Supported drones and cameras - PIX4Dmapper
Pix4D develops both image acquisition apps, which allow one to perform drone and terrestrial captures, and photogrammetry software that transforms images into 2D and 3D outputs for different applications and use cases.
This article describes if and how Pix4D apps and software are compatible and support different drones, cameras, and devices.
Important: Note that if a drone, camera, or device is not supported by one of Pix4D's image acquisition apps, this doesn't necessarily mean that the images captured with that drone, camera, or device can't be processed in one of Pix4D's photogrammetry software.
For example, while PIX4Dscan and PIX4Dcapture don't support the DJI Mavic 3, images from this drone can be processed in any of Pix4D's processing software. For more information: Which image acquisition app can I use with Pix4D's software?
Supported drones
Drone Flight Processing
  PIX4Dcapture new_capture_logo_light.jpg PIX4Dcapture Pro new_capturepro_logo_dark.png PIX4Dscan new_scan_logo_light.jpg PIX4Dmapper new_mapper_logo_light.jpg PIX4Dmatic new_matic_logo_light.jpg PIX4Dfields new_fields_logo_light.jpg PIX4Dreact new_react_logo_light.jpg PIX4Dcloud new_cloud_logo_light.jpg PIX4Dinspect new_inspect_logo_light.jpg PIX4Dengine new_engine_logo_light.jpg
Inspire 1
Inspire 2
Mavic Air
Mavic Air 2
Air 2S
Mavic Mini
Mavic Pro
Mavic 2 Pro
Mavic 2 Zoom
Mavic 2 Enterprise Dual iOS (RGB)     RGB RGB RGB RGB RGB
Mavic 2 Enterprise Advanced       RGB RGB RGB RGB RGB
Mavic 3
Mavic 3 Enterprise - 3E
Phantom 3
Phantom 3 Advanced
Phantom 3 Pro
Phantom 4
Phantom 4 Pro
Phantom 4 Pro V2
Phantom 4 RTK
Phantom 4 Multispectral
Spark
Matrice 100
Matrice 200
Matrice 200 V2
Matrice 210
Matrice 210 RTK X4S / X5S X4S / X5S
Matrice 210 V2   X4S / X5S X4S / X5S
Matrice 210 V2 RTK   X4S / X5S X4S / X5S
Matrice 300 RTK   P1 P1
Matrice 30T       RGB RGB RGB RGB RGB RGB
Matrice 600
Anafi
Anafi USA RGB RGB RGB
Anafi Ai
Anafi Thermal RGB RGB RGB RGB RGB RGB RGB
Yuneec H520
AgEagle eBee series
Albris
Sentera
AeroVironment Quantix
Autel Evo I
Autel Evo II 8K
Autel Evo II Pro 6K
Autel Evo II V3
Autel Evo II Dual
Skydio 2 / 2+
Skydio X2       RGB RGB RGB RGB
Wingtra
Delair UX11
ACSL Soten
XAG M500
Supported cameras
Camera Flight Processing
Any camera       ** *** **** ° °° °°°
Zenmuse X3
Zenmuse X4S
Zenmuse X5
Zenmuse X5R
Zenmuse X5S
Zenmuse X7
Zenmuse XT
Zenmuse XT2
Zenmuse H20T       RGB RGB RGB RGB RGB
Zenmuse P1
Yuneec E90
S.O.D.A. series
Albris
Aeria X
S110 RGB/NIR/RE
Sequoia / Sequoia+
Altum
Altum-PT
RedEdge
RedEdge-P
RedEdge- MX / M
SlantRange-3P
Sentera 6X
La Quinta DB2-Vision
Sony Alpha 7R IV
Sony Cyber-shot DSC-RX1RM2
Sony Cyber-shot DSC-WX220
Sony UMC-R10C
Sony
Canon
Nikon
Delair
Hasselblad
Olympus
Panasonic
Pentax
Pioneer
Ricoh
Tetracam
GoPro cameras
Other brands
* PIX4Dmapper has an extensive internal camera database but can process images from any camera model (RGB, multispectral, thermal). For cameras that do not exist in PIX4Dmapper's camera database, the optimal internal camera parameters can be computed in the software while processing a good dataset. For more information:
Requests to add new camera models to the database can be sent to Technical Support.
** PIX4Dmatic has an internal camera database with precalibrated models but can process images from any camera model (RGB) as long as the images contain the necessary EXIF/XMP (metadata) tags. Requests to add new camera models to the database can be sent to Technical Support.
*** PIX4Dfields has an extensive internal camera database but can process images from any camera model (RGB, multispectral, thermal).
For camera models and resolutions that don't exist in the PIX4Dfields' database, it is still possible to process a dataset if a file with the internal camera parameters is provided. For more information: Your camera is not supported at this time - PIX4Dfields. Requests to add new camera models to the database can be sent to Technical Support.
**** PIX4Dreact has an extensive internal camera database but can process nadir images from any camera model (RGB).
For camera models and resolutions that don't exist in the PIX4Dreact's database, it is still possible to process a dataset if a file with the internal camera parameters is provided. For more information: Your camera is not supported at this time - PIX4Dreact. Requests to add new camera models to the database can be sent to Technical Support.
° PIX4Dcloud has an internal camera database but can process images from any camera model (RGB, multispectral). It can process thermal images and generate a reflectance map only when used in combination with PIX4Dmapper.
For cameras that do not exist in PIX4Dcloud's camera database, the software can potentially process the images and compute the optimal internal camera parameters provided that a good dataset is given as input (Enough images (100 - 300 images), non-planar scene (not all objects with the same height), high overlap and rich texture, several grid flights (at different heights) or oblique imagery with sufficient overlap, if possible, with GCPs).
°° PIX4Dinspect has an internal camera database but can process images from any camera model (RGB).
For cameras that do not exist in PIX4Dinspect's camera database, the software can potentially process the images and compute the optimal internal camera parameters provided that a good dataset is given as input (Enough images (100 - 300 images), non-planar scene (not all objects with the same height), high overlap and rich texture, several grid flights (at different heights) or oblique imagery with sufficient overlap).
°°° PIX4Dengine has an internal camera database but can process images from any camera model (RGB, multispectral, thermal).
For cameras that do not exist in PIX4Dengine's camera database, the software can potentially process the images and compute the optimal internal camera parameters provided that a good dataset is given as input (Enough images (100 - 300 images), non-planar scene (not all objects with the same height), high overlap and rich texture, several grid flights (at different heights) or oblique imagery with sufficient overlap, if possible with GCPs).
0 out of 0 found this helpful
