Advanced Settings - PIX4Dcatch
The Advanced Settings menu provides additional tools to customize how PIX4Dcatch captures, displays, and stores data. This article explains each option and its purpose.
Capture settings
To access the advanced settings:
  1. Go to the main menu and select Capture Settings
  2. Tap in the More section and select Advanced settings
A Reset to defaults button is available to restore all settings to their original values. Settings locked by your organization are not affected by Reset to defaults.
Note: For information about the basic settings, please refer to the App Overview - PIX4Dcatch
Advanced settings
Settings vary depending on whether the device is an iPhone/iPad or an Android device. Upon accessing the Advanced Settings, the controls are structured into several distinct sections. Each section can be activated or deactivated using the corresponding toggle:
  • Capture Quality
  • RTK
  • View
  • Mesh
  • Other
 Available settings vary based on the device, whether iOS (iPhone/iPad) or Android.
iOS Advanced Settings
Capture Quality
  • Warning Sounds: Receive audible warnings during capture.
  • Auto Focus: Sets the camera settings to auto focus.
  • Skip Low Quality Images: Prevents image capture when excessive device movement is detected. A warning appears on-screen when triggered.
  • Resolution: Defines the resolution of the captured images. Higher resolutions require more processing time and storage.
    • Normal: Lower than 4k*.
    • 4K: Approx. 4K*.
    • Maximum Resolution: above 4K*.
* Actual values depend on the device model. Refer to Apple’s device specifications for details.
Note: High-resolution capture is available on iPhone 11 and later and iPad Pro (5th generation and later).
RTK
  • Shows accuracy color overlay: Displays a color-coded accuracy gradient at the top of the capture view when connected to an RTK device.
View
  • Show Cameras: Display the camera indicator (image pyramid) for each captured photo.
  • Live preview mode: Controls how the real-time preview is displayed.
    • First-person view: The view from the camera viewpoint.
    • Top View: The view from above.
Mesh
  • Enable Live Depth Mesh:  Generates a lightweight mesh from LiDAR depth data. Available only for devices with LiDAR
  • Enable Mesh: Generates a mesh from LiDAR depth data. Available only for devices with LiDAR. This mesh requires substantially more processing power and is limited to 1500 images.
  • Mesh Settings: Set the mesh type and mesh colors.
    • Save Mesh: Save a copy of the Depth mesh to the project.
    • Mesh type: Display the mesh or cameras as wireframes.
    • Mesh color: Adjust mesh and/or camera indicator colors using a 0–1 value scale.
    • Mesh background: Adjust background opacity.
Other
  • Disable background upload: Turn off the ability to upload projects to PIX4Dcloud in the background.
  • Show PIX4Dcloud AR legacy option: Turn off the ability to work with the legacy PIX4Dcloud AR workflow. This feature has been upgraded with the PIX4Dcatch AR mode.
  • Enable Pause Button: Enables the pause button during the capture.
  • Save Video: Saves a video recording of the capture session. Available to all users, with or without a PIX4Dcatch Professional license. The video is saved with the project and included when the project is exported.
Android Advanced Settings
            advanced settings
Capture Quality
  •  Auto Focus: Sets the camera settings to autofocus.
View
  • Show Feature Points: Display the feature points as detected by the device.  A greater density of feature points generally improves reconstruction accuracy.
Cameras
  • Camera Settings: Allows adjustment of camera indicator colors.
Mesh
  • Show Mesh: Displays the mesh in the viewer.
  • Mesh Settings: Set the mesh type, density, and mesh colors.
    • Mesh density: Adjust the density.
    • Mesh color: Adjust mesh and/or camera indicator colors using the 0–1 value scale.
      Screenshot_20251117-123316_PIX4Dcatch
