.
- Click on the project settings.
- Click the Delete icon at the bottom.
With a PIX4Dfields license, uploading outputs to PIX4Dcloud directly from PIX4Dfields is possible. For more information: Share to Cloud - PIX4Dfields.
PIX4Dfields generates outputs that can be exported for use outside the software. See PIX4Dfields outputs and their formats here: PIX4Dfields inputs and outputs.
Warning:The export functionality is available only for commercial licenses. During the trial period, the results of PIX4Dfields cannot be exported. For more information about commercial licenses, contact our sales team here.
