Measure tool- PIX4Dcatch
This support guide explains how to use the Measure tool in the PIX4Dcatch mobile app to capture site measurements in real time, either with an RTK device or with the device's GPS.
PIX4Dcatch allows measurements to be taken directly in the app using the device's built-in GPS or a connected RTK device for high-accuracy positioning.
      Measure with an RTK device
      Measure using the mobile device's GPS
For higher-accuracy positioning and accurate measurement, connect a supported RTK device to the PIX4Dcatch app.
  1. Open PIX4Dcatch.
  2. Connect the supported RTK device to PIX4Dcatch. For more information, visit Connecting PIX4Dcatch to a compatible RTK (GNSS) device.
  3. Go to the Capture view and tap on Button Tools icon located at the lower left of the screen.
  4. Tap on Measure.
    Measure tool-portrait
  5. Position the reticle Frame 2608838 at the starting location and tap Plus Add Point icon. Move to the endpoint, position the reticle Frame 2608838 , and tap Plus Add point icon.
  6. The zoom tool can be used to zoom in or out to add a point.  It is possible to redo, undo, or delete the line or point that has been created.
    Zoom to measure-portrait
  7. Tap on the Button (2) OK icon to complete the measurement. (Option) Add additional points to create a multi-segment measurement if required.
  8. Once the measurement is complete, tap the line to view details such as Name, Description, 2D length, 3D length, Elevation Difference, and slope.
When no RTK device is connected, PIX4Dcatch uses the mobile device's built-in GPS for positioning.
  1. Open PIX4Dcatch.
  2. Go to the Capture view and tap on Button Tools icon located at the lower left of the screen.
  3. Tap on  Measure.
  4. Position the reticle Frame 2608838 at the starting location and tap Plus Add Point icon. Move to the endpoint, position the reticle Frame 2608838 , and tap on Plus Add point icon.
  5. The zoom tool can be used to zoom in or out to add a point.  It is possible to redo, undo, or delete the line or point that has been created.
  6. Tap on the Button (2) OK icon to complete the measurement. (Option) Add additional points to create a multi-segment measurement if required.
  7. Once the measurement is complete, tap the line to view details such as Name, Description, 2D length, 3D length, Elevation Difference, and slope.
