Troubleshooting
Drone connection issues - PIX4Dcapture Pro
In case the connection can not be established with the drone, ensure that:
  • You can connect properly to your drone using the drone manufacturer application.
  • PIX4Dcapture Pro is compatible with the drone, camera, and controller: Supported drones, cameras, and controllers.
  • The correct drone model is selected in the Dashboard of PIX4Dcapture Pro.
  • The drone manufacturer's app is not running in the background. Force quit if necessary: How to force quit PIX4Dcapture Pro.
  • The USB cable is properly plugged between the remote controller and the iPad or tablet. Unplug and replug if necessary.
  • The drone is registered with the remote controller. Ensure that the drone can be flown with the controller user. Please verify this with the drone manufacturer app before attempting to use the drone with PIX4Dcapture Pro app.
  • Restart the procedure from scratch. To do so, close and force quit the app, disconnect the cable from the iPad or tablet, and turn off the remote controller and the drone. Then switch on the drone and the controller, reconnect the USB cable, and open PIX4Dcapture Pro.
