Depth point cloud - PIX4Dmatic
PIX4Dmatic_point_cloud_icon_small.png Dense point cloud PIX4Dmatic_depth_point_cloud_small.png Depth point cloud PIX4Dmatic_fusion_depth_dense_small.png Depth & dense fusion
Depth point cloud
The depth point cloud is generated from LiDAR depth maps.
Note: since version 2.4.0, processing can be paused and resumed at any time as long as the project remains open. There is no need to cancel and start over. If processing is paused and the project is about to be closed, the following message will appear.
Captura de pantalla 2026-04-20 132137
Access:
  • Click Processing options processing_options.png.
  • On the Menu bar, click Process > Depth point cloud...
Important: Available only with PIX4Dcatch projects that contain LiDAR depth maps.
We recommend using it:
  • To get a quick overview of the project. The depth point cloud generation is relatively fast compared to the Calibrate and Dense point cloud step but still gives a good overview if the data acquisition is good.
  • To combine it with the dense point cloud to get a more complete fused point cloud. More information can be found the Depth and Dense fusion article.
