Depth and dense fusion - PIX4Dmatic
Pix4Dmatic raycloud icon
Calibration
gaussian
Gaussian splats
Pix4Dmatic point cloud icon
Point cloud
Mesh
Pix4Dmatic dsm icon
DSM
Pix4Dmatic orthomosaic icon
PIX4Dmatic_point_cloud_icon_small.png Dense point cloud PIX4Dmatic_depth_point_cloud_small.png Depth point cloud PIX4Dmatic_fusion_depth_dense_small.png Depth & dense fusion
The Depth & dense fusion option combines the point cloud generated from images with the one generated from LiDAR depth maps.
Note: since version 2.4.0, processing can be paused and resumed at any time as long as the project remains open. There is no need to cancel and start over. If processing is paused and the project is about to be closed, the following message will appear.
Captura de pantalla 2026-04-20 132137
Access:
  • Click Processing options processing_options.png.
  • On the Menu bar, click Process > Depth & dense fusion...
Important: Available only with PIX4Dcatch projects that contain LiDAR depth maps.
This feature combines the photogrammetry and LiDAR point cloud and makes the final point cloud denser and more complete.
The following parameter can be set:
  • Distance: The minimum distance [units] from a depth point to the dense point cloud for fusing it. The values depend on selected units:
    • 0 - 0.500 m, default 0.025 m, or
    • 0 - 1.640 ft / ftUS, default 0.082 ft / ftUS.
Example: Reflective areas are challenging to reconstruct and the dense point cloud generated from images is likely to have holes. In those cases, the point cloud generated from depth maps can be used to fill the holes.
