Download the latest version for android.
Current Version 1.11.0
Version | Release date | Release type |
1.11.0 | June 28th, 2022 | Updates, Improvements, Bug fixes |
Version 1.11.0 |
What's new
- Support for viDoc RTK rover.
- Able to capture in Portrait mode.
- Search bar and project number added to the projects view.
Bug fixes
- Improve captured point cloud.
- Improve image triggering and performance during capture.
- Many UI improvements and bug fixes.
Versions 1.10.0
1.10.0 | March 28th, 2022 | Updates, Improvements, Bug fixes |
Version 1.10.0 |
What's new
- Improved warnings during capture.
- Improved authentication workflow.
Bug fixes
- Fix issues when uploading to PIX4Dcloud.
- Fix crash and issues when canceling an upload.
- Fix issue of not being able to load sites in multi-projects upload.
- Fix issues when opening large projects in the detailed view.
- Fix issues related to the demo project.
Versions 1.9.1
1.9.1 | March 17th, 2022 | Bug fixes |
Version 1.9.1 |
Bug fixes
- Stability improvements.
Versions 1.9.0
1.9.0 | March 10th, 2022 | Updates, Improvements, Bug fixes |
Version 1.9.0 |
What's new
- Improve demo project download.
- Show more complete captured point cloud for large captures.
- Add Auto-rotate functionality in the live preview top-view mode.
Bug fixes
- Ability to manipulate smoothly the 3D View when the cameras are shown.
- Improvements in the upload to PIX4Dcloud workflow.
Versions 1.8.0
1.8.0 | February 7th, 2022 | Updates, Improvements, Bug fixes |
Version 1.8.0 |
What's new
- Demo project available in the projects folder.
- Ability to rotate phone upside down (180 degrees).
- Availability to use geoid GSIGEO2011.
Bug fixes
- Fixed issue showing the disclaimer page after logout.
- Fixed issue of not being able to pass the disclaimer page on tablets.
- Update geoids.
- Many bug fixes and improvements.
Versions 1.7.1
1.7.1 | January 4th, 2022 | Improvements |
Version 1.7.1 |
What's new
- Allow unlimited processing for valid PIX4Dcloud Advanced trial licenses.
Versions 1.7.0
1.7.0 | December 14th, 2021 | Updates, Improvements, Bug fixes |
Version 1.7.0 |
What's new
- Show feature points in live preview view for non-supported depth devices.
- Improve 3D viewer visualization.
- App usage disclaimer.
Bug fixes
Versions 1.6.0
1.6.0 | November 29th, 2021 | Updates, Improvements, Bug fixes |
Version 1.6.0 |
What's new
- Upload multiple projects to PIX4Dcloud.
- Continues to upload when the app is in the background.
- Project upload progress bar.
- Show resume percentage tag for partially uploaded projects.
- Improve display of image locations on the map.
- Enhance upload failure messages.
Bug fixes
- App can be used without Location Services
- Fixed issues when using multiple accounts in the app.
- Fix crashes.
Versions 1.5.0
1.5.0 | November 2nd, 2021 | Updates, Improvements, Bug fixes |
Version 1.5.0 |
What's new
- New default processing pipeline used when uploading to PIX4Dcloud
- Option to process with the classic PIX4Dmapper pipeline
- Ability to view third-party license info from the account dialog
Bug fixes
- Alert when illegal characters are used to rename projects when uploading to PIX4Dcloud
- Show loading dialog when opening the project details
- Fixed crashes and improvements
Versions 1.4.0
1.4.0 | October 4th, 2021 | Updates, Bug fixes |
Version 1.4.0 |
What's new
- Show Imperial or Metric units based on the system locale
- When upload fails, a dialog explaining the reason appears
Bug fixes
- Fix crashes when sending app to background
- Fix issue of not showing the Delete button when multiple projects are selected
- Fix crashes when exporting data while the device is low on resources
Versions 1.3.0
1.3.0 | August 25th, 2021 | Updates, Bug fixes |
Version 1.3.0 |
What's new
- Display the PIX4Dcloud processed 3D-model in the project 3D-view
- Ability to save logs, rename & delete a project from the detailed view
- Display the percentage towards completion when uploading to PIX4Dcloud
Bug fixes
- Fix issue of having corrupted images on some devices
- Fix issue of showing the wrong image after selection
- Show live preview data after it was hidden
- Fix occasional crashes while saving and opening projects
Versions 1.2.0
1.2.0 | August 4th, 2021 | Updates, Improvements |
Version 1.2.0 |
What's new
- Live -preview:
- Show 3D preview of the scene captured in real-time
- Show the location of images in the live preview
- Toggle between a top view and synchronized camera views Visualize & export the 3D model
- 3D view in the project details that render the depth points & the images
- Export the point cloud in PLY format
- Other updates:
- Display information, storage used & maps of the project
Bug fixes
- Solved corrupted zipped files for large capture
- Solved lagging in overlap trigger mode
Versions 1.1.0
1.1.4 | July 20th, 2021 | Updates |
1.1.3 | May 12th, 2021 | Updates, Bug fixes |
1.1.2 | May 3rd, 2021 | Updates, Bug fixes |
1.1.1 | April 12th, 2021 | Bug fixes |
1.1.0 | March 29th, 2021 | Updates, Improvements |
Version 1.1.4 |
What's new
- The ability for any PIX4D account user to export a project to a photogrammetry software such as PIX4Dmatic
Version 1.1.3 |
What's new
- Ability to view, pan, and zoom images in the detailed project view
- Ability to delete images
- Ability to show image information
- Default trigger setting is set to 90% overlap
- Reframing of the text in the upload dialog to make it more understandable
- Ability to receive notifications
Bug fixes
- Fixed crash when accepting permissions at the first start of the app
- Fixed autofocus option not being applied
Version 1.1.2 |
What's new
- Ability to change a project name on save
- Ability to cancel a current capture session
Bug fixes
- Fixed issue of not able to download the app from play store, on many devices, due to depth API support
Version 1.1.1 |
Bug fixes
- Fixed issue of not being able to create a trial license for some users
- Fixed issue of having incorrect altitude in some image metadata
Version 1.1.0 |
What's new
- Ability to choose image overlap trigger from the settings during data capture
- Enhanced visualization technique to improve the experience of data capture
- More feature points are shown during data capture
- Ability to filter projects by the mean of tabs in the projects view
- Ability to save log files from the projects view
Bugs fixes
- Fixed crash when getting network state on Galaxy tab
- Fixed issue when exporting projects on Xiaomi
- Fixed issue of login to PIX4D from Chrome browser
Versions 1.0.0
1.0.3 | March 8th, 2021 | Bug fixes |
1.0.2 | March 4th, 2021 | New, bugs fixes |
1.0.1 | Feb 3rd, 2021 | Bugs fixes |
1.0.0 | Feb 2nd, 2021 | Initial release |
Version 1.0.3 |
Bug fixes
- Add a check if "Google Play Services for AR" is not installed and redirect to Google Play Store for installation
Version 1.0.2 |
What's new
- Ability to select multiple projects to discard them
- Ability to rename projects
- Ability to export a project while offline
- Automatic selection of a newly created site
- Other minor improvements to the user interface
Bug fixes
- Fixed issues when performing volume calculations for high-resolution GSDs
- Fixed an issue where project files were uploaded multiple times
- Fixed the ability to re-upload a project when it is deleted on PIX4Dcloud
- Fixed crash at startup when GPS is updating
Version 1.0.1 |
What's new
- Bug fixes
Version 1.0.0 |
PIX4Dcatch is the tool for acquiring optimal ground images for photogrammetry. These ground images can be used to get highly accurate 3D models on or offline within PIX4Dmapper (free 15-day trial available, then a valid subscription is required).
No need to be an expert. Walk around your area of interest and the app will record pictures along the way, together with GPS positions. Images can be uploaded to PIX4Dcloud for the fast generation of scaled and georeferenced 3D models and point clouds that you can visualize, measure, share, and export. Or they can be exported locally for processing in PIX4Dmapper.
Workflow
- Scan: Walk around the area of interest. PIX4Dcatch automatically records geotagged frames and displays on your screen real-time 3D meshing for scene completion feedback.
- Upload: Stop recording and automatically upload images to PIX4Dcloud to generate accurate and easy to share 3D models (requires a PIX4Dcloud subscription - free 15 day trial available).
- Export: Or export: transfer the images from your device to your desktop computer and start the photogrammetry process, add GCPs and validate the accuracy of your 3D scene with PIX4Dmapper (requires a PIX4Dmapper subscription-free 15-day trial available)
- Examine: Measure distances, areas, and volumes, and perform virtual inspections.
- Share: Selectively and securely share project data and insights with your team, clients, and suppliers. Devices compatibility:
Device compatibility:
- All ARCore enabled devices.
Usage information
- Ensure the app is up to date. Upload the images to PIX4Dcloud to generate, visualize, measure, and share your 3D model.
- PIX4D accepts no liability for damage, injuries, or legalities from the misuse of this app. Use only in safe environments.
