English
  • 検索欄が空のため、提案はありません。
遠方外れ値フィルター -PIX4Dsurvey
The Distant Outlier Filter detects points that are isolated from the main scene in all point clouds and recycles them.
The removed points are not used in further steps such as the terrain classification.
アクセス:
  • クリック プロセス Pix4Dsurvey process icon あるいは、
  • メニューバーで、「処理」>「遠隔外れ値フィルター」をクリックします。
Tip: It is recommended to run the Distant Outlier Filter before generating other results. For example, outliers in the point cloud can greatly influence the Terrain Filter process. Removing outliers will improve results.
PIX4Dsurvey Distant Outliers
Note: The Distant Outlier Filter focuses on finding points that are isolated and far away from the point cloud. It therefore cannot be used to filter out noise in the main body of the point cloud.
