ソフトウェアマニュアル > テーブルビュー -PIX4Dmapper
The software manual describes all the options that can be found in the PIX4Dmapper software. Offline version: Offline Getting Started and Manual (pdf). The following links contain a detailed description of these options:
New Project...
Open Project...
Recent Projects
Close Project
Download Project Files...
Upload Project Files...
Image Properties Editor...
GCP/MTP Manager...
Select Output Coordinate System...
Save Project
Save Project As...
Split into Subprojects...
Exit
Open Project...
Recent Projects
Close Project
GCP/MTP Manager...
Save Project
Save Project As...
Exit
Reoptimize
Rematch and Optimize
Quality Report...
Open Results Folder...
Outputs Status...
Generate Quality Report
Save Undistorted Images
Run Point Cloud Classification
Generate 3D Textured Mesh
Import Point Cloud for DSM Generation...
Generate DTM
Generate Contour Lines
Send Elevation Data (DSM) to eMotion
Send Map to eMotion
Processing Options...
Views
Menu bar entry
Left sidebar 3D View
Right sidebar
- Viewpoint
- Navigation Modes
- Perspective/ Orthographic
- Change Background...
- Display Sky
- New Processing Area
- New Scale Constraint
- New Orientation Constraint
- New Orthoplane
- New Video Animation Trajectory...
- New Polyline
- New Surface
Right sidebar
- Clipping Box
- Cameras
- GCPs and Manual Tie Points
- Automatic Tie Points
- Processing Area
- Point Clouds
- Objects
Views
