How to use vertical coordinate systems and geoids - PIX4Dsurvey
This article explains how to select vertical coordinate reference systems, geoid, or geoid height in PIX4Dsurvey. Selecting the correct vertical coordinate reference system is important to geolocate the reconstruction and the elements within accurately.
What is a geoid model: The geoid is defined based on the earth's gravity field and is used as the reference surface for heights. Beneath the continents, it can be considered as a continuation of the mean sea level surface.
For more information, see the Orthographic (geoid) vs. ellipsoidal heights article.
PIX4Dmatic and PIX4Dsurvey support global geoids (EGM84, EGM96, and EGM2008) and local geoids, for example, GEOID12B in the US and OSGM15 in the UK.
For local geoids that are not included in the PIX4Dmatic and PIX4Dsurvey database, it is possible to specify the Geoid height value to convert between ellipsoidal and orthometric heights.
Access: For more information on how to define the horizontal and vertical coordinate systems of the project, please see the How to use coordinate systems in PIX4Dsurvey article.
Selecting the vertical coordinate reference system
After selecting the Horizontal coordinate reference system, the list of Vertical coordinate reference systems is available.
Only Vertical coordinate reference systems within the area of use of the Horizontal coordinate reference system are listed.
Selecting the geoid
Several geoid models are available in the PIX4Dmatic and PIX4Dsurvey databases. The full list is available in the List of supported geoids section.
The list of available geoids depends on the selected vertical coordinate reference frame.
Important: Before selecting the Geoid, it is necessary to select the correct  Vertical coordinate reference system. Only geoids corresponding to a certain vertical coordinate reference system are listed in the Geoid drop-down menu.
Selecting the geoid height
When the geoid corresponding to the selected vertical reference frame is not available, it is possible to specify the Geoid height value, which represents the height between the base ellipsoid of the horizontal coordinate reference system and the desired geoid.
The Geoid height value is used to convert the image geolocation (WGS 84 ellipsoid or EGM96 geoid) into the desired project coordinate system.
Important: Before selecting the Geoid, it is necessary to select the correct  Vertical coordinate reference system. Only geoids corresponding to a certain vertical coordinate system are listed in the Geoid drop-down menu.
Country or region Vertical coordinate reference system Geoid Note
Global EGM96 height - EPSG:5773 EGM96 15' geoid
EGM2008 height - EPSG:3855
MSL height - EPSG:5714
EGM2008 2.5' geoid
Argentina SRVN16 height - EPSG:9255 GEOIDE-Ar16
Australia AHD height - EPSG:5711
AHD (Tasmania) height - EPSG:5712
AUSGeoid98
AUSGeoid09
AHD height - EPSG:5711 AUSGeoid2020
Austria EVRF2000 Austria height - EPSG:9274 Austrian Geoid 2008
GHA height - EPSG:5778 Austrian Geoid 2008 | GHA
Belgium Ostend height - EPSG:5710 hBG18
Canada
CGVD28 height - EPSG:5713 CGG2000/HTv2.0
CGVD2013(CGG2013) height - EPSG:6647 CGG2013
CGVD2013(CGG2013a) height - EPSG:9245 CGG2013a
Corsica NGF-IGN78 height - EPSG:5721 RAC09
NGF-IGN78 height - EPSG:5721 RAC23
Czech Republic Baltic 1957 height - EPSG:8357 CR-2005
Denmark DVR90 height - EPSG:5799 DVR90
DNN height - EPSG:5733 DNN
Faroe Islands FVR09 height - EPSG:5317 FVR09
Finland N60 height - EPSG:5717 FIN2000
N2000 height - EPSG:3900 FIN2005N00
France
NGF-IGN69 height - EPSG:5720 RAF09
NGF-IGN69 height - EPSG:5720 RAF18
NGF-IGN69 height - EPSG:5720 RAF18b
NGF-IGN69 height - EPSG:5720 RAF20
Germany DHHN2016 height - EPSG:7837 GCG2016
Greenland GVR2000 height - EPSG:8266 GGEOID2000
GVR2016 height - EPSG:8267 GGEOID2016
Iceland ISH2004 height - EPSG:8089 IceGeoid2011
Japan JGD2011 (vertical) height - EPSG:6695 GSIGEO2011
Latvia Latvia 2000 height - EPSG:7700 LV14
Mexico NAVD88 height - EPSG:5703 GGM10
Netherlands NAP height - EPSG:5709 NLGEO2018
Bonaire height - EPSG:10763 BONGEO2004
New Zealand NZVD2009 height - EPSG:4440 NZGeoid2009
Meant to be used with an NZ horizontal CRS
NZVD2016 height - EPSG:7839 NZGeoid2016
Auckland 1946 height - EPSG:5759 NZGeoid2016 | Auckland 1946
Bluff 1955 height - EPSG:5760 NZGeoid2016 | Bluff 1955
Dunedin-Bluff 1960 height - EPSG:4458 NZGeoid2016 | Dunedin-Bluff 1960
Dunedin 1958 height - EPSG:5761
NZGeoid2016 | Dunedin 1958
Gisborne 1926 height - EPSG:5762
NZGeoid2016 | Gisborne 1926
Lyttelton 1937 height - EPSG:5763
NZGeoid2016 | Lyttelton 1937
Moturiki 1953 height - EPSG:5764
NZGeoid2016 | Moturiki 1953
Napier 1962 height - EPSG:5765
NZGeoid2016 | Napier 1962
Nelson 1955 height - EPSG:5766
NZGeoid2016 | Nelson 1955
One Tree Point 1964 height - EPSG:5767
NZGeoid2016 | One Tree Point 1964
Stewart Island 1977 height - EPSG:5772
NZGeoid2016 | Stewart Island 1977
Taranaki 1970 height - EPSG:5769
NZGeoid2016 | Taranaki 1970
Wellington 1953 height - EPSG:5770
NZGeoid2016 | Wellington 1953
Norway NN2000 height - EPSG:5941 HREF2018b
Norway / Svalbard SVD2006 height - EPSG:20000 arcgp-2006-sk
SVD2024 height - EPSG:10999 Svalbard_EGG2015_2024
Poland Baltic 1986 - EPSG:9650
EVRF2007-PL height - EPSG:9651
PL-geoid-2011
EVRF2007-PL height - EPSG:9651 PL-geoid-2021
Portugal Cascais height - EPSG:5780 GeodPT08
Singapore SHD height - EPSG:6919 SGeoid09
Slovakia Baltic 1957 height - EPSG:8357 DVRM05 Only available to Baltic 1957 height
Slovenia SVS2010 height - EPSG:8690 SLO_VRP2016/Koper
South Africa SA LLD height - EPSG:9279 SAGEOID2010
Spain Alicante height - EPSG:5782 EGM08-REDNAP
Sweden RH2000 height - EPSG:5613 SWEN17
Switzerland LN02 height - EPSG:5728
LHN95 height - EPSG:5729
CHGeo2004
Taiwan TWVD 2001 height - EPSG:8904 TWGEOID2018h
UK Belfast height - EPSG:5732
Douglas height - EPSG:5750
Lerwick height - EPSG:5742
Malin Head height - EPSG:5731
ODN (Offshore) height - EPSG:7707
ODN height - EPSG:5701
ODN Orkney height - EPSG:5740
St. Marys height - EPSG:5749
Stornoway height - EPSG:5746
OSGM15 Including Great Britain, Ireland, and North Ireland
US NAVD88 height - EPSG:5703
NAVD88 height (ft) - EPSG:8228
NAVD88 height (ftUS) - EPSG:6360
GEOID99
GEOID03
GEOID06
GEOID09
GGM10
NMVD03 height - EPSG:6640
PRVD02 height - EPSG:6641
VIVD09 height - EPSG:6642
ASVD02 height - EPSG:6643
GUVD04 height - EPSG:6644
GEOID12A
GEOID12B
GEOID18
Importing geoids
Note: This feature is available for versions 1.57 or newer.
Access
Ensure the following requirements concerning coordinate reference systems are fulfilled.
  • Download the respective file.
    • This file can be downloaded only via the official authorities.
  • Set the vertical coordinate reference system according to the table below.
Then, a new option, import.pngImport geoid will be visible.
List of supported geoid models for import
Country or region Vertical coordinate reference system Geoid Source File name
Estonia EH2000 height- EPSG:9663 EST-GEOID2017 Avaleht | Geoportaal | Maa-amet  EST-GEOID2017.BLN
Lithuania LAS07 height - EPSG:9666 LIT20G Nacionalinė žemės tarnyba prie Aplinkos ministerijos
LIT20G.txt
South Korea KVD1964 height - EPSG 5193 KNGeoid18 National Geographic Information Institute of South Korea (NGII) KNGeoid18.dat
KNGeoid24 National Geographic Information Institute of South Korea (NGII) hybrid_geoid.dat
Useful information
  • After successfully importing it, this geoid will be used as any other geoid model.
  • Importing a custom geoid file needs to be done only once.
  • Any new project created afterward will have the custom geoid model already available. This also applies after installing a later version of PIX4Dmatic/PIX4Dsurvey.
  • When importing the custom geoid file into PIX4Dmatic version 1.57 or newer, it will also be available in the equivalent version of PIX4Dsurvey and vice versa.
