Vectorization tools - PIX4Dmatic
PIX4Dmatic enables the vectorization of point clouds generated from project images. Users can precisely define the position of the geometry using original images, the point cloud, and the vertex editor and organize each geometry in layers.
Vectorization tools in PIX4Dmatic
How to use vectorization tools
How to edit vectorization results
To move the vertex in the 3D view
To add a vertex to exisitng geometry
To remove a vertex from exisitng geometry
To split a polyline
To join polylines
To continue polylines
To offset polylines
Editing geometry on images
Editing geometry with polyline simplification
Editing geometry with vertex alignment
Drape polyline
Layers
Export vector layers
Vectorization tools
The following vectorization tools (+Keyboard shortcut) are available in PIX4Dmatic:
Marker (M). Click on a point in the 2D or 3D view to create a marker.
Polyline (L). A minimum of two points need to be clicked in the 2D or 3D view to define a polyline.
Circle (C). To draw a circle, there are two different methods:
- Center, radius: The first vertex defines the center of the circle, and the second vertex defines a point on the circumference. Circle objects are always horizontal, and the elevation is defined by the point of the point cloud selected for the center. The second point must also be in the point cloud, but the circle will be drawn at the altitude of the center defined by the first point.
- 3 points. Select three points to adjust a circle that contains these three points.
Note: Circles can be created with a dedicated vectorizing tool in the 3D view. In 3D, circles will be drawn flat. In a section view, circles will be automatically aligned with the section.
Polygon (P). A minimum of three points needs to be clicked in the 2D or 3D view to define a polygon. By default, polygons are created as planar surfaces; however, this setting can be modified before creation by enabling or disabling the planarity toogle.
- If the planar geometry toggle is on, the height is the average of the vertex heights.
- If the planar geometry toggle is off, the height of each vertex is taken from the DSM.
Note: Polygons can also be created by using shared vertices. All polygons involved must be located on the same layer.
Polygon hole (H). A minimum of three points needs to be clicked in the 3D view to define a hole inside a polygon. To use, the polygon must be previously selected.
Arc (A). A minimum of three points needs to be clicked in the 3D view to define an arc.
Catenary (U). For vectorization of freely hanging power lines, chains, and ropes. A minimum of three points needs to be clicked in the 3D view.
Tip: When vectorizing catenaries, the order of the clicks is not important. The mathematical line that represents the catenary curve will be calculated based on all clicked points.
- Select the tool on the toolbar or use the keyboard shortcut.
- Left-click in the 2D or 3D view to create the first vertex to start the vectorization.
- Continue using the left-click to add more vertices to the geometry.
- (Optional) Press the Esc key to cancel the vectorization.
- To finish the geometry:
- Right-click in the 2D or 3D view to add the last vertex and finish the geometry.
- Alternatively, press Enter to accept the edits and finish the geometry.
- (Optional) Right-click again to exit the vectorization tool and to change to
Simple selection (default).
Note: Pressing Enter confirms the current geometry without adding any additional vertices. For faster vectorization, it is recommended to use right-click, which simultaneously places the final vertex and completes the geometry.
Use the Simple selection tool to select an object.
Click on the existing geometry.
Click on the vertex and drag it to the new position.
After moving the vertex to the new position, the edits are automatically taken into account, and you can continue creating new geometries or edit existing ones.
To add a vertex to existing geometry
Hover over the section where you would like to add the vertex.
Click to create a new vertex.
To remove a vertex from existing geometry
Click on the vertex and press the Delete key.
To split a polyline
Select the vertex where you want to split the object, it will turn purple.
Right-click on the vertex
Click Split polyline.
After the polyline is split, two separate polylines are created. The polylines share the vertex in which they were split.
To join polylines
Use the Simple selection tool to select the vertex of the first polyline.
Hold Shift and select the vertex of the second polyline.
With Shift still pressed, right-click on the shared vertex and click Join polylines.
After the polylines are merged, a single polyline is created.
Important: The polylines to be joined must be on the same layer.
- Use the Simple selection tool to select an object.
- Select the vertex where you want to continue the polyline. The polyline can only be continued from the ends.
- Right-click on the vertex
- Click Continue polyline
To offset polylines
- Right button and Offset polyline
- A new section view will be created on this polyline.
- While holding Alt or ⌥, drag the new polyline within the section view to place it in the desired location.
To move the vertex on the images:
- Use the Simple selection tool to click on an object.
- Click on the vertex on the image and drag it to the new position on at least two images.
- Press Enter to accept the edits.
- (Optional) Hit the Esc key to cancel the edit.
After moving the vertex to the new position on at least two images, the position of the vertex is automatically changed and updated.
It is possible to simplify a complex polyline by reducing or increasing the number of vertices. When the polyline is draped over the point cloud, the option to adjust its complexity is available. If the polyline was created manually, it consists of segments between vertex.
To modify the polyline simplification, follow these steps:
- Use the simple selection tool to select the polyline.
- To access the polyline simplification menu, click on Polyline simplification
located near the object name in the bottom left corner of the PIX4Dmatic window. - Adjust the level of simplification using the slider, which ranges between 1 and 10
- 1: Maximum level of simplification.
- 8 (default): Default level of simplification.
- 10: No simplification. All vertices are kept.
Aligning the vertices to a specific altitude is possible for objects with more than 1 vertex (polylines, polygons, volume polygons).
To vertically align the vertices:
- To access the vertical alignment menu, click Align Vertices
located near the object name in the bottom left corner of the PIX4Dmatic window and choose the desired alignment:
Align to the highest: All the vertices of the selected object are moved vertically to align with the highest vertex.
Align to the average: All the vertices of the selected object are moved vertically to align with the average altitude of all vertices of the selected object.
Align to the lowest: All the vertices of the selected object are moved vertically to align with the lowest vertex.- Custom height: All the vertices of the selected object are moved vertically to align with the given custom height.
Note: The Polygon must be set as a non-planar surface.
Drape polyline
Polylines can be draped over the point cloud to automatically conform to its surface. This process generates vertices that align with the uppermost points of the point cloud geometry.
To use the drape polyline tool:
- Select a polyline.
- Right-click on the selected polyline to display a contextual menu.
- Choose the Drape polyline option from the contextual menu.
- The polyline will be draped over the visible point cloud, and the polyline simplification window with the Complexity slider will appear.
- (optional) The Complexity slider can be adjusted until the draped polyline fits the required specifications.
Tip: Drape polyline feature is also available in Section view. For further information on how to utilize this feature, please follow this link.
Layers
All geometries created with the vectorization tools are organized into Layers. These layers help manage and categorize the various geometries according to the specific needs of the project.
The properties of the layers are the following:
- Color: Change the color of the layer. All the geometries inside the layer will be colorized with the same color.
- Line width: Change the width of the line (Polyline) or the width of the perimeter line (Polygon and Circle) inside the layer.
- Select all: Select all the entities inside of the layer.
- Rename: To change the name of the layer.
- Triangulate geometries: Update outdated layer geometries if calibrated cameras are up-to-date
- Compute all outdated volumes: In case the volume calculation becomes outdated, this tool calculates all the volumes at once.
- Export: Export the geometries by selecting the format and the layers.
- Delete: The selected layer and all the content within will be deleted.
- Layer lock. It is now possible to a lock layer. When a layer is locked, the geometries contained within cannot be modified. Locked geometries will appear grayed out, clearly indicating that they cannot be altered.
The vector layers that need to be exported can be filtered to match your requirements. It is possible to select specific layers [1] and/or filter by object type [2].
The vector layers can be exported in .dxf, .zip shp, .shp, GeoJSON, and .csv (only for makers) formats [3]. If Export vertices as markets are activated, all the vertex of the geometries will be exported as a marker.
Note: DXF (for Autodesk) will export polygons as triangle meshes. For order third-party software, the option "DXF" will convert the polygons into polylines (perimeter only)
If the .csv format is selected (comma-separated values), only markers will be exported. The format of the resulting table can be set.
| Format | Meaning |
| PENZDL | Point name, Easting coordinate, Northing coordinate, Z coordinate, Description, Label |
| PNEZDL | Point name, Northing coordinate, Easthing coordinate, Z coordinate, Description, Label |
| PXYZDL | Point name, X coordinate, Y coordinate, Z coordinate, Description, Label |
| PYXZDL | Point name, Y coordinate, X coordinate, Z coordinate, Description, Label |
| PENZD | Point name, Easting coordinate, Northing coordinate, Z coordinate, Description |
| PNEZD | Point name, Northing coordinate, Easthing coordinate, Z coordinate, Description |
| PXYZD | Point name, X coordinate, Y coordinate, Z coordinate, Description |
| PYXZD | Point name, Y coordinate, X coordinate, Z coordinate, Description |
| PENZL | Point name, Easting coordinate, Northing coordinate, Z coordinate, Label |
| PNEZL | Point name, Northing coordinate, Easthing coordinate, Z coordinate, Label |
| PXYZL | Point name, X coordinate, Y coordinate, Z coordinate, Label |
| PYXZL | Point name, Y coordinate, X coordinate, Z coordinate, Label |
| PENZ | Point name, Easting coordinate, Northing coordinate, Z coordinate |
| PNEZ | Point name, Northing coordinate, Easthing coordinate, Z coordinate |
| PXYZ | Point name, X coordinate, Y coordinate, Z coordinate |
| PYXZ | Point name, Y coordinate, X coordinate, Z coordinate |
| ENZ | Easting coordinate, Northing coordinate, Z coordinate |
| NEZ | Northing coordinate, Easthing coordinate, Z coordinate |
| XYZ | X coordinate, Y coordinate, Z coordinate |
| YXZ | Y coordinate, X coordinate, Z coordinate |
