Technical release notes (2.XX) - PIX4Dmatic
This article summarizes PIX4Dmatic version 2.0 and above. This includes new capabilities, additional updates, and bug fixes.
Download the latest or authorized older PIX4Dmatic versions from the Download page after signing in with your license account. For more information click here.
To access PIX4Dmatic 1.0-1.86 technical release notes, please visit: Technical release notes (1.XX) - PIX4Dmatic
Disclaimer: The preview version contains new features and bug fixes. Documentation and support are not available. We recommend testing the preview version before using it for production work.
| Version | Release date | Release Type | Installers |
| 2.13.0 | Novembre 2, 2026 | Preview | Windows | Mac |
2.13.0
All licenses
Additional Updates and Improvements
- Added the ATP reprojection error to the quality report and the quality report panel
- Added the median number of keypoints per image to the quality report and the quality report panel
- Added the median number of matches per calibrated image to the quality report panel
- Added a terrain icon to layers in the content panel, shown on hover, to set or unset a layer as terrain in one click
- Updated the trial tag to show the remaining Pro trial days for Analyst and Standard licenses, with a link to the Pro upgrade guide. Additionally, the "Plans & licenses" page now opens directly in the current organization
- Reduced the disk space used by DSMs, DTMs, and orthomosaics by about 3 times
- Improved the speed of trimming, patching, and importing DSMs and orthomosaics, and of volume calculations
Bug fixes
- Security patches and bug fixes
- Fixed an issue where the "Color by elevation" settings showed fewer decimals for elevation values than the DSM and DTM range sliders
- Fixed an issue where logging in with SSO could open a different account than the email entered, when another account was still logged in to the web browser
- Fixed an issue where downloading a recent PIX4Dcloud project would fail to import its orthomosaic
PIX4Dmatic Standard
New capabilities
- Added new calibration options in the processing panel to control image pair matching, including the matching strategy (Standard, Auto, Geometrically verified), pipeline strategy, rematch type, and image pair settings based on capture time, GPS, tie points, ground overlap for terrestrial images, and pre-matching. Additionally, the reoptimize rematch option is now a dropdown menu
- Added support for importing MP4 and MOV videos from the "Import" menu or by drag-and-drop. Frames are extracted as images every set number of frames or seconds and added to a new or existing project. Extracted images are not geolocated
- Improved the quality of thermal orthomosaics with an enhanced non-uniformity correction (NUC) and radiometric correction, and added new emissivity presets for barley, grapevine, lawn, maize, pasture, soybean, and wheat
- Improved the calibration results of projects using the "Flat scene low texture" template, which now calibrates as in PIX4Dmatic 2.3 and earlier
PIX4Dmatic Analyst
- No updates specific to this license
PIX4Dmatic Pro
New capabilities
| 2.12.0 | October 12, 2026 | Preview | Windows | Mac |
2.12.0
All licenses
New capabilities
Migrated DSM, DTM, and orthomosaic settings from the content panel context menu to a dedicated section in the properties panel, adding value distribution histograms above the range slider
- Improved interactivity in the PIX4Dcloud download dialog project tree by adding row hover effects, dynamic expand/collapse arrow feedback, and click-to-expand folder selection
Bug fixes
- Fixed an issue where executing the polyline offset workflow would fail to display the offset dialog
- Fixed an issue where opening a project would cause the status center to display "Opening TIN meshes" even when no TIN meshes were present
- Stability improvements
- Security patches
PIX4Dmatic Standard
- Added support for fixed-sized mesh generation with 32k textures
- Redesigned DSM input selection in the processing panel by replacing multi-select comboboxes with dedicated dropdowns for input type (e.g., point clouds, Gaussian splats) and specific dataset selection
- Added a direct link to the images relocation dialog in the status center when processing fails due to missing or moved image files
- Removed misleading status center warnings regarding missing IMU EXIF data during image import
- Fixed an issue where generating orthomosaics in merged projects with mixed camera models might cause processing to fail in some cases
Bug fixes
- Fixed an issue where importing GCPs after calibrating un-geotagged images would fail to re-center the scene on the GCP median position, resulting in poor deliverable quality
- Improved processing speed for terrestrial and mixed scenes in Gaussian splatting
PIX4Dmatic Analyst
PIX4Dmatic Pro
Bug fixes
| 2.11.0 | September 23, 2026 | Preview | Windows | Mac |
2.11.0
All licenses
New capabilities
Introduced detachable project tabs, enabling users to drag project tabs out of the main tab bar and open them as separate standalone windows for side-by-side viewing and multi-project analysis
- Relocated access to the Polyline simplify and Align vertices tools from the properties panel to the content panel geometry menu and the viewer right-click context menu for improved tool accessibility
- Added a dynamic triangle count preview that updates in real time when adjusting the mesh level of detail slider in the PIX4Dcloud upload dialog
- Added an option in the custom report export panel to use orthomosaics as the background for custom report overview plans, volumes reports, and inventory screenshots
Bug fixes
- Fixed an issue where operating within a strict proxy environment would cause some operations to bypass configured proxy settings and fail to connect
- Fixed an issue where exporting DXF files would cause the progress indicator to remain stuck at 100% while writing the file
- Enhanced the Focus on selection command to support region of interest objects
- Fixed an issue where rendering a DSM in 2D view with hillshading mode enabled would cause visual artifacts to appear on specific interpolation setups
- Security patches
PIX4Dmatic Standard
New capabilities
- Generate and export single tile meshes with fixed texture size and maximum triangle count
- Optimized thermal workflows by removing the DJI SDK requirement during initial thermal image and OPF imports, shifting SDK verification, parameter calculation, and missing-driver warnings to the processing panel prior to thermal orthomosaic processing
- Added an option in the preferences dialog to select a custom DJI SDK installation path for thermal processing
- Added temperature unit selection to the export dialog and processing panel for orthomosaic GeoTIFF exports
- Added lines connecting input and optimized positions in the camera and tie point plots within the quality report
Bug fixes
- Fixed an issue where running dense point cloud generation or AI tools on systems with outdated NVIDIA CUDA drivers would cause application crashes instead of automatically falling back to CPU processing
PIX4Dmatic Analyst
- Enhanced logging in the status center during Surveying panel processing to display the active point cloud or grid input dataset name
PIX4Dmatic Pro
New capabilities
Bug fixes
| 2.10.0 | August 27, 2026 | Stable | Windows | Mac |
| 2.10.1 | September 7, 2026 | Stable | Windows | Mac |
| 2.10.2 | Septembre 14, 2026 | Stable | Windows | Mac |
| 2.10.3 | Septembre 23, 2026 | Stable | Windows | Mac |
| 2.10.4 | Octobre 28, 2026 | Stable | Windows | Mac |
2.10.4
All licenses
Additional updates and improvements
Improved the compatibility of exported GeoTIFF files with PIX4Dcloud
Bug fixes
- Addressed critical security vulnerabilities. We strongly recommend all users update to this version
- Fixed a crash that could occur in the 2D view while loading DSMs, DTMs, or orthomosaics
- Fixed crashes that could occur in the 2D and 3D views when the GPU memory is full
- Fixed a crash that could occur when marking MTPs in the image viewer
- Fixed a crash that could occur when switching users several times
- Fixed a crash that could occur when exporting to OPF a project whose only point cloud is a fused point cloud
- Fixed a crash that could occur when canceling an upload to PIX4Dcloud
- Fixed an issue where polylines and polygons could disappear from the 3D view
- Fixed an issue where the quality report would show wrong calibration processing settings for projects processed with a custom template
PIX4Dmatic Standard
Bug fixes
PIX4Dmatic Analyst
- No updates specific to this license.
PIX4Dmatic Pro
Bug fixes
2.10.3
All licenses
Bug fixes
- Fixed macOS crash when displaying legacy 3D meshes with high-resolution (32K) textures
PIX4Dmatic Standard
Bug fixes
- Fixed an issue where editing a CRS during GCP import and canceling the import would cause the dialog to retain the canceled CRS state and display an erroneous data loss warning upon re-importing GCP files
PIX4Dmatic Analyst
PIX4Dmatic Pro
Bug fixes
2.10.2
All licenses
Bug fixes
- Fixed undefined resolution in the TIN export dialog
- Fixed "Focus on selection" for the Region of interest (ROI)
2.10.1
Information: If your Windows username contains non-ASCII characters, DJI thermal image processing may fail. To resolve this, please enable the "Beta: Use Unicode UTF-8 for worldwide language support" setting in your Windows Region settings.
For more information, please refer to this article
All licenses
Known issues
- Starting from this version, OPF projects containing GCPs with a coordinate reference system whose definition has multiple available geoid models can no longer be imported. This affects OPF projects generated by PIX4Dmatic 2.9 or earlier.
PIX4Dmatic Standard
Bug fixes
- Fixed an issue that prevented DJI thermal images from being processed.
PIX4Dmatic Analyst
PIX4Dmatic Pro
Bug fixes
2.10.0
Important notice for DJI thermal users. Version 2.10.0 contains a known issue affecting thermal image processing for DJI cameras only. All RGB imagery and non-DJI thermal datasets work normally. If your workflow requires DJI thermal processing, please download or remain on 2.9.0. A fix will be published as soon as possible.
Affected licenses: PIX4Dmatic Standard and PIX4Dmatic Pro
All licenses
- Added support for the South Korean geoid model KNGeoid26. Users can now import and use this specific model as a user-provided geoid model for EPSG:5193 "KVD1964 height"
- Fixed an issue where Windows Smart App Control would block PIX4Dmatic from launching
Bug fixes
- Fixed an issue where uploading projects to PIX4Dcloud (via the "Process" or "Upload" workflows) would occasionally fail
- Fixed an issue where certain processing folders were left on the disk when a newly created project was closed without saving
- Fixed an issue where mITPs would not render in their correct positions on high-resolution displays (such as 4K monitors)
- Fixed an issue in the properties panel where the maximum keypoint count for ATPs incorrectly displayed the same value across all projects
- Fixed an issue in the properties panel where the volume recomputation dropdown menus were not correctly pre-filled after editing a volume's vertices
- Fixed an issue in the properties panel where the resolution for the DSM and orthomosaic was displayed with incorrect units
- Fixed an issue where the image viewer would sometimes reset the zoom when adding marks, editing vertices, or removing images
- Fixed an issue where importing large geometry files would fail to display progress in the status center and could not be canceled
- Fixed an issue in the report panel where the layer selection dropdown menus for the overview plan and inventory sections were not sorting layers consistently
- Fixed an issue where DSMs downloaded from PIX4Dcloud displayed incorrect minimum and maximum elevation values
- Fixed an issue where completing a polygon hole would incorrectly switch the active tool back to selection mode
- Fixed an issue where the geoid model was omitted from the coordinate reference system definition when exporting GCPs to the OPF format<
- Fixed an issue in the Welcome view where an empty project placeholder would incorrectly appear at the end of the list when using the grid layout and sorting by name
- Fixed security vulnerabilities in third-party libraries
Known issues
- Starting from this version, OPF projects containing GCPs with a coordinate reference system whose definition has multiple available geoid models can no longer be imported. This affects OPF projects generated by PIX4Dmatic 2.9 or earlier (learn more)
PIX4Dmatic Standard
- Improved the mesh generation to prevent color balancing artifacts across tiles and increase effective texture resolution. Additionally, fixed an issue that could result in visible holes at mesh tile boundaries
- Automatically export offset file alongside Gaussian splats when saving to the PLY format
- Fixed an issue that could slow down the merging process when working with large input projects
Bug fixes
- Fixed an issue where adding new images to a previously calibrated project would incorrectly trigger a reoptimization process instead of a full calibration
- Fixed an issue where an orthomosaic in the 3D view would display distorted, diamond-shaped pixels instead of correct square pixels
PIX4Dmatic Analyst
Bug fixes
- Fixed an issue where generating a DTM in a project imported from an OPF file would silently fail
- Fixed an issue where the "Use terrain layers as breaklines" toggle would automatically enable itself after generating a TIN
- Fixed an issue in the Surveying panel where clearing the contents of a text input field would unexpectedly lock the field, preventing users from typing new text
PIX4Dmatic Pro
- Improved the overall visual quality and geometry of Gaussian splatting models while reducing memory usage during generation
- Increased the default number of rendered Gaussian splats to 10 million to enhance visual fidelity for most users. Additionally, the maximum limit in Preferences has been raised to 20 million, allowing users with powerful hardware to render massive projects more smoothly
Bug fixes
| 2.9.0 | August 6, 2026 | Preview | Windows | Mac |
2.9.0
All licenses
- Enhanced the properties panel to display specific settings and properties for thermal datasets
- Added support for filtering images in the image viewer by camera sensor name
- Enhanced the user interface to highlight the difference between Discovery and Trial modes by changing the Discovery tag to orange and adding direct "Start trial" links to the Processing and Surveying panels
- Improved trial onboarding by guiding users directly to their active license, adding a "NEW" tag for recent licenses, and introducing a refresh button in the "Organizations and licenses" dialog
- Added a button in the "Organizations and licenses" dialog that allows users to copy license details to the clipboard
- Added a new "Display" page in preferences to manage visual settings and define default distance and temperature units for new projects
- Added individual size adjustment for GCPs, checkpoints, and MTPs in the content panel
- Added direct links in the status center to open exports or navigate to the destination folder
- Improved quality report export progress tracking on Windows
Information
- Updated Trial licenses to include full export capabilities, matching the permissions of the Pro edition
Bug fixes
- Fixed several issues where project deliverables were incorrectly marked as outdated
- Fixed an issue that caused visual flickering in exported video flythroughs when working with large projects
- Fixed an issue in the 3D viewer where hidden Gaussian splats could still be selected
PIX4Dmatic Standard
New capabilities
Added support for processing thermal datasets from FLIR, DJI, and radiometric TIFF cameras to generate georeferenced 2D thermal orthomosaics. Users can visualize and inspect temperature values in Kelvin, Celsius, and Fahrenheit using dedicated thermal color palettes
- Enabled GeoTIFF export for thermal orthomosaics
- Improved the calibration to deliver faster processing on computers without an NVIDIA GPU. This update also improves calibration results when using MTPs, and ensures reliable processing cancellation
- Added legacy PIX4Dmapper exports for GCPs and calibrated cameras
- Improved error and warning details when adding images
- Fixed DSM legend elevation values in the quality report not matching the display unit
Bug fixes
- Fixed an issue in the image viewer where the zoom level would reset after marking a manual tie point
PIX4Dmatic Analyst
PIX4Dmatic Pro
New capabilities
- Added a beta option to generate DSMs and orthoplanes directly from Gaussian splats
- Improved the overall visual quality and geometry of Gaussian splatting models. This update delivers higher model opacity, cleaner edges, richer texture details, and better point cloud completeness for dark or poorly illuminated scene elements
Bug fixes
| 2.8.0 | July 14, 2026 | Preview | Windows | Mac |
Follow this article for troubleshooting: Windows SmartScreen warning on PIX4Dmatic installer
2.8.0
All licenses
New capabilities
Added interactive 3D surface visualization for DSMs, DTMs, and orthomosaics. Supports styling with elevation gradients, orthomosaic overlays, and hillshading, alongside vectorization tools
- Added support for exporting and importing point cloud normals within LAS files using standard naming conventions (Normal X/Y/Z)
- Upgraded the project deletion process on the Homepage to move files to the system trash or recycle bin instead of permanently erasing them
Information
- PIX4Dcloud now supports downloading Gaussian splat, DSM, and orthomosaic results directly for seamless opening inside PIX4Dmatic
- Site localization can now be performed using our localization calculator enabling accurate data transformation and alignment within a local coordinate reference system
Bug fixes
- Fixed a memory leak that occurred when displaying orthomosaics in the 2D view
- Fixed an issue where the Cmd+C keyboard shortcut failed to copy the text of the selected line in the status center on macOS
- Fixed a regression introduced in version 2.7.0 that caused the calibration process to crash under certain conditions
Known issues
- Volumes may remain marked as "outdated" after recomputing if a classification was previously performed on the source point cloud
PIX4Dmatic Standard
PIX4Dmatic Analyst
- Updated the contour line label spacing slider to operate on a logarithmic scale and increased the maximum spacing limit to 1000m
PIX4Dmatic Pro
| 2.7.0 | June 22 , 2026 | Preview | Windows | Mac |
2.7.0
All licenses
New capabilities
Added support for restricting DSMs, DTMs, and orthomosaics to the current region of interest (ROI) via a new button in the content panel, allowing users to cut away unwanted parts or export small sections without full project reprocessing
- Improved custom report overview plans by automatically using visible 3D data (point clouds, meshes, Gaussian splats, or TINs) as a background when an orthomosaic is missing or manually excluded
- Improved GeoTIFF files export times for both local files and uploads to PIX4Dcloud
- Added support for importing and exporting orthomosaics within OPF projects
- Updated 3D camera visualization to reflect actual image aspect ratios and focal lengths
- Added the "Collapse/Expand all" icon to the Reports panel
Information
- Upgraded the 3D rendering backend by replacing OpenGL with Direct3D (Windows) and Metal (macOS) to deliver improved performance. While extensive testing has been conducted, please note that some minor instabilities may occur. Should you encounter any repetitive issues, please ask Pixie then open a support ticket
Bug fixes
- Fixed a calculation error in DSM/DTM custom resolution settings that caused inaccurate unit conversions when switching between display units
Known issues
PIX4Dmatic Standard
- Enhanced the mesh generation algorithm to mitigate surface defects and large bubbles at project boundaries caused by surface trimming failures. Additionally, implemented a speed optimization for texturing large-scale scenes
Known issue
A regression in version 2.7.0 causes the calibration process to crash in certain cases. This will be resolved in the 2.8.0 release
PIX4Dmatic Analyst
PIX4Dmatic Pro
Known issue
| 2.6.0 | June 1, 2026 | Preview | Windows | Mac |
2.6.0
All licenses
- Introduced three visualization modes for DSM and DTM layers: Color map, Hillshading (Greyscale), and Combined (new default), along with a vertical exaggeration slider to control shading intensity
- Added the ability to reorder project tabs via drag-and-drop. When a large number of projects are open, introduced navigation arrows and mouse-wheel scrolling to easily scroll the project tab bar
Enabled the properties panel for ATPs, Gaussian splats, meshes, DSMs, orthomosaics, and orthoplanes; these items can now be selected directly from the Content panel. Added a description field for point clouds
- Added a context menu option in the Content panel to detach geometries from sections
- Added the current organization name next to "Drive" within the PIX4Dcloud dialog
- Added support for importing and exporting DSM and DTM items in OPF format
Information
- Added earlier warning notifications on the login screen if an internet connection is missing at app start-up or during the email verification step
- Added support for the GCG05 geoid model to accurately process German datasets using the DHHN92 vertical coordinate reference system
- Improved compatibility with Trimble CAL files containing Helmert datum transformations
Bug fixes
- Improved densification VRAM management, preventing potential processing crashes
- Fixed an issue where the polyline simplification dialog appeared in both the 3D and section views simultaneously instead of only the active workspace view
Known issues
- This version is not compatible with the PIX4Dmapper “Open in PIX4Dmatic” feature
- Visual artifacts, such as missing triangles, may occasionally appear in the volume surface; these artifacts are purely visual and do not affect the actual volume computation results
PIX4Dmatic Standard
Information
- Added pre-upload validation for PIX4Dcloud processing to block unsupported un-geolocated images
Bug fixes
- Fixed an issue where sky masks were not being re-generated after a project underwent recalibration or reoptimization
- Resolved an issue where a dense point cloud generated with the sky filter enabled would incorrectly remain marked as "outdated" after a project readjustment
- Fixed processing panel behavior for imported
.p4sprojects. Toggling processing steps no longer deselects connected steps unexpectedly. Unavailable inputs can now be inspected to determine why processing steps are disabled - Regenerating a mesh now automatically forces it to be visible in the 3D view, even if it was hidden before being deleted
PIX4Dmatic Analyst
Bug fixes
- Regenerating contour lines now automatically forces them to be visible in the 3D view, even if they were hidden before being deleted
PIX4Dmatic Pro
Upgraded the Gaussian splatting algorithm, bringing significant performance and quality improvements:
Faster processing: achieves an average 30% speedup during generation
Lower system requirements: reduced VRAM footprint, allowing the algorithm to run on GPUs with at least 10GB of VRAM
Higher accuracy: improved geometric accuracy, particularly on flat, texture-rich surfaces
Information
Bug fixes
- Fixed an issue where the dense point cloud would incorrectly become "outdated" after generating Gaussian splats with the sky filter enabled
| 2.5.0 | May 7, 2026 | Stable | Windows | Mac |
| 2.5.1 | May 12, 2026 | Stable | Windows | Mac |
| 2.5.2 | May 26, 2026 | Stable | Windows | Mac |
| 2.5.3 | June 22, 2026 | Stable | Windows | Mac |
| 2.5.4 | July 15, 2026 | Stable | Windows | Mac |
2.5.4
All licenses
Bug fixes
PIX4Dmatic Standard
Bug fixes
Various bug fixes
PIX4Dmatic Pro
Bug fixes
Various bug fixes
2.5.3
All licenses
Bug fixes
2.5.2
All licenses
Bug fixes
- Fixed a regression where the point size in the section view was restricted to a very small size
PIX4Dmatic Standard
Bug fixes
Fixed an issue where mesh exports in SLPK format failed to import into ArcGIS
Fixed an issue where the calibration process would crash due to incompatible GPU drivers by adding a driver compatibility check and an automatic fallback to CPU processing
PIX4Dmatic Pro
Bug fixes
- Fixed an issue where mesh exports in SLPK format failed to import into ArcGIS
- Fixed an issue where the calibration process would crash due to incompatible GPU drivers by adding a driver compatibility check and an automatic fallback to CPU processing
2.5.1
PIX4Dmatic Pro
Bug fixes
- Fixed an issue where Gaussian splats generation failed when the project name or folder path contained non-ASCII characters
2.5.0
All licenses
- Updated the custom report screenshots to include visible meshes
Information
- PIX4Dmatic Pro trials are reset for everyone, even if a PIX4Dmatic trial was already activated in the past
Bug fixes
- Fixed a freeze occurring when cancelling the "Share to PIX4Dcloud" upload process
- Removed excessive pixel smoothing in the image viewer to improve the clarity of pixels when marking tie points and geometries
- Fixed an issue where the color palettes for "Color by elevation" and "Color ATPs by relative confidence" were not displaying correctly
- Fixed an issue where newly modified keyboard shortcuts were not immediately active
- Fixed an issue where the DSM and DTM slider positions were not saved within the project settings
- Fixed an issue where point cloud classification settings were automatically toggled on when opening a project, regardless of whether they were previously disabled
- Fixed an issue where point clouds with visibility toggled off could not be exported from the content panel
Known issues
PIX4Dmatic Standard
- Enabled read-only access to the camera internals dialog during active processing
Bug fixes
- Fixed an issue where manual tie points (MTPs) were ignored when uploading to PIX4Dcloud for processing if the GCP coordinate reference system was not set
- Resolved an issue where image depth data from PIX4Dcatch was not properly utilized during reoptimization
- Improved the camera offset logic to apply inputs to all cameras when no specific selection is made, while respecting the selection otherwise
- Fixed a regression where depth maps were computed at an incorrect resolution, which negatively impacted processing times
Known issues
- Mesh exports in SLPK format produced in version 2.3.0 or later failed to import into ArcGIS
PIX4Dmatic Analyst
- Added support for circle and arc geometries as breaklines when generating TINs with terrain layers
Bug fixes
- Improved the performance and stability of surface comparison and volume computation
PIX4Dmatic Pro
- Improved the quality of mesh previews and meshes generated from Gaussian splats point clouds
Bug fixes
- Fixed an issue where cancelling “Gaussian splats & dense point cloud” left the dense point cloud in an invalid state
Known issues
- Gaussian Splatting processing may crash when file names or directory paths contain non-latin characters. As a workaround, please use only alphanumeric characters
| 2.4.0 | April 20, 2026 | Preview | Windows | Mac |
2.4.0
All licenses
New Capabilities
- Added the ability to pause and resume main processing tasks via the Status center or Process menu
- Upgraded the custom report with an updated full volume report featuring visual overviews and detailed data tables, and an inventory section with updated volume metrics and screenshots
- Added support for downloading projects processed in PIX4Dcloud and directly opening calibration and dense point cloud results in PIX4Dmatic. This includes projects initiated via the PIX4Dmatic cloud processing option, the PIX4Dcloud web interface, PIX4Dcatch, and PIX4Dmapper (for projects processed since March 2026)
- Enabled full vectorization support on Gaussian splats, matching the point cloud workflow
- Added the PLY export format for Gaussian splats, which can be uploaded to PIX4Dcloud
- Added the ability to reorder bottom panels and pull them out into separate windows
- Added an option to display image names in the viewer, which can be toggled via the toolbar or context menu
- Added Czechia grid file to support ETRS89 (EPSG:4258) transformations to compound CRSs EPSG:5513+8357 and EPSG:5514+8357 (S-JTSK / Krovak + Baltic 1957 height)
- Removed the hover delay, allowing tooltips to display instantly
- Improved the progress reporting during Gaussian splat generation
- Set the default sort order for ASPRS classes to ascending across all relevant dropdown menus
- Added an option in the Help menu to dismiss all unviewed onboarding messages
- Added support for OPF 1.2
Information
- For optimal performance and stability, please ensure your NVIDIA graphics drivers (GPUs) are updated to the latest version.
Bug fixes
- Fixed an issue where Gaussian splats would flicker in exported video flythroughs
- Fixed a crash that occurred in certain cases when closing the application on macOS
- Fixed an issue where camera 3D representations could appear incorrectly after importing an OPF project
Known issues
PIX4Dmatic Standard
- Added a new "No GPS" calibration template for processing challenging datasets that lack reliable geotags or GCPs (e.g., underwater or non-PIX4Dcatch indoor projects)
- Improved calibration robustness for projects with partial or missing RTK signals. Users can now manually define the level of trust in geotags via new externals confidence options (Auto, Low, Standard) for the PIX4Dcatch and Interior scene calibration templates in the “Trusted location and orientation” pipeline
- Improved calibration for flat and low-texture scenes (reducing camera pose bending and IMU bias) and for indoor terrestrial projects using ITPs
- Added support for new DJI cameras and resolutions, including:
- Mini 3 (FC3582 6.7mm, 8064x6048)
- Matrice 3TD (M3TD 6.7mm, 4032x3024)
- Mini 5 Pro (FC9313 8.7mm at 4096x2304, 4096x3072, and 8192x6144)
- L3 models (L3 14.4 at 6144x4096 and 12288x8192, with correct orientation detection for the dual camera)
- Added logic to prefer higher-quality Gaussian splatting‑derived depth maps over PIX4Dcatch depth maps for mesh generation and object selection
Bug fixes
- Fixed an issue for images with positions where incorrect orientation values were used for calibration instead of being treated as missing when values were either absent from EXIF or manually removed
PIX4Dmatic Analyst
New Capabilities
- Added a new surface comparison tool in the Surveying panel that allows cut/fill analyses between TIN or point cloud surfaces, optionally using boundary geometries. These surfaces can also now act as base surfaces when recomputing volumes directly from the Properties panel
PIX4Dmatic Pro
New Capabilities
- The Aerial processing template for Gaussian splats processing has been replaced by Nadir and Oblique options, aligning with PIX4Dcloud for optimal results
- Improved Gaussian splatting processing time for JPG images by speeding up the loading time
Bug fixes
- Fixed an issue where compatible NVIDIA GPUs (such as Quadro series) were not correctly detected for Gaussian splatting
- Fixed issues to reduce holes in meshes generated from dense point clouds created from Gaussian splats
| 2.3.0 | March 24, 2026 | Preview | Windows | Mac |
2.3.0
All licenses
New Capabilities
Volume computation improvements:
Added cut/fill colorization for computed volumes in the 3D view, using height differences to easily distinguish between cut and fill areas
Volumes can now be recomputed directly from the Properties panel
Information
- Supported macOS versions are now Sequoia (15.x) and Tahoe (26.x). Sonoma (14.x) is no longer supported
- Updated the Windows installer to support desktop Gaussian Splatting processing. The new installer does not automatically replace previous versions; older versions should be manually uninstalled from the “Add or Remove programs” list
Bug fixes
- Fixed an issue where the CSV geometry export custom headers Easting and Northing were incorrectly swapped for certain coordinate reference systems
Known issues
- On macOS, the application may crash when closing in certain cases
PIX4Dmatic Standard
- Improved the calibration for terrestrial acquisitions, delivering better scene reconstruction for datasets with weak, missing, or no GPS data
Information
- To prevent crashes during calibration, please ensure your NVIDIA drivers are up to date. This version of PIX4Dmatic uses requires driver version 570 or newer for optimal stability and performance
Bug fixes
- Fixed an issue where processing in the cloud would fail if Gaussian splats were selected as an output
- Fixed an issue where exporting to LAS/LAZ was incorrectly blocked for projects containing terrain classification when using a Standard license
PIX4Dmatic Analyst
New Capabilities
- Added support for using a single TIN as the "To surface" for volume computations
- Improved the accuracy of progress reporting and the responsiveness of cancellation when generating TIN surfaces
PIX4Dmatic Pro
New Capabilities
- Added support for generating Gaussian splats. Visualize splats in 3D and share results directly to PIX4Dcloud. Leveraging Gaussian splatting technology now allows for higher-quality point clouds, DSMs, meshes, and orthomosaics compared to standard processing. Note: Generation is currently supported on powerful NVIDIA GPUs
Information
Bug fixes
| 2.2.0 | March 2, 2026 | Preview | Windows | Mac |
2.2.0
All licenses
New Capabilities
- Added support for viewing the elevation difference between the base surface and the point cloud in the status bar by hovering over a volume in the 3D viewer
- Added a new settings dialog for volume computation, allowing for the customization of input point clouds, classification filters, and grid resolution
- Added support for viewing the coordinates of points on a TIN surface by hovering the cursor over it in the 3D viewer
- The software now retains the specific settings and point clouds used for each volume computation, automatically flagging volumes as "outdated" if the underlying source data changes
- All steps in the processing panel are now selectable. Checking a desired output automatically selects all required prerequisite steps
- Added the Window > Save current layout as default option, allowing the current arrangement and visibility of panels and tabs to be applied automatically to all new projects
- Improved the layout and stability of PDF reports on macOS, ensuring parity with the Windows version. This update preserves image links and resolves resource management issues during the export process.
Information
- Discontinued support for NVIDIA GPU architectures Kepler and older to focus on modern hardware optimization
Bug fixes
- Fixed an issue where the default CRS was not consistently suggested when creating a new project from imported images
- Fixed an issue where the scene origin was not recentered when changing the CRS for imported images, which previously led to precision errors and sparse point clouds during densification
Known issues
- When a project is uploaded to PIX4Dcloud for processing, and the "Gaussian splat" option is selected, processing will fail. The workaround is to use a previous software version until it is fixed in the next release.
PIX4Dmatic Standard
PIX4Dmatic Analyst
New Capabilities
- LandXML import: import multiple TIN surfaces via File > Import > TINs or drag-and-drop
- Added the capability to export several TIN surfaces into a single LandXML file
PIX4Dmatic Pro
New Capabilities
| 2.1.0 | February 11, 2026 | Preview | Windows | Mac |
2.1.0
All licenses
New Capabilities
- Added the ability to customize keyboard shortcuts directly in the Preferences dialog
Added support for the SHARE SLAM S20 camera
Added support for new cameras: Wingtra INSPE, MAP61, RX1RX2, SUR61, SONY DSC-RX1RM3, SONY ILX-LR1 with 85mm lens
- Updated the 2D basemap to the latest version, ensuring access to the most recent map data
- Added the option to select the language for quality reports and custom reports when exporting via the report panel
- Added a "Load more" button to the PIX4Dcloud resource list, allowing users to access all datasets, sites, and folders beyond the previous 25-item limit
- Consolidated settings and menu options into a single 3-dot menu for all content panel items to improve consistency
- Added a Cancel button to the login dialog during SSO authentication, allowing users to abort the request and retry without restarting the application
Bug fixes
- Fixed an issue where the status bar would flicker or display the DSM/DTM elevation instead of the correct coordinates when hovering over objects in the 2D view
- Fixed crash when opening native file explorer on Windows
- Fixed an issue where the point cloud section in the content panel could become unresponsive if the Remove outliers tool failed while processing a subset of point clouds
PIX4Dmatic Standard
- Added an Export option directly to the content panel menus for DSM, ROI, mesh, and orthomosaic
- Updated the calibration process to automatically discard corrupted images instead of failing the entire process, allowing calibration to continue
Bug fixes
- Fixed an issue where position and orientation cells in the Cameras table became uneditable after their values were removed
PIX4Dmatic Analyst
New Capabilities
- Added support for multiple TINs in a single project. Users can now choose which TIN to use for contour line generation and decide whether to create a new model or overwrite an existing one
PIX4Dmatic Pro
New Capabilities
Bug fixes
| 2.0.0 | January 5, 2026 | Stable | Windows | Mac |
| 2.0.1 | January 30, 2026 | Stable | Windows | Mac |
| 2.0.2 | February 16, 2026 | Stable | Windows | Mac |
2.0.2
All licenses
New Capabilities
Added support for opening PIX4Dmapper and PIX4Dsurvey project files by:
Right-click on a .p4d or .p4s file → Open with “PIX4Dmatic.exe”
Drag & Drop a .p4d or .p4s file onto the “PIX4Dmatic.exe” desktop icon
From the command line (e.g. Command Prompt)
e.g. "c:\Program Files\PIX4Dmatic\PIX4Dmatic.exe" project.p4d
Bug fixes
- Fix crash when opening native file explorer on Windows
2.0.1
All licenses
Bug fixes
- Fixed a crash that could occur during communication with Pix4D server
- Fixed a crash that could occur when closing the application
- Fixed an issue where manual tie points would disappear from the 2D and 3D views during calibration or reoptimization
- Fixed an issue where exported volume CSV files always used metric units, ignoring the project setting for display units
- Fixed an issue where the 2D view incorrectly displayed the 3D length for measurements instead of the expected 2D length
- Removed the duplicate Compute all outdated volumes command from the Edit menu; it is now exclusively located in the Process menu
PIX4Dmatic Standard
Bug fixes
PIX4Dmatic Analyst
PIX4Dmatic Pro
Bug fixes
2.0.0
All licenses
New Capabilities
- Added support for the new PIX4Dmatic license plans: Analyst, Standard, and Pro
- Added a project axes indicator in the 3D view
- Moved the outlier removal filter from the processing options to a standalone tool accessible via the 3D view and point clouds panel
- Updated the Device manager to display active devices from all organizations
Bug fixes
- Fixed an issue that could cause the application to freeze when exporting GeoTIFF files
- Fixed an issue where the custom report displayed incorrect names for volumes in the overview page
- Added support for imported point clouds in the custom report inventory snapshots
- Fixed an issue that prevented opening LAS files containing incorrect variable length record (VLR) information
PIX4Dmatic Standard
PIX4Dmatic Analyst
New Capabilities
- All PIX4Dsurvey features are now available in PIX4Dmatic: Key capabilities now integrated into a single application include automatic vectorization and comprehensive terrain workflows (terrain classification, TIN, grid, and contour lines)
- Added the ability to generate a digital terrain model (DTM) using terrain-classified points to create bare-earth surface models
- Added the option to generate contour lines directly from the digital terrain model (DTM)
PIX4Dmatic Pro
New Capabilities
